Tap dancing your way to 100 mpg in your Prius...
Discussion in 'Newbie Forum' started by Jaquimo, Jul 18, 2011.
  1. Jaquimo
    Jaquimo Paraglider, Prius glider...
    96
    Bloemfontein, South Africa
  2. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    OMG!
    I thought I was going crazy but there have been times when I've "tapped" the accelerator and improved my mileage. I never reported it because I figured it was a fluke or assumed it was related to something else. I'm now going to try this for real and see what kind of results I get.
    A Reminder from your friends at Priuschat: Always obey speed limits and traffic laws. Perform special driving techniques only when traffic and the situation allow. Before you attempt any special driving techniques please keep in mind that you are an adult, you are responsible for your own actions and no one, in any way, forced you to do it.
  3. fuzzy1
    10,431
    Is there any confirmation of this at the fuel pump, not just on the display?
    Without confirmation, I think this sounds more like an 'undocumented feature' in the MPG display software. 'Bug', for those outside any computer industry.
    The difference between my displayed MPG and pump MPG has widened significantly over the past two years, and I've been suspecting that increased use of Pulse & Glide, triggering more ICE on/off cycles, may be a factor. The method described here would push this to an extreme. But I haven't put this to any serious test.
    I'd like to hear about any real life test for a whole tank.
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    I agree with you, fuzzy.
    There are times when I am transitioning from a glide to a pulse and the gauge still reads 9999 despite the fact the engine is now on and I'm accelerating. This happens very briefly but do it enough over the life of a full tank and the effect may be higher indicated mpg.
  5. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Bogus yahoo spam adware content for pluginsupply from oct 20, 2010.
    Accumulated rounding error in the mpg calculation displayed.
  6. ccdisce
    ccdisce Active Member
    259
    187
    Stone Mtn GA USA
    Micro Pulse and Glide or Integral Pulse and Glide.
  7. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I'm not buying it until someone using this technique reports miles & gallons pumped.
    BTW, the gap between my MID & calculated FE seems to have dropped from ~7% to ~5%. I don't have an explanation.
