Shifting Issue?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by spyderx, Jul 13, 2011.
  1. spyderx
    spyderx Member
    151
    31
    MD, DC
    2014 Prius c
    Have others noticed this on their Gen3 Prius?
    While it is subtle but nevertheless I've noticed there's abrupt transition and feel on highways when it seems like ICE kicks in. This observation is completely new and that's why I'm inquiring. I've not noticed this at all for the first 5k miles until now.
    So, last week I changed oil for the first time at home with Mobil1 0w-20 syn and made sure the dipstick was shown at proper level. I also rotated the tires. Then I proceed on a 700 mile trip. As I was approaching my destination I started to notice this subtle but somewhat jerky transitioning when accelerating moderately.
    Not sure what could be causing this. I don't think it's the CVT transmission... Should I change out the oil to stock non-syn?
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    It has nothing to do with oil, Mobil 1 0W20 is fine and is what a lot of us use. I think what you feel is normal but no one can be sure without driving your car. Why no go to a dealer and take a test drive in another Prius and see how it feels to you.
  3. spyderx
    spyderx Member
    151
    31
    MD, DC
    2014 Prius c
    I've not noticed this prior to the oil change for the first 5k miles.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I have noticed this as well and just assume it is the components loosening up. When new, it was very smooth but now not so much. Of course this has happened to our Kai van as well over the years.
    Like Tom mentioned, you can always have the dealer look at it... just be prepared for "this is normal" or "this has never happened before".
    You might have them check the transmission/transaxle fluid as well. I guess the Gen IIs had problems with it leaking.?
  5. spyderx
    spyderx Member
    151
    31
    MD, DC
    2014 Prius c
    Only other variable that I could think of is maybe a bad batch of gasoline from my last fillup. So, I just refilled the half empty tank with another brand.
    I can almost guaranty that the dealer will waive it off as "normal". I don't want to waste my time.
  6. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    I get this occasionally sometimes. I honestly wouldn't worry about it. Dealers are assholes, and chances are you're going to be "shewed" away by them. It all depends on how warm the engine is I think - I really don't know. However, sometimes the transition from electric to ICE power is a little more noticeable than others. I have 15.5K miles on my car, and this is more noticeable at times than others. I say just drive the car and enjoy it, if something is to go wrong - you've got the warranty to get it fixed.
  7. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Is the 'jolt' or 'transition' at about 45 mph?
    If so it's something to do with the switching between the two motor/generators. I believe the engine also comes on after this transition but doesn't necessarily use any fuel.
    I'm sure others will explain this in more detail.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ that is correct GC. The engine has to spin above 46mph to keep the MG from over-spinning.
  9. LulzChicken
    791
    135
    Alabama
    Yep, this speed is 43mph from what I can tell I always feel a slight jolt.
  10. spyderx
    spyderx Member
    151
    31
    MD, DC
    2014 Prius c
    So is this jolt normal? I'm not liking it!
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    When my prius was new, I could hardly detect it, now I can. Normal? <shrug>
  12. socratesthecabdriver
    283
    31
    greece
    I love it when i feel the yank the electric engine generates !!!!!
    I actually gotten 3.8 litters at 210 kilometers on a relaxed saturday workday !!
    The prius is like thi chi !!!! Go with the flow be one with the force !!!
    Enjoy the ride !!!! Zzzzzzzzzzzen
  13. qbee42
    3,079
    It's not the CVT, as the Prius never shifts gears. It only has one physical gear ratio, and those gears are always engaged.
  14. fuzzy1
    10,372
    I do feel a transition occasionally. Sometimes it happens when gliding up through 46 mph and the ICE spins up but doesn't fire up. Sometimes it happens at lower speed when thrust is needed and it really does fire.
    But it did this from the start, and I haven't noticed any change over 29k miles.
  15. PaJa
    PaJa Senior member
    678
    114
    92
    Czech republic
    I'm sure you know it, but ...
    Actually it is not a gear transition, but you feel a quick MG2 and ICE rotation leveraging at 46 mph/70 kmh. I think it has something to do with MG2 rotation limit.
  16. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Depends if it is a jolt or a 'transition'. If it's a big bad clunking jolt then it's not right and needs looking at. If it's a transition then it is much more gentle than most automatic transmissions and is perfectly normal.
    With the Prius you get one transition or 'change' but with automatics you'll get 3, 4 or 5. I know which one I prefer.
    (note - I am aware the Prius doesn't change gear as such but this 'movement' is a transition when the engine is run at 43-45 mph and is similar in feel to a gear change on an automatic)
  17. qbee42
    3,079
    The limit is with MG1, not MG2. MG1 must spin backward to keep the ICE stationary. As the speed of the car increases, the rotating speed of MG1 must increase to compensate. Eventually it reaches its limit and must spin the ICE.
  18. ctrlaltf
    ctrlaltf New Member
    Puerto Rico
    I had a similar experience with the car shifting gears as I transitioned from going uphill to going downhill. As started going downhill on a steep road, suddenly the car lurched forward.Could be mildly dangerous. Luckily I was riding the brake.
  19. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    But this is a Prius forum and I am guessing you don't have a Prius as the Prius doesn't have any gears to shift so would be unable to lurch.
    Mildly dangerous? Impossible. :D
  20. qbee42
    3,079
    What type of car? The Prius doesn't shift gears.
