need help hv battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by no trust, Jul 13, 2011.
  1. no trust
    no trust Junior Member
    46
    Powhatan, VA
    I had the 12v battery replaced 11-10 . 2 weeks ago warning lights came on ,the first thing i checked was the 12v battery & found that the positive terminal was siting on top of the post. So i reconected it lights went out . Drove the car maybe 100 miles lights came back on ,checked voltage at battery 12.5v trickle charged over night re connected battery lights cleared drove another 50 miles lights came back on. took car to dealer who replaced battery they load tested said battery is ok cleared codes but 2 codes p3000 ,c1310 would not clear but only check engine light and yellow warning light remained on red triangle went out and car drove normal not in the limp mode. Drove to advance read code p3012 cleared code all lights went out . Drove another 100 miles or so lights came back on. Charging system reads 13.8v inverter coolant pump working . Could the loose battery cable have caused these problems or is my hv battery going bad or computer bad no longer trust the dealers never did can anyone help unclutter my brain?
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    from what i can gather online... p3012 is saying the 12v is weak
    c1310 is a general malfunction in hybrid system
    p3000 DSL Solenoid circuit low
    i'm thinking it's semi the battery problem... just as a random guess. maybe the system was finally balancing out with the 12v and realized there was a problem so a code was flagged.
  3. no trust
    46
    Powhatan, VA
    according to them the p3012 is specific to hv battery cell 2. the car has 131000 miles thanks
  4. northwichita
    481
    102
    29
    Wichita KS
    this matches info in this web page for battery codes.
    http://www.hybrids.ru/PriusNHW20/rm/rm1076e/m_05_0665.pdf
    from same page, trouble areas for p3012 (Battery block 2 becomes weak ) are HV battery assembly, Battery ECU.
    Question for the experts, would a check for corrosion on the relevant terminals be a good idea?
  5. V8Cobrakid
    3,790
    152
    according to this page Here, they were right. other pages point back to low 12v. i figured the japanese one is the most accurate?
  6. no trust
    46
    Powhatan, VA
    so im going to have to take it to another dealer to have it diagnosed unless i open and inspect the battery my self ? I am an electrician but not sure of proper steps to take not to screw up something else!
  7. V8Cobrakid
    3,790
    152
    isn't this what the tech guides from toyota (forget the link) is for? pay a few bucks to get all the info you want in a 24 hour period...
  8. Patrick Wong
    18,200
    6,500
    It does sound like the traction battery has a problem in battery block #2. As previously suggested, you can access repair manual info at techinfo.toyota.com so that you can obtain the process to remove the traction battery including the safety precautions.
    Once you have removed the battery, then you can measure the voltage of each of the 28 modules, and will probably find that module 3 or 4 has a lower voltage compared to the other 27 modules.
    In that case, you can buy a used replacement module via eBay, charge it to a similar voltage as exists on the other modules, and replace the failed module.
    If you decide to do this, you must exert compression pressure on the sides of the module (which has a plastic body) so that it does not expand and blow up while subject to charging voltage.
  9. jdenenberg
    jdenenberg EE Professor
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I have some fully charged and rebalanced Gen2 modules that I am selling for $30 each (plus shipping). All of them measure at better than their 6.5 amp-hour rating. He can slowly discharge one to the same voltage as the others with a digital voltmeter and a 10 ohm, 10 watt power resistor. As an electrician, he should know to be careful around the high voltages of a Prius battery. Once the front bus bars are removed, all voltages are below 16v and are safe.
    JeffD
  10. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    You aren't the only electrician to have repaired their hybrid battery. There was a guy in SoCal that did it last year on a Gen I, just replacing a bad module. The repair is akin to replacing a bad circuit breaker in a large panel.
    The bad module will be obvious -- it will be over 1.2V less than every other module. Buy two modules from JeffD -- always replace the block pair, rather than the individual module. The non-failed module in the bad block has probably been overcharged several times, due to the car trying to maintain balance in the string, and is probably weaker than the rest of the string.
    There are some threads here on rebuilding 2001-2003 batteries, which are similar to 2004-2009, just larger. http://priuschat.com/forums/generation-1-prius-discussion/84017-nhw11-traction-battery-autopsy.html
    If you buy the Bentley manual for Prius on Amazon, you should be all set, as far as general safety information, codes, etc.
  11. no trust
    46
    Powhatan, VA
    ok went on techinfo pulled battery checked cell voltage all between 7.9 & 7.86v
    but all negative terminals are slightly powdery and alot of dog hair between cells going to clean all terminals and vacume out dog hair (two chocolate labs) and try battery again. also willcheck cooling fan for hair although i know it runs. What do you all think? Does anyone know what the torque spec is for the cell terminals?
  12. seilerts
    3,326
    1,518
    Santa Fe, NM
    Sounds like a good plan. Torque spec is 48 in-lb. A good approximation to that very low level of torque is a good twist with a nut driver.
  13. no trust
    46
    Powhatan, VA
    Is it possible my problem is that simple ? I guess ill find out !
  14. seilerts
    3,326
    1,518
    Santa Fe, NM
    Pay very, very close attention to all of the sense wire connectors. Sometimes, those break or have high resistance, which shows up as a bad block. I have to wonder how many of the battery bad block DTCs that result in battery replacement are just broken/bad sense wires.
  15. no trust
    46
    Powhatan, VA
    ok I took a sewing needle and taped it to the lead on my fluke meter pulled the sense wire conector out of the ecu and tested each wire all good, that was after cleaning the terminals with white vinegar. Thanks for staying tuned in!
  16. no trust
    46
    Powhatan, VA
    Has any one used no ox on the terminals ? Will that and heat or resistance,one in the same, or am i over thinking it?
  17. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Hi no trust. Is there any chance you could snap some photos of the dog hair in the battery or have you already cleaned it?
    I've had to clean a lot of dog hair out of the battery cooling fan on my Prius and I've long been a bit suspicious that my HV battery might be similarly clogged. The fan itself is much easier to access than the battery box, but it looks like I'll have to bite the bullet and disassemble the whole battery box for cleaning come summer.
  18. no trust
    46
    Powhatan, VA
    I have already cleaned it but I havent been in the fan yet. I would clean the battery for sure! You can clean it with it still in the car . At the bottom of the battery where the cooling duct hooks up shine a bright flashlight when its clean you can see light through the top between the cells.
  19. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Thanks notrust. Yeah I haven't had the back seat out yet so I've got to figure that out first. When I cleaned the blower fan I did initially try to get into the battery box, took out a whole bunch of bolts etc, but I still couldn't get it opened and I eventually gave up. Next time I'll get the back seat out first and try again.
  20. Patrick Wong
    18,200
    6,500
    After you are done cleaning up the battery module terminals, I suggest that if possible, you attach a load to the battery to draw a moderate current, like six 100W light bulbs connected so that they can withstand ~220VDC without burning up. For example, three parallel strings of two bulbs in series will draw ~3A.
    While the battery is under load, measure the voltages at each module and see if they are still closely synchronized, or if you can find a module whose voltage is below the others. It would be easier to find the faulty module now, rather than wait until you've put everything back together only to find that you are getting the same warning lights.
    Tuner wannabe likes this.
