Is this normal?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RL Prius, May 11, 2011.
  1. RL Prius
    RL Prius Junior Member
    77
    Bay area
    I have a 2010 Prius II, 13k miles right now. The problem is when I back up from still and apply brake, I can hear and feel and hear some Clunk noise from the front.
    Is this noise normal??
    Thanks
  2. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    I also hear this.
    I'm thinking it's the brake calipers. This is just my guess but i'm thinking there is a little foward and backwards play in them and it only shows up when backing. mine sounds more like a click than a clunk.
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Mine has done it from new and still does it with no ill effect. I'm at 46k miles now.
  4. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Mine does it also since it was new, as they say, don't worry bout it.
  5. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Mine does it too, but only in the morning after it's been parked all night (garage). I assumed it was moisture or road debris on the rotors/pads from day before. Also, after the Prius is washed and has sat for a while, the noise (grinding) is predominate for the first couple of brake pedal applications. I'm certain it's moisture and not a problem.
    When I back out in the morning, the first thing I do is lightly apply the brakes to clean off the rotor. This also keeps the car from surging when the ICE kicks on.
  6. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Sometimes but not all the time.
    My wife reported the same thing about her Fusion Hybrid and I experienced it.
    I'm not trying to say that it's a hybrid only thing, just that I've experienced it in our other car which happens to also be a hybrid.
  7. ETC(SS)
    7,287
    It's normal...at least for the Prius.
    Remember that when you're backing up, you're not using the engine (at first) and so you're more likely to hear and feel the brake shoes cleaning off the rotors, which will always have a little surface corrosion even after an overnight park. Also, 99+ percent of your braking is done while the car is moving forward. A reverse braking will cause the calipers and other pieces/parts to shift a little bit, which may account for the noise and/or pedal input that you're experiencing.
    I'm not sure if this is exacerbated by the additional regen braking components---but suffice it to say that you don't have to worry about the noise........as long as the car is still stopping normally that is. You're at 13K miles. You're car is still covered by its warranty. If the noise really bothers you then you can take it to the dealership, but I think that they're just going to take it for a short hop (or tell you that they did) and give you more or less the same answer that we did.
    Best of Luck!
  8. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    So from what everyone is saying the answer to your question would be Yes. :D Now go out and enjoy your Prius and stop worrying !
  9. kklin
    kklin New Member
    CA
    My 1-month old Prius does the same thing every time I back off from garage in the morning. Thank for the info.
  10. Canard
    Canard Member
    223
    Ontario, Canada
    I had my car in today to have another rattle investigated, and mentioned the clunking on direction changes. My hybrid tech advised that it was due to the brake pads shifting around in the calipers and was normal. Mine gives off a hell of a clunk - probably more audible because of the lack of engine noise and reflected sound off of any nearby objects (adjacent car, wall, etc).
    -Iain
  11. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    Let me know how the rattle repair goes.
