How do I do this?
Discussion in 'Newbie Forum' started by Johnnyc, Jul 1, 2011.
  1. Johnnyc
    Johnnyc New Member
    Billerica
    If I'm leaving my car at a Toyota dealership to be serviced and I won't be there to after hours how can I get my key. Is there a way to lock the car and have your key inside?
    John
  2. qbee42
    3,079
    Yes. Just lock it with the mechanical key.
  3. Johnnyc
    Johnnyc New Member
    Billerica
    I don't want to sound stupid but, "how does the little key start the car if the dealership has to move it to the garage area. I've never done this before and want to make sure I'm doing the right thing.
    thank you.
  4. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I believe that little key only unlocks the door so you can gain access to the FOB and start the car.
  5. andyprius
    2,212
    188
    What confuses me is how does the dealership lock the car if the FOB is in the car?
  6. Johnnyc
    Johnnyc New Member
    Billerica
    I'm getting more and more confused. what does FOB stand for?
  7. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    This seems like something the dealership can help you with?
    Call your service adviser and ask them! Let us know what they say.
  8. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Fresh of the boat. :D
  9. FLteacher
    FLteacher Junior Member
    75
    If you prepay (or pay by credit card over the phone ) or have a free service, they can lock the key in your car (using the door lock buttons on the door), and you can pick it up, using the other key. You do have two right?
  10. andyprius
    2,212
    188
    It is not actually an acronym, it is the electronic key you carry around in your pocket.
  11. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Hey Johnny,
    Here's what I would do. Bring some aluminum foil with you to the dealer. When you drop off the car, take the mechanical key out of the FOB (the plastic, electronic black key you carry with buttons on it) so that you keep the mechanical key while they work on the car. To remove it, just slide over the switch on top of the FOB and pull out on the side section. Again, don't give the old fashioned key to the dealer, keep it.
    Then only give the dealer the FOB part of the key with the aluminum foil. Ask them to lock your car when finished by wrapping the FOB in aluminum foil and putting it somewhere like the glove or center compartment. The car won't detect it that way (just cause of the foil, other location is just so you can find it when you get in!).
    When you come back afterhours, car is successfully locked, and you can open the driver's door with your mechanical key, unwrap the FOB from its foil, and voilà, you can start the car as normal.
  12. Johnnyc
    Johnnyc New Member
    Billerica
    I do have 2 keys. I thought you couldn't leave the key in the car because it could drain the battery. I thought I read that in this forum for newbies
  13. FLteacher
    75
    I don't think it will make much difference for just a couple of hours. I've left my keys in the car without thinking (in my purse overnight). Mike's idea is a good one - to wrap the fob in foil, so if someone breaks in, the car can't easily be stolen.
  14. richard schumacher
    7,664
    1,047
    United States
    Grammar nit: it's not "FOB", it's "fob". Go look it up.
