Driving Down a Mountain
Discussion in 'Gen 2 Prius Main Forum' started by Aaron, Jul 12, 2011.
  1. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Took my 2008 Prius down a huge mountain for the first time yesterday and noticed something strange. While applying the brake my ScanGauge would only read a 83% max charge level even though I was applying the brake well beyond when it reached 83%.
    Also, once I was at max charge for quite awhile (and still pressing on the brake peddle) my Prius started increasing its RPMs on it own and the charge level started to drop. It's like my car didn't like being fully charged and decided on it's own to go back down to 62%. Normal?
    I thought by the time I got down the mountain I would have a fully charged battery, but this was not the case.
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    do not know. Wonder if you went down the same steep mountain I did (Rt 40 in PA westbound). What I noticed was after the battery went all-green, there was subtle increased noise. I took this to mean once the battery was charged, some change happens. I probably should have gone to B mode, from reading posts.
  3. Aaron
    Aaron Member
    260
    Monroe, Ohio
    I was going 55 MPH....too fast for B mode:)
  4. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Me too 55 MPH, but I was thinking you can do 55 in B. My mountain was really steep.
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    Santa Fe, NM
    You cannot "fully" charge the HV battery. The normal SOC range is 40%-80%. The engine RPMs went up because the car was using the HV battery to spin the engine. At this point, all, or almost all braking would have been hydraulic.
    Next time use B.
  6. F8L
    19,011
    4,083
    Grass Valley, CA.
    I wouldn't worry about it. You were not using any extra fuel while the engine rev'd up and your battery was as full as it was going to get. It is weird to experience it though it is by design. It's only happened to me 4 or 5 times. :)
  7. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    Why do you think 55 MPH is too fast for B mode? I'm pretty sure B mode works all the way up to 110 MPH.
  8. Aaron
    Aaron Member
    260
    Monroe, Ohio
    How fast can I go in "B"? Could I blow the engine?
  9. fuzzy1
    10,675
    I can speak only for GenIII, but B mode doesn't have a speed limit, at least within the speed range I use. If B mode gives too much braking, then (1) the 'mountain' isn't very steep, and (2) press the gas pedal very lightly to reduce the degree of engine braking, adjusting it to the amount you want.
  10. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Nice. I was under the impression that if I was going too fast downhill I could damage the engine.
  11. fuzzy1
    10,675
    While I don't like the screaming jet engine howl of the ICE spinning at 4500 RPM in braking mode, it shouldn't be any worse than spinning it that fast while burning fuel to climb the hill.
  12. Aaron
    Aaron Member
    260
    Monroe, Ohio
    The climb was quite something. Fully loaded with 5 people and gear. 96 F outside. Water temp got to 210 F. The ICE was screaming! But she performed like a champ. It's the hardest I've ran this car. Just turned 60K miles.
  13. SpikeVFR
    SpikeVFR New Member
    221
    SF Bay area, CA
    Uhhh, why would you say that? I have been in B mode to at least about 75-80 MPH - if the hill is steep enough.
  14. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Yeah, I just realized B is not the equivalent to Low 1, 2, or 3 on a normal car.
  15. Wolfie52
    Wolfie52 Senior "Jr" Member
    143
    124
    No. Carolina
    I was using the B mode at 70-75 MPH this weekend. No problem.
  16. fuzzy1
    10,675
    It is approximately equivalent to a downshift in an old technology car when decelerating. When applying power to maintain or increase speed, it doesn't really do anything.
  17. qbee42
    3,081
    Around 140 mph, but only if dropped from a helicopter.
  18. Aaron
    Aaron Member
    260
    Monroe, Ohio
    So THATS the Prius terminal velocity!
  19. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    [ame="http://www.youtube.com/watch?v=fIF9ys-hJn0"]‪MGB parachute advertisement‬‏ - YouTube[/ame]
    Darn, I remembered the commercial, but it does not look like the car ever had a chance at terminal velocity. There was a persistent rumor that this was the second drop, the chute did not open the first time. (yes, they needed a second car)
  20. gialia
    gialia New Member
    Greece
    What is the benefit of B mode? I thought that it is only to be used to provide more breaking and not for the whole ride down a mountain.
