prius just dropped mpg....what the?
Discussion in 'Gen 2 Prius Fuel Economy' started by 05azprius, Jul 17, 2011.
  1. 05azprius
    05azprius New Member
    83
    phoenix
    ok this is worrying me and irritating me.
    i bought my prius about... 3-4 months ago? it was wrecked and i fixed it (front right suspension/fender), i put... about 11000 miles on it already. i did oil change, air filter, new tires, etc... all the basics. i was getting 42mpg with a/c on in town, and about 47 on the highway. i took it on a trip to oregon, and then back down the coast and home, i averaged 37mpg (it was loaded with 5 people, and full of luggage, i did 5mph over posted speed limit the whole way so 75-80, a/c blasting the whole way). i figured the loaded down aspect was the reasoning for the low mpg, however i've been home and run 600 miles through it, and i'm averaging 32mpg last tank, and 36mpg this tank. also when i'm driving, if i turn off everything (a/c, radio, etc...) and listen down by the center of the car in the middle i swear i can hear a metallic sound....however outside the vehicle there are no audible noises...
    any ideas? anything to try? this is seriously pissing me off.
  2. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Dumb question: have you checked the 12V battery?
    Now where's that standard list of low mileage questions...
  3. 05azprius
    83
    phoenix
    it's a brand new optima, put in the same time as everything else mentioned above.
  4. jdenenberg
    jdenenberg EE Professor
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    What tires/tire pressure?
    JeffD
  5. 05azprius
    83
    phoenix
    whatever discount tire sold me, pressure is still at what they put it at, seems a moot point since nothing has changed with the cars configuration since before i left on my trip (aside from my mpg)
  6. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    Does the engine run all the time? Have you noticed any change in the frequency by which you are traveling forward on battery only?
    Even though the Optima is new, it is important to check its voltage and connections just to rule it out as a possible cause.
  7. ItsNotAboutTheMoney
    2,287
    460
    Maine
  8. 05azprius
    83
    phoenix
    i'll check the 12v for the hell of it but it's literally 2 months old so i'm not expecting to find issue there.
    i seem to possibly travel on battery less than before.
  9. 05azprius
    83
    phoenix
    - Have you read This Thead Yet?
    Yes, i know how to drive the #@$% car.
    - What fuel economy are you getting and how are you determining fuel economy? (trip computer or manual calculations)
    32mpg last tank, 36 thus far this tank (trip computer)
    - What fuel economy are you expecting and why?
    40-42 in mixed driving, because i was getting that prior to taking the car on a 4000 mile trip
    - What are the approximate outside air temps?
    HOT, 110-140
    - How long are your trips?
    10-40 miles
    - How much of it is city vs. highway? Roughly what's the average speed in overall and and of each segment? Is there a lot of stop and go driving?
    70% city, 30% highway, average speed... 30mph averaged, some stop and go, i try to time the lights
    - What region/state are you in? (if you haven't set your location in your profile)
    Hell (phoenix, az)
    - What's the terrain like of your drives? (e.g. flat, gentle hills, steep hills, etc.)
    flat
    - Is your oil overfilled? (i.e. above the full mark on the dipstick)
    no
    How old is your 12v battery? What is the voltage reading of your 12v battery after sitting over night? (Method Here)
    brand new optima
    Have you had your alignment checked? Any pulling or abnormal tire wear?
    alignment done 3 months ago with new tires
    - Are you using the factory tires and wheels? If not, please indicate tire make, model and size (e.g. Goodyear Assurance Fuel Max 185/65R15).
    factory wheels, different tires, but my above mpg were on these tires.
    - What are your tire pressures?
    whatever discount tire set them at, and same as they were when i got the previous mpg.
    - Make, model, year, engine and transmission of previous car? (e.g. 08 Honda Civic Si 2.0L 4 cylinder, manual transmission) What did you actually get on the same trips/commute? (Please give us actual numbers, not EPA ratings.)
    '91 acura NSX, why's it matter. i've had 100's of vehicles.
    - How are you trying to drive (e.g. trying to stay in electric only?) and how hard are you braking?
    properly.
    - Are you "warming up" the ICE (internal combustion engine) by letting it idle after powering on?
    sometimes.
    - Are you driving using D or B mode?
    D obviously
    - HVAC settings? Are you using the heater, AC, auto mode, etc.? If using auto, what temp is it set to?
    a/c, 72 typically
    - If reporting a mileage drop, did anything significant change on your car (e.g. accident, hit a curb or big pothole throwing off alignment, oil change/other maintenance/repairs, changed tires or wheels, etc.) or your commute?
    No, nothing aside from taking it on a rather long trip to oregon and back.
  10. seilerts
    3,326
    1,518
    Santa Fe, NM
    I meant to ask, do you hear the battery fan running, it is behind the little duct in the rear seat passenger side. If your HV battery is chronically hot (in PHX, I think that could happen), then regen is somewhat inhibited and fuel economy will decline.
    We are here to help. The Prius is one of the most difficult cars on the road to troubleshoot if there is a problem without trouble codes. Please do not be offended if we ask you for information that appears to insult your intelligence.
    Such as, please do measure your tire pressures. Please do measure the voltage on your new battery. Please do let us know what the actual numbers are, rather than "tire pressure and battery voltage are okay." 12.0V is actually a bad sign, it should measure >12.4V with the car off. We are scientists and engineers here and live and die by the numbers.
    But there is a possibility that something happened on your trip to OR, such as suspension damage due to hitting a hard bump with a fully loaded car. There is the metallic noise that you mentioned as well. The thing to do it get the car up on jack stands or a lift, to inspect the undercarriage and make sure that all wheels are turning freely. Check the level and condition of the hybrid transaxle fluid while you are down there.
  11. Patrick Wong
    18,200
    6,500
    1. How do you know that a tire didn't incur minor damage during your road trip, so that it is now leaking air; if you don't bother to check tire inflation pressures?
    That should be the first item on your list to verify. Since you don't seem to have a preferred tire pressure, may I suggest you use 44/42 psi for front/rear.
    2. What is the condition of your air conditioning system? Was any component damaged in the accident?
    Is it possible that the AC system is not working efficiently so that the AC compressor is running constantly, thus negatively impacting your mpg in the hot Phoenix weather?
  12. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    you were fully loaded though... 5 people and cargo.. expect reduced mpg.
    my brother and I with bikes and camping gear only averaged around 35mpg or so on a long distance travel to colorado and back.
    weight is a huge issue with this car vs mpg.
    after any long trips with a lot of weight, check your oil.
    also.. the car kinda logs and bases itself upon your driving habbits. if you are loaded down and pulling a lot of weight, it tends to torque itself out more.. once it's just you again, it kinda has to adjust to that light load/less torque requirement.
    it's said (back in 05 or so) that if you reset the car by unplugging the 12v.. everything goes back to standard and you can kinda re train the car based off your driving conditions.
    (don't ask for details.. this is years of casual chatting among people here)
    plus.. a full load and anything over 65mph will get you poor mpgs... even if the speed limits are higher.. expect a reduced mpg.
    since you were in a front end collision, you might want to have your inverter pump checked (or check yourself by visual turbulance) and have your normal water pump checked.. it's not in the front or too out in the open where an impact will literally hit it.. but after my front end accident, mine sounded funny and wasn't acting right, so the repair shop replaced it. (they claimed it as being on the front of the engine.. but didn't tell the insurance the front of the engine was actually to the side of the car)
    now... the only flaw i saw in your own personal spec/answer sheet above is that you let the car warmup before going... you're not supposed to do this as all it really does is drain the HV battery which you'll have to make up after the car fully warms up... so.. the 1st mile or so will definitely be poor mpgs. (it all adds up)
    i pull trailers.. am agressive with my accelerations... love speeding through mountain passes... i average around 40... pulling any weight, it drops to 37 or so. (i'm extremely mild when pulling a trailer.. i coast a lot more than when i'm solo)
  13. 05azprius
    83
    phoenix
    ok, 12.7v on the 12v battery, and the discount tire paperwork says inflated to 33psi, my gauge says 32-33 (hard to tell the difference in 1 psi on an analog gauge) i've looked underneath and found nothing damaged, also put it on jack stands and the wheels seems to spin ok. are there any common occurrences of bearings going bad in the transmission? also the transaxle fluid is full.
  14. 05azprius
    83
    phoenix
    1. because it is aired up properly and i didn't hit anything. they have 32-33psi in them front to back. and while i understand running a higher psi seems to give the prius better mpg, keep in mind this is the same psi i was at when i got previous numbers, so while that may yield an improvement, it's not the source of issue.
    2. works fine, charge is within factory parameters.
  15. 05azprius
    83
    phoenix
    I specifically stated that i expected a lower mpg on the trip, my issue has nothing to do with my mpg on my trip.
    oil is good
    you sure? i've not heard of such a thing (that doesn't mean anything beyond, i haven't heard of such a thing)
    you seem to be stuck on the mpg on my trip, which i was not complaining about.
    for reference i have been an ASE certified mechanic since i was 22...i've also taken master classes in collision repair. so the front end was repaired properly (and i know that for a fact, not because a "mechanic" told me such). inverter pump was replaced under warranty, waterpump is fine.
    granted i'm aware that that'll hurt my mpg mildly but over a 300+ mile average, this is not going to account for much.
    i live in phoenix, everything is flat and boring. the only excitement is the ignorant drivers you have to constantly avoid.
  16. seilerts
    3,326
    1,518
    Santa Fe, NM
    Usually, the only simple problem with the transaxle is an axle seal. Bigger problems would throw codes and the car is not drivable.
    Do you have access to Techstream or a Toyota-enhanced scan tool? Next step is to watch the activity between the inverter and battery to make sure that regen is not inhibited, and keep an eye on hv battery temperature and battery fan voltage. As a rule of thumb, any time you can hear the fan running on high, regen is reduced dramatically, and you now are driving a Yaris equivalent.
  17. 05azprius
    83
    phoenix
    oh in reply to your previous question i initially missed, i have noticed the battery cooling fan running a bit more than usual.
    i do not have access to any toyota specific diagnostic equipment. the car only has 92k miles, if it weren't salvage it would be real nice to just drop it off and let the dealer fix it under warranty :(
    i honestly think the issue is the noise i'm hearing (and the drag that would be created due to whatever the noise is). although oddly enough today there were a couple times where i was suddenly going from 38mpg, to 52-55 on the trip computer (as i usually would on the freeway), then it would kick back down (not a/c related however).
    i'm really thinking about just adding up what i have into it and trying to break even on it.
  18. seilerts
    3,326
    1,518
    Santa Fe, NM
    99% sure that explains it. If you can hear the fan running, that means that the battery is HOT, and regen is inhibited. Hang on to it until winter and then sell it.
  19. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I would buy a can of MAF cleaner and spray off the air flow sensor. I just did that on my wife's 08 Prius. She was down to 36 mpg in short hop city driving. The last 80 miles was at 43 mpg so it looks like it helped. Just search PriusChat for instructions.
  20. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I have to ask...reading your signature I take it you purchased this Prius with a salvaged title?
    Thus the damage you describe happened before your ownership?
    If you are dealing with a vehicle wrecked and repaired before your ownership any degree of potential problems might be rearing their ugly heads. Especially if the original damage is reportedly front end and suspension related.
    The benefit of purchasing a salvage title is cheaper initial buy in...the risk is strange minor to major problems manifesting with ownership...
    Good Luck, I'd say the positive sign is that by your definition the MPG's seem to have suddenly dropped...which I would speculate means some singular failure or event has caused the problem...thus it's not something that existed since you purchased your vehicle...
    Again good luck, and I hope you can find out what has caused your sudden decline in fuel efficiency and I hope it isn't a major repair.
