How To Cool Down Your Car Without A/C
Discussion in 'Gen 3 Prius Main Forum' started by Maine Pilot, Jul 20, 2011.
  1. Maine Pilot
    Maine Pilot Senior Member
    166
    504
    Saco, Maine
    Unfortunately, this video is in Japanese, but essentially it has you opening the windows on one side of the car while opening/closing the door on the opposite side:
    How to cool down your car instantly
    If any of you speak Japanese, could you give us a translation?
    51,851
    so, you're changing the air from outside to inside? cool!
  3. Maine Pilot
    166
    504
    Saco, Maine
    Actually, I think it's purging the hot air from the inside to outside.
  4. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    Excellent example of how to refresh the ambiance of your car after dining at Taco Bell.
    2 people like this.
  5. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    While this may work well for exchanging interior air with exterior air, and it will reduce the air temperature, it will not get most of the heat out of the car. Air holds very little heat per degree of temperature. Most of the heat in the car will be in materials. In the video, they drop the air temp by 10°C, that amounts to maybe 100 BTU (0.03 kWh). The rest of the car is still hot, it has about 5000 BTU of heat at that higher temperature, and will rapidly heat that air back up,
    2 people like this.
  6. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Just get the Solar Roof if heat is that much of a problem where you live and park.
  7. bisco
    51,851
    still, when you get in a hot car that has been in the sun for awhile, i would think it would help the a/c work a little more efficiently.
  8. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    You're exactly right to suggest that the best way to remove most of the heat is to remove the seats.
    Just kidding.
  9. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I would say you're absolutely correct. But I think the perceived benefit of this exercise or any "Hot Day" pre-entery exercise isn't to affectively cool down interior materials that may of heated up...so much as it is to reduce the immediate air tempature.
    Concievably once you are in the vehicle and moving, your options for decreasing the air tempature and increasing the air circulation greatly increase. Even if this means reaching for the button marked AC.
    I try to use a sunshade..and crack windows to avoid the heat build up to start with...
    Curiosity will probably have me try this...but I don't know if I wouldn't rather simply sweat for 10 seconds longer as opposed to repeatedly swinging my door open and shut...
    A hot day, is a hot day outside...regardless of what you are driving.
    Unless you have the solar roof package...I'd think the best recomendation is use of a sunshade, cracked windows, and/or window tinting. My unscientific purely "butt in the car" observation is when I employ these measures...the tempature in my car doesn't feel much greater or greater than the surrounding outside air..
  10. Corwyn
    2,171
    659
    Maine
    Let's consider a sunshade, estimating at 1 meter^2 of glass, 1kW of sunshine per m^2, maybe 50% transmittance = 0.5 kWh after sitting in the sun for an hour. Or taken another way, a sunshade reduces the heat by more than the above pumping technique every 4 minutes.
  11. markf57
    markf57 Junior Member
    78
    17
    Longmont, Colorado
    Do I understand that the heat is not pushed out by closing the door, but sucked out by opening the door?
  12. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Rowing like a galley slave in 90-100 degree heat for 4 or 5 minutes isn't my cup of tea. For those of us with a Prius just try opening the rear hatch and let convection take place. Yeah, I wish we all lived near an ocean... well on second thought.
    2 people like this.
  13. mad-dog-one
    1,181
    421
    Whereabouts Unknown
    I think both must occur, although the heat generated by repeatedly pushing and pulling the door, while standing in the sun, may create the greatest discomfort. Wouldn't you move more outside air into the car and inside air out in the first 20 feet of driving, with windows down?
  14. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Several previous cars I've driven had auto-open windows & sunroof (press & hold open button on remote and they all open). On really hot days I would open all as I was approaching the car, and when I drove off whatever hot air was still in the car would be flushed out.
    Going through what's shown in the vid seems like more effort than it's worth.
  15. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    I saw this, and I was thinking about posting it here. The Japanese huh?
  16. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    I have that in the Lexus and it works really well, especially if it's done from a distance when approaching the car. People who normally park outside in the sun can just get the SR option in the Prius to avoid that hassle.
  17. barcelona11
    barcelona11 New Member
    71
    Central NC, USA
    The operation shown won't cool down the car, as titled, though it will replace the hotter air inside with relatively cooler air from outside. I don't like the idea of opening and closing the door repeatedly for several reasons, not the least of which is what the kids are doing in the parking lot while I'm fanning the car.
    Thermal mass is still the issue, as it is with a home, a building, or the road surface. Cooling down the thermal mass (seats, dash, panels, etc.) cools down the car.
    When the sun is beaming down, I toss one end of a towel over the steering wheel. This keeps the steering wheel (thermal mass) from becoming too hot to the touch.
    What would really help is an infrared reflective (IR) membrane or fabric that we could use to cover the whole car when parked. I want one that pops up like some window shades. Preferably with cool Japanese art on it.
    Buildings with an IR membrane roof or IR-coated metal roofing stay remarkably cooler in the sun due to never heating up the thermal mass. Maybe someday we'll have dark-colored IR paint and plastic for vehicles!
  18. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Open and close the hatch instead of the door. This way, you'll finish it in 5 strokes instead of 10.
  19. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    CAn I do this while the car is in motion? Running the AC really lowers my MPGs and it's all about the MPGs
  20. Corwyn
    2,171
    659
    Maine
    Umm, 'Dark' means absorbing light, and converting it into heat. Infrared is a small portion of all sunlight. So get a light colored car (and cover the windows with something light colored as well) and you are most of the way there.
