Another Smart Key Question
Discussion in 'Gen 2 Prius Technical Discussion' started by cleon, Jul 11, 2011.
  1. cleon
    cleon New Member
    lebanon, Ohio, US
    I have a 2008 with smart key. I keep it in my pocket, all works
    well.
    If a car jacker stops me and I give up the car, How far will he
    get if I still have the smart key and it is not with him?
  2. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    As far as he can go without turning the car off. Prius won't shutoff as long as there is gas in the tank, but once powered off it won't restart without the fob. This is how Prius is designed so that if your smartkey battery dies while you're driving, the car won't suddenly quit say in the middle of the freeway.
  3. MarvinHC
    MarvinHC Junior Member
    49
    Europe
    Correct and this bears one other risk:
    Don't keep your key too close to the car inside the house, otherwise anyone could drive off without they key (for example if your driveway is right in front of the entrance door and you keep your key right inside the door on a hook or so)
  4. RobH
    RobH Senior Member
    2,376
    988
    70
    Sunnyvale, California
    The key has to be inside the car in order to start it. Try it!
  5. Politburo
    Politburo Active Member
    971
    208
    What RobH said, plus, if the key is within range for more than a minute (iirc), the system shuts off.
  6. MarvinHC
    49
    Europe
    mea culpa.
    I tried it out and you are absolutely right. Thanks for pointing this out.
  7. PriQ
    PriQ CT+iQ
    377
    113
    Europe
    And should the fob battery die, you can still start the car by placing the key right next to the start button.
    (Use the tiny spare key inside the fob to get inside)
  8. Patrick Wong
    18,200
    6,497
    Regarding 2G Prius, it is necessary to insert the fob into the dashboard slot. However 3G Prius does not have this slot, hence you need to hold the fob near the POWER button.
  9. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    holding it next to PWR button also works...I know because I bought my car with a dead SKS battery and thats how the salesman started the car for me on the test drive.
  10. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    Not far enough to escape the long-arm of the law. :confused:
  11. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Oh Patrick,
    Gen 2 with Smart System will no need to insert the fob into the slot. Mine has this function and the key was in my pocket ever since I owned the car for 2+ yrs. Really keyless get in ,fobless in the slot during driving.:).
  12. qbee42
    3,079
    Patrick is referring to the backup starting system used when the smart key has failed. Obviously you don't need to insert the fob when running in smart mode.
