Report: Imperfect fuel-saving tech contributed to Ford's fall in quality
Discussion in 'Other Cars' started by cwerdna, Jul 10, 2011.
  1. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Report: Imperfect fuel-saving tech contributed to Ford's fall in quality — Autoblog Green
    This relatees to the Ford not doing well recently in JDPA "initial quality" previously mostly blamed on MyFord Touch. Key passage from ABG:
    The awkward shifts sounds familiar.... GM's Chevy Cruze's automatics have had numerous complaints about shift quality, at least initially.
    However, Fords like the new non-manual Focus apparently use a dual clutch transmission instead of conventional automatic. I've never driven a Ford equipped w/one of these to be able to say if it's a good/similar driving experience to a conventional slushbox.
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Hmmm is this the old "I want 40 mpg out of a 4 cylinder car BUT still want the same smoothness and power I used to get with my 5 litre V8, but I now forget that it only got 15 mpg" conundrum?
  3. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    There have been some issues with the tranny. Some have a grinding issue, others have leaked. Ours has been flawless.
    Most of the complaints I would equate to being similar to the Prius braking "problems". The transmission is an automatic shifting manual, as such at slow speed it has that studdery feel that a manual has when you are in that mid-rpm band but too slow to upshift. People that have never driven a stick see this as an issue...it isn't, its just the way things work.
    I love the box. The twin clutch means that you never lose torque and the upshifts and downshifts are fast. The computer even blips the throttle on downshifts to match revs.
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    The famous 40 mpg of these cars is on the highway. How much gear shifting is happening ?
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Do they give you any sort of flappy-paddle gearbox override or a stick with a +/- to control gear changes yourself?
    I find the easiest way to tell if a double clutch system is any good at all is to try and fake it out. Accelerate hard and downshift or upshift while it is doing that. Also try to go N->N+1->N-2 and see if it shutters with the triple gear downchange. Try adding a N after the N-2 and see if it can pick back up again.
  6. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    No, it is completely hands off automatic.
    There are, however, two ways to tweak the shift patterns.
    1) Use L, it is not low gear but more like the "sport" mode of other automatics. It will hold out shifting to near redline and will downshift upto 2 gears but will not exceed redline.
    2) Use hill assist, its a B-mode sort of in that it will select a lower gear for max. engine braking, I like using it on uphills as it is not as harsh as L but will not shift midpoint on a hill and leave you with no torque.
    It's a good box, I enjoy it but it is not a regular auto. Really the dealers need to explain that just like they should explain the transition between regen and friction and how a bump could make that transition feel like accelerating.
  7. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    The auto is good for 2 more mpg in town too and 1 more on the hwy. The SFE, which is all autos includes a grille blocker and undercarraige covers (ala Prius) plus LRR tires for the extra MPG on the Fiesta. On the Focus they get the active grille shutters and probably under body panels as well.
  8. bisco
    51,787
    bnc, which model are you driving?
  9. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Why don't they use a CVT like what's in the Prius?
  10. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Because that would require 2 other sources of motive power to create gearing, something they just don't have.
    They could do a standard belt driven CVT on a cone, but there is a practical limit for how much power can be had out of one of those. So perhaps they need too much power to make it not feel like a turd on the road so they can't use it... Or perhaps ford just doesn't have this tech. Honda and Nissan are the only big ones I know of that used it for mass production.
  11. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    The type of CVT in Prius is a PLANETARY, which is used to combine a gas engine and two electric motors.
    That wouldn't work in a traditional vehicle, since all it has is a gas engine. The other type is CONE & BELT, which could be used. But acceptance of that in previous vehicles has been a mix.
  12. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    We have a Fiesta SE in addition to our 2010 Prius III. :rockon:
  13. bisco
    51,787
    you sound pretty happy with it. i saw a new focus today, much better looking than the old one.
  14. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    Yes the new gen. is quite nice, I actually like the sedan in the focus too.
  15. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Nissan uses its CVT at least up to high 200's in the current altima and maxima, though in its infiniti line it still uses geared transmissions. I don't know how much of that is for feel vs power, but I have heard of power limitations on CVT as well.
  16. Trollbait
    12,484
    And Ford maybe looking at eventual use in trucks. Nissan is the only manufacturer with a CVT in a 'truck', but I don't think many consider it for a towing or even work vehicle.
