12V Battery Stats: Should I Replace?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Aaron, Jul 14, 2011.
  1. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Got the following voltage data. The car has been sitting for approx 18 hours:
    12.3 - accessory mode (nothing on)
    11.7- lights on
    11.4- rear window heater on
    11.1- lights & rear window heater on together
    Was reading the voltage should be between 12.6 and 11.9, so at 12.3 I guess I'm doing OK. Right?:confused:
  2. jdenenberg
    jdenenberg EE Professor
    3,957
    1,955
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It's not in terrible shape. Did you drive short trips or long ones before your Prius sat idle? If short trips, then your 12v just is not fully charged. If long trips, keep an eye on the battery as it is showing some weakness.
    JeffD
  3. Aaron
    Aaron Member
    260
    Monroe, Ohio
    I just got back from a 330 mile trip without stopping.
    Will charging my cellphone while driving shorten the life of the 12V?
  4. jdenenberg
    3,957
    1,955
    Trumbull, CT
    2020 Prius
    LE AWD-e
    So just keep an eye on the battery.
    No, the charging system can supply up to about 100 amps for accessories without problems (except for a drop in MPG to supply the energy, about 1 MPG lost for each 10 amp of current load).
    JeffD
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Quick question, where did you measure the voltage? If by chance you read this on the screen in Service Mode, I would recommend reading it with a DVM right at the battery terminals or at least on the jump terminals in the engine fuse box. I read a difference of -0.7V on the Service Screen versus with a DVM right at the battery terminals.
  6. Aaron
    Aaron Member
    260
    Monroe, Ohio
    I read it in Service Mode and on my ScanGauge.
  7. dureel
    dureel New Member
    NYC
    How do you get voltage data? (sorry for being such a newb)
  8. F8L
    19,011
    4,083
    Grass Valley, CA.
    The best way is to have the vehicle shut down for 6+hours then use a digital volt meter to measure voltage at the battery terminals.
