Floor Mat Keeps Kicking Up
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bluewhale, Jul 7, 2011.
  1. bluewhale
    bluewhale New Member
    24
    Bay Area, California
    For some reason my drivers side floor mat/carpet keeps kicking itself loose of the two hooks there to keep it in line. Then it moves quickly forward to stuff itself under the pedals.
    The dealer indicated he had not seen this problem and didn't really have a suggestion. Has anybody here encountered it?
    Thanks
    Paul
  2. hpartsch
    hpartsch Member
    102
    pa
    My 05 does the same thing... The dealer told me the same thing....
    I think toyota needs to re-engineer their mats + hooks.
  3. tomtomsf
    tomtomsf Junior Member
    36
    Half Moon Bay
    My front passenger seat mat moves a lot all the time. Fortunately, my drivers side mat stays put pretty well. The mats stayed put in my previous cars (Nissan, Honda). Honestly, Toyota, seat mat technology is not rocket science.
    Tom G.
  4. bisco
    52,417
    if you cannot secure the mat, (wire ties?) remove it so it does not create a safety issue.
  5. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Check to see if you have something under the mat. Mine never moves.
  6. bluewhale
    24
    No, nothing under mats. Per the dealer they and the hooks look fine. must be my foot movement. I agree with Bisco: if I can't secure the little bugger is has to go. But I would much rather secure it than go without. I'll keep asking for a bit.
    Thanks for the feedback to all.
    Paul
  7. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    I am not sure which floor mat you have. I have one of the al-weather mats, and it does not budge. I
    You might want to try temporarily removing the mat and coating the underside with a non-skid substance, like silicone. Re-install it and see what happens.
  8. Den49
    Den49 Member
    498
    272
    Maryland
    Suggestion: Try sticking a few pieces of the loop side of velcro under the floor mat. The loops will grab the carpet and keep the mat from moving and coming off the hooks. Use the industrial strength velcro (Walmart), not the general sewing variety. Also, be sure you are pushing the mat down and onto the base of the hooks and not just loosely over the hooks.
  9. bluewhale
    24
    Velcro was what I was trying to think of. Ordering some now.
    Thanks Den49!
  10. jim256
    jim256 Member
    317
    69
    Eastern NC
    If the velcro is not strong enough to keep them in place, you might try appropriately long zip ties. When Lexus first had the accelerator recall, they put zip ties throught the mat holes and looped them around a horizontal bar on the seat understructure. That was the interim fix until the new accelerator pedals were available.
    I haven't had any issues with my mats coming off the hooks, in fact it's even hard to get them off for vacuuming, but the zip ties might be another option.
  11. Insight-I Owner
    Insight-I Owner 2006 Insight-I MT + 2011 Prius
    505
    100
    Essex, CT
    Weird, I couldn't get my factory mats to UNHOOK from the floor hooks.
    Why not simply replace the factory mats with a set of Weathertech liners? They give far more protection than the factory mats, clip down easily, and their shape also helps hold them in place (I can't see ANY way they'd scrunch up under the pedals):
    WeatherTech Automotive Accessories - FloorLiner
    I got just the front liners, plus a cargo area liner (I have a dog). Made in the USA.
    Husky makes even more weatherproof liners, but you live in the Bay area, so you would probably be fine with the Weathertech.
  12. richard schumacher
    7,666
    1,047
    United States
    Ditto the weird; it's difficult to get mine unhooked. Does the mat come free from the hooks, or do the hooks come free from the floor? Can you have another dealer check them, or post a photo? Maybe the dealer gave you the wrong ones and is playing dumb (which would be really dumb, as his liability in case of an accident would be expensive).
  13. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I agree with the two previous posts, mine is very difficult to remove and could never come loose by itself.
    If it were me I would go to the dealer and compare the mat and hook set up with some of the new cars on the lot. I think something must be wrong somewhere.
  14. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Agreed. I struggle to remove mine.
  15. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    If it keeps kicking up, something isn't installed right.
  16. fuzzy1
    10,603
    Like several other GenIII owners, I have extreme difficulty unhooking them for cleaning. Near all the dirt gets dumped -- inside the car -- before the mat gets unhooked.
  17. Insight-I Owner
    505
    100
    Essex, CT
    As I said, I simply avoided the whole issue by buying aftermarket floor liners. They cover the floor much better, catch almost ALL of the grunge, are FAR easier to empty and dump the dirt, and can easily be rinsed off. Just wish I hadn't been forced to spend $200 for the OEM set when I bought the car!!!!
  18. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    For winter I bought an "el cheapo" rubber floormat from Walmart, used my driver's side factory mat as a pattern and attacked it with a box cutter (including the holes for the clips). In spring I took it outside and hosed it off. I'm leaving it in because it's so easy to clean. Just like the carpeted Prius mat it doesn't move at all.
  19. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    It's not that difficult to unhook the factory mats if you know a trick. Simply place one hand below the mat where the hook is, one at a time, and push the hook inward toward the eye using your other hand while lifting (toward the contour of the hook). Pretty easy to do once you get the hang of it.
  20. duffasaurus
    duffasaurus Senior Member
    177
    Charlotte, NC
    My floor maps are also rock solid and never move an inch. I prefer the carpeted mats, even though they wear out quickly near where the heel contacts the mat. Yes, the Weathertech mats offer better protection and last very long. That's my opinion and I'm sticking to it!:)
