Map DVD quit working
Discussion in 'Gen 3 Prius Audio and Electronics' started by zcoach, Jul 6, 2011.
  1. zcoach
    zcoach Junior Member
    Blytheville, AR
    My 2010 nav went bad this weekend on the road. It says it does not see my DVD. If you eject it and put it back in, it will SOMETIMEs, rarely come on a few seconds then back to not seeing the DVD. Anyone have an idea on how to fix it?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Take it to the dealer and let them fix it if it is still under warranty.
  3. liskipper
    liskipper Member
    374
    79
    Long Island, NY
    I would check the DVD for dirt, fingerprints or scratches. There are cleaning kits that you can get from an audio store. If the DVD looks good, it should still be under warranty, so let a dealer take care of it. I am on my third Nav unit - they are so well built .... At least in each case it has been a warranty issue. Another reason to have an extended warranty on the Prius. A non-warranty replacement will pay for the extended warranty.
  4. zcoach
    Blytheville, AR
    I tried another DVD today and it did not work. Dealer said that a new one was $4000, reman was 2000. Found a reman on net for 1400. Is there anyone that can repair the one I own?
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Isn't is till under warranty? When did you buy the car and how many miles are on it?
  6. zcoach
    Blytheville, AR
    59000 miles:(
