64 MPG in Denver
Discussion in 'Gen 3 Prius Fuel Economy' started by Rodj, Jul 16, 2011.
  1. Rodj
    Rodj New Member
    Denver
    I drive 30 minutes each way to and from work. I have seen 64.2 mpg but with the ac on i am getting 63.9. all i have done is put nitogen in the tires and try to run on battery as much as possible. the highest posted speed limit is 40 miles per hour which appears to me to be the sweet spot for the prius. I didn't expect to see 60mpg so i am very happy with the 2010. the best i did on my 2007 prius was 54mpg driving the same route.
  2. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    Woah, that's really really good. Congratulations on your accomplishments. Also, that mileage for your 2007 is extremely well indeed. Was this the MPG you calculated at the pump? Or off of the display? The display tends to read a little high than the actual numbers you are getting. Either way, great work.
  3. Rodj
    Rodj New Member
    Denver
    i used the dash reading. i understand that its alittle high but in the long run for a difference of 2 mpg it's easier to use the dash you still get feed back on your prius driving skills.
  4. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    The dash MPG is off by a percentage not by 2 or 3 or 4 mpg. It may seem like it's off by a few mpg when your average is 50-60mpg. Those with PHEV kit that regularly get 99.9mpg see difference as much as 8 or 9 mpg off.
  5. bisco
    51,781
    it's the nitrogen. probably the greatest advance inmpg's in the history of mpg advances. and it's CHEAP!
  6. LulzChicken
    791
    135
    Alabama
    How can pure nitrogen in the tires help fuel economy? Isn't Nitrogen in 74%~ of the air already? As long as your pressure is always maintained, how does it help so much? Where can I get pure nitrogen in my tires?
  7. bisco
    51,781
    most everybody is offering it these days.
  8. LulzChicken
    791
    135
    Alabama
    Alright, but what makes it so good? Besides the fact that my tires may maintain the proper pressures longer?
  9. cproaudio
    2,401
    762
    CA
    I saw a video somewhere explaining why pure nitrogen is recommended. If you use regular compressor, there's water build up that'll get pumped into the tire. The water will rust and damage the TPMS sensor. Tires pumped with nitrogen won't have this problem.
  10. tjeeper
    tjeeper New Member
    UT
    I regularly get 62 mpg on my daily drive, best is 67. That's with or without AC, doesn't seem to effect my mileage.
    I've always gotten better than the EPA mileage with my vehicles. I attributed it to the altitude, less O2 means vehicles use less gas. But, what do I know? :)
  11. fuzzy1
    10,385
    Running on battery as much as possible is generally not a good strategy, as it involves multiple energy conversion losses. A Pulse & Glide pattern with minimum battery use will usually do better -- pulse on the gas engine to bring the car up to speed, then coast unpowered a while with the HSI bar at or near zero.
    In the real world, terrain and traffic may call for more electric assist to extend some glides to better fit the situation. But don't spend a significant fraction of your driving time with the HSI bar showing strong electric-only propulsion.
    Your maximum speed limit of 40 fits very well with Pulse & Glide, which is especially effective in GenIII at and below 45 mph, after the engine warms to operating temperature. Without AC or long steep downhills, 70 mpg (displayed) should be within reach.
  12. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    Nothing ... he's kidding ....
    REV
  13. Gary Otto
    Gary Otto Member
    123
    Silver Springs, FL
    Actually..I believe it is the air, or lack of, that accounts for increased mileage at high altitudes. Modern fuel injected motors automatically lean the fuel/air mixture at higher altitudes. Less air means less fuel used.
    I had noticed a gradual increse in fuel economy (in a Toyota powered RV) heading west from Florida until I reached the continental divide, then once on the western side the fuel economy returned to normal.
  14. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    we are getting 58-62 at sea level with A/C use, so yours b/c of the higher altitude?
    the trick with A/C to set it to highest possible temps (85 or external, whichever lower), recirculate and run fan at ~35-40%. This actually produces better MPG then open windows at above 50MPH
  15. fuzzy1
    10,385
    Modern fuel injected engines should run a constant air/fuel mixture, regardless of altitude.
    Thinner air helps two ways at on pre-hybrids: Less air drag on the highway, and less part-throttle pumping loss in the engine, due to lower intake vacuum. Hybrids with Atkinson cycle engines have much less of the later, so should get less improvement at high altitude.
