Washed my smart key
Discussion in 'Gen 2 Prius Main Forum' started by skippy911, Jul 19, 2011.
  1. skippy911
    skippy911 New Member
    33
    Georgia
    I washed my bike clothes and found the key at the bottom of the washer. I pressed the buttons and no little red light. I tried replacing the battery same thing. Is my key toast? I tried it in the dashboard and thank god the car started. This is the only key I have btw, can the dealers program a new one with this one key? I have it sitting in a tin of rice and will try it again in the morning. I hope it works as I do not have 250ish lying around which it looks like is the going price for a new key and programming.
  2. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Take the battery out. If there is charge, there is a potential for a short.
    If the car started then the key still has its programming. If you lose the key or it dies, it is a lot more than $250. Between $600 and $900 usually since you have no backup.
    Go get a spare key made. A spare from a working key is much much much cheaper than a new key coding.
  3. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    You can try sticking it in a bag of rice to get rid of all the moisture. Next day replace the battery and try.
  4. Southern Dad
    Southern Dad Active Member
    350
    212
    58
    Monroe, GA
    A two year old decided that all my keys including my Smart Key needed to be inside of the fish tank. I used the rice in the bag trick and two days later my key was fine. Saved me a couple hundred!
  5. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    So did the fish get good mileage when they took the car out for a spin? I have a 2 1/2 and can picture him doing that. Thanks for the laugh this morning. :pound: Glad you key still works
  6. skippy911
    33
    Georgia
    Sniffle, still no dice on the key working. I let it sit all night in a tin of rice and still no light flashing on the key, and it still won't open the car doors. I tried 3 different batteries too. I called 3 toyota dealers this morning and the best price for a new key I got was 218 plus tax, and an extra 30 to program it.
    I found this on ebay, TOYOTA PRIUS Smart Key Keyless Remote MOZB31EG SILVER | eBay
    I asked the dealer and they said they can program it for 30 bucks, is it worth trying that? I would like to spend 85bucks instead of 218 anyday.
  7. skippy911
    33
    Georgia
    Ok now this is crazy, I sprayed compressed air inside the key and the little red light began to flash! I ran out to the car and it stopped working. I then took the air with me, sprayed the key and it kept flashing off and on. I pressed the key and it opened the doors one time, but not again. Any ideas? Is my key beyond screwed?
  8. PriQ
    PriQ CT+iQ
    377
    113
    Europe
    That the car starts is only proof that the RFID chip works. this is separate from the rest of the electronics, which might still be toast.
    Let it dry for some additional days before giving up on it. Replacing/recoding a FOB is quite expensive.
  9. Patrick Wong
    18,210
    6,515
    I believe that it will be a waste of your time and money to buy a used Smart fob, as it is likely that the car's immobilizer and Smart ECUs will not accept its registration.
    Since the fob is working intermittently, I suggest that you open it up again, and leave it under a source of moderate heat for a few hours, like a 100W incandescent bulb. That will give the circuit board a chance to thoroughly dry out. Good luck.
  10. skippy911
    33
    Georgia
    Beyond the price of 218 for a key and 30 for programming what else is included in the "quite expensive", that you stated?
  11. PriQ
    PriQ CT+iQ
    377
    113
    Europe
    218+30 is quite expensive compared to a bag of rice, or the power used to dry it using a light bulb, radiator or similar ;-)
  12. skippy911
    33
    Georgia
    Haha so true so true, I have it disassembled and laying in the dashboard of the car right now, the heat should hopefully dry it up nicely.
  13. PriQ
    PriQ CT+iQ
    377
    113
    Europe
    I am crossing my fingers and hoping for the best. I know from experience that my fob will be getting an unexpected bath sooner or later.
  14. skippy911
    33
    Georgia
    Yah, and the thing that sucks is this is the only key I have for the car :( Bought it used and only had one key, they told me a new key would be about 300 at the time so I said heck no.
  15. uart
    uart Senior Member
    4,220
    1,211
    Australia
    In cases where your accidentally immerse something like this in salt water (or anything that might be either corrosive or cause a residue) then the best thing to do is to wash it thoroughly in clean fresh water and then dry it out again (using the methods listed above in this thread).
  16. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    Santa Fe, NM
    $30 is the cheapest I have ever seen for programming, and $250 out the door for a programmed key is very reasonable. Most dealers charge an hour of labor for a new smart key because it is a two step process. Given that you can start the car, you should be able to have a new smart key programmed without needing a smart ECU seed reset. A seed reset adds as much as $100 to the programming cost due to an additional layer of complexity and getting a new seed from Toyota Corporate.
    Do not buy a used smart key off ebay if you intend to take it to a dealer.
  17. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i did the same thing. i personally dont believe the "bag of rice" being the best option. what i did is diassembled it and sat it on my floor register and ran the heat for a few days.
    that worked, but the battery died about a month later. battery replacement at dealer; about $30...at Batteries Plus; $5.47 after tax. self-installed
  18. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Since it is your only key, don't leave it in the car while drying and lock yourself out.
  19. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Where are you getting immersed in Salt Water? The OP said he left the fob in bike clothes he washed?
    I could hardly recommend thoroughly washing it "again"...dryer is better....if he keeps dunking it in water it's going to be hopeless.
    To the OP? Since it seems to slowly be intermittently working...yeah, I'd just wait a few days...see what happens...
  20. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    If just drying it out and replacing the battery fails, there's still more you could do. Open up the case, remove the circuit board, and spray it with circuit board cleaner (Radio Shack should have some). Be sure the battery connectors are free of corrosion. Then reassemble the case & install a new battery.
    To open the case, first disassemble it down to removing the battery. Insert a pair of needle nose pliers into the space where the mechanical key goes, and spread the case apart. The case should split open along the glue line. The circuit board is jam fit in half the case - remove it by prying with a small screwdriver. Note also the small 1/8" square by 1/2" long chip that is separate from the circuit board. That's the transponder, and it is the functional part when the remote is inserted into the dash slot. Don't lose it...
    You can test the circuit board while it's out by just holding a battery in place and pressing any button switch. If it's working, the red LED will light up.
    Reassemble using a moderate strength glue. I used ordinary white glue, and it came apart after a few months. But if you use too strong a glue, you'll never get it apart again. Don't use epoxy or any instant set glue.
    As for buying a used keyfob, first find some place that can do a seed reset. Some locksmiths have the equipment, and all dealers have it. But the dealers generally don't know (or refuse to admit) how to do it. It requires an extra 16 minute reset of the security computer, plus looking up a seed value on the Toyota website. The mechanic can do something else during the 16 minute delay, but you'll probably get charged for the full time.
    Probably the cheapest replacement keyfob is a used one off eBay ($40 is a good price), and have the car programmed by a locksmith. But find the locksmith with the proper equipment first.
    Next best deal is to purchase a new, never programmed before, keyfob off ebay from a dealer like toyotapartsnow or toyotagreg
    Be sure to get a silver logo keyfob if your car has SKS (don't have to insert the keyfob into the dash to start). You'll also need an uncut mechanical key (most used keyfobs come with a key already cut for somebody else's car...). The only thing special about the mechanical key is that it fits inside the remote. You could also get a $2 copy made on an ordinary key blank anywhere duplicate keys are made.
    The most hassle free way to get a functional keyfob is to go to a dealer and pay their full price. If the first remote that they try doesn't work, they'll just take it back to the parts department and get another. You'll get the one that works. The one that didn't work will probably end up on eBay...
