Turn signals are now parking lights / DRL's - parking lights are turn signals (MB/Audi style)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by SDM44, Jun 20, 2011.
  1. waiwaiet
    waiwaiet New Member
    47
    Rogers, AR
    Now this is weird....eveythig works fine now...anyone got any idea on what's going on? Sometimes it doesn't work at all but sometimes it does
  2. CHIZELD
    CHIZELD New Member
    64
    @ Your Lady's House
    Looks sweet!
  3. XMAN LIVE
    XMAN LIVE "Just have Fun!"
    271
    49
    Cypress TX
    Can someone post picture of flasher unit under dash... so I can see what I need to replace... thanks
    I guess I will ask does anyone have a idea on waht wire to use as IGN wire that goes to +12V when the car is in RUN mode for the DRL-2P that is located under the hood?
    FYI on some questions I asked:
    ----- Forwarded Message -----
    Sent: Saturday, September 17, 2011 2:59 PM
    Subject: RE: Question on compatibility
    All items will work on your car. The DRL-2P is designed for the 04-09
    Prius, but it will work on the 2010 and newer cars. The instructions are
    for the 04-09, so you will have to ID the correct wires. The turn signal,
    ground and marker light wires are easy to find. You will have to find an
    IGN wire that goes to +12V when the car is in RUN mode. $39.95
    The OTS-1T is a plug-in device that replaces the turn signal flasher.
    $49.95
    The BLP-1 is a splice-in brake light pulser that will work on all cars.
    $35.
    Let me know if you have any other questions.
    -L
    http://www.webelectricproducts.com/products.htm
    -----Original Message-----
    Sent: Saturday, September 17, 2011 9:43 AM
    To: [email protected]
    Subject: Question on compatibility
    I am thinking of using 3 products.... I have a 2010 Prius V w/ATP...
    Like to use the below products. Can you advice if any will work.... and what
    model to order and cost...
    One touch Turn Signals
    Brake Light Pulser
    Daytime Running Lights
    Regards,
    Bruce
  4. XMAN LIVE
    271
    49
    Cypress TX
    Where did you get projector style LED? Can I order a pair? How much
    Cproaudio posted picture of flasher unit:
