Only half the vents are blowing
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rustystew, Jul 4, 2011.
  1. rustystew
    rustystew New Member
    Galisteo NM
    Hey guys,
    I'm having an issue with my A/C (havn't tested with heat, cause it is hot outside). The middle two air vents don't blow air even when it is on max cooling. They did start working for about a day and a half about a month ago, but I have not idea why they started working or why they stopped working again. Thinking maybe loose wiring, or something of that sort. Have any of you guys heard of this issue? And are there certain things I can try before bringing it to get it fixed?
  2. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Could it be that the climate control air cleaner is plugged? Hal
  3. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    You do have them open, right? :D
  4. rustystew
    Galisteo NM
    Andyprius: definitely checked that. They are open.
    Hal: Not sure what that is. I'll look it up and see.
    Also I know the cabin air filter is clear
  5. Hal W
    Hal W New Member
    872
    53
    Yes ,but the criters may have got in there and built a home!!! Hal
  6. andyprius
    2,212
    188
    Could be something sticking electronically, if you try changing direction of air flow as well as temp extemes and recirculate and outside air, that might stimulate something to work. Only thing I can think of:....... Maybe there is a ECU for climate control??
  7. andyprius
    2,212
    188
    If your 07 is like my 05, then possibly the heat/defrost is on (lower left) I suppose this directs air to the windshield and removes air from the middle vents :cheer2:
  8. rustystew
    Galisteo NM
    This is something the mechanic at the dealer suggested. And actually went out and dinked with it at no cost to see if it worked. But, alas, it did not.
    I played with that some today. It doesn't seem to change my situation. I can hear something click back in the dash somewhere when I press that button (assuming some sort of gateway switch redirecting the airflow). It clicks both when I press it to turn on defrost and when I turn it off. However, it did lead to an interesting discovery. The window vent (the one defrost uses to blow air on the window) is always blowing weather defrost is on or not.
  9. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    Santa Fe, NM
    Did the tech happen to mention phases like "air mix servo"?
    I looked at the diagram and the center vents are about the last thing that you get to after taking apart the entire dash. I think you are at that point. :(
  10. rustystew
    Galisteo NM
    I had to bring my car in for 90k service so I have them taking a look at it now.
  11. rustystew
    Galisteo NM
    So the story is, there is a motor that moves it all back and forth and it is knocked off track. 3 hours labor @ $100 to fix, eff that. Definitely not worth $300. Now I just have to figure out how to take the dash apart myself so I can do it.
  12. seilerts
    3,326
    1,512
    Santa Fe, NM
  13. koolingit
    koolingit Member
    158
    Mocksville NC, USA
    Before you go crazy tearing the dash apart, try putting your head down by the brake peddle and looking up toward the center of the dash. There are linkages and levers there and one of them might be the culprit. Have someone work the defrost control while you watch these linkages move. Maybe you'll see something you can correct.
  14. rustystew
    Galisteo NM
    Oh man you guys! Thanks for the help. Super busy week ahead of me, might be able to play with it next weekend. -Randy
  15. koolingit
    koolingit Member
    158
    Mocksville NC, USA
  16. tomiprius
    tomiprius New Member
    San Jose, CA
    I have one for sale.
    Take a look on ebay
  17. rustystew
    Galisteo NM
    Ok guys, I was finally able to play with it today. KoolingIT thanks for the picture it was very helpful to see. I could use a bit more help though. Would anybody be willing to post a video of how it is supposed to move when it is working properly? I'm not so good at figuring things out but I'm super awesome at comparisons! I'm going to go out there and dick with it some, see what I come up with.
    What I notice is that attached to the piece shown in the other thread is a bar (circled in the image below) and it seems to be getting jammed and not sliding correctly along the piece further up in there not shown in this image. Now it could be that THAT piece is jammed because whatever it is connected to is jammed, but who knows.
  18. rustystew
    Galisteo NM
    Attached is a video of how mine is acting. There is the black box which pops around which I feel might be of particular interest.
  19. rustystew
    Galisteo NM
    update
    I dove under my dash again tonight, and found that white piece in the other thread had completely sliped off it's track. However, I think it is due to the black motor that rotates it being stuck therefore forcing it into slipping off it's track.
    My guess is that the trick is to set the settings on the computer controller to be the same as where the three pins are set (going to take some time and experimentation) then when those are set manually to match the computer/motor then pop the white piece on that connects the motor to the three pins.
    It's all very difficult because I can only get one hand in there to work AND I don't know where the pins are supposed to be in accordance to any setting (which I imagine is the hardest part).
    So, if anyone has any resource to point me to that will indicate or help me deduce the location of the pins in reference to what setting are on the computer, that would seem to help me very much.
    Thanks.
  20. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    509
    63
    I took some pictures of the gear positions. Hope this helps. Good luck!
    Cdgreg, mobes and rustystew like this.
