Left the run all day
Discussion in 'Gen 3 Prius Main Forum' started by Caug1, Jul 20, 2011.
  1. Caug1
    Caug1 Member
    119
    BOSTON
    Hello,
    so i parked the car in garage at my work, but forgot to shot it off, as i found out 8 hours later.
    why wouldn't car shot off? i got the key with me.
    I know it was my fault, but still i wish it could stop with out detecting the key.
    The good thing was that car was nice and cool, since i was using ac.
    The bed thing was that mpgs dropped from 54.4 to 51.
    I was working on my best mpgs so far.
    any feed back would be good.
    Thanks,
    C
    52,405
    car does not shut off unless you push the power button. it should have beeped at you as you closed the door and walked away. what kind of feedback would you like?
  3. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    This is just about all that can be said. Just make sure to turn your car off before you get out. I may have done this once or twice, but when the car beeped at me three times after shutting the door, I realized I did indeed forget to turn the car off. Not much more to say, learning from your mistake is the best way to prevent them in the future. There is always next tank.
  4. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    When the battery in the key fob eventually goes dead, resulting in the key is no longer detected, and you're doing 70 MPH on the freeway, do you really want the car to shut off?
  5. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    It's obvious that you don't lock your doors......if you had try to lock the doors.....the car would of given a long beep.
    Your lucky that someone didn't drive off with your car. Especially in Boston !!!
  6. bisco
    52,405
    especially in boston? ouch!
  7. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Yeah, but he wouldn't have gotten far in Boston traffic. ;)
  8. bisco
    52,405
    can't argue with that. if we ever get back to 'full employment' i don't know how we'll get anywhere. :(
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    exactly. It is good practice to just lock the car when you get out. Even with the car off, if you don't shut a door fully, you will know.
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    This is why I park with the power button. I don't press the Park button but rather the power button... this ensures that I shut off the car.
  11. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Ditto. This makes it far less likely to forget to shut off the car, and pressing the power button automatically puts the car in park.
  12. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    Yep - Yep - Yep!:thumb:
  13. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    Only lost 3mpg running all day.
    Jeez, this guys parking lot stint is more efficient than my commute. :(
  14. ETC(SS)
    7,367
    You mean there's another way you're supposed to do it? :D
    Note for the humor impaired: That was sarcasm.
    Since I have to deal with gates and locks all of the time.....I have to use the Park button much more than I'd like to. However (comma) when I'm PARKED, I usually just hit the power button.
    As others stated......it's a good habit to get into.
