Left or Right cubby hole for Sub - How Big is it?
Discussion in 'Gen 3 Prius Audio and Electronics' started by vidoprof, Jul 18, 2011.
  1. vidoprof
    vidoprof New Member
    136
    Tampa, FL
    For any of you guys and gals that had a fiberglass enclosure built (or built themselves) do you know how many cubic ft the area is? I am trying to figure out how big a sub I can go. I was hoping a JL 10W6 would fit on the right side cubby hole as it looks bigger than the left side.
    I saw someone put a Hertz 10" in passenger side (Shawn B) and then another person put in a 8" in a fiberglass on the drivers side.
    I really want it to look FLUSH as possible.
    So I guess would a 10W6 fit in the passenger cubby hole? How deep is the area? The mounting depth on the W6 is about 7". Would that fit?
    Thanks for all the help.
    I get the car Thursday so now I need to really move on this.
    Thanks
    ryan
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Don't think you will get 7" out of the area (including the face)... probably going to have to go with a shallow-mount sub.
  3. shawnb2
    shawnb2 Active Member
    533
    107
    22
    Thousand Oaks, CA
    Hey Ryan, just stumbled across your post. I'm not sure of the exact amount of airspace in my enclosure but I know it's more than the minimum requirement of .5 cu.ft. that my Hertz 10" sub requires and it pretty beefy on the backside. I just ordered a new Kenwood NAV headunit and will be installing it here in the next few weeks. I still have some tuning issues I'd like to address with the fact that I am being over the top picky with how it sounds. I may switch subs if changing a couple other things don't work out for what I'm looking for now that I'm going to have a better source for it all. I will report back with my findings. Just FYI, my sub is 7" total depth with just under 6" mounting depth and it fits just fine.
  4. vidoprof
    vidoprof New Member
    136
    Tampa, FL
    Thanks for the update Shawn.. Problem is that the mounting depth on the 10w6 is JUST under 7". So not sure it would fit, but I am hopeful. I will have to go the 10w3 route worse case.
    Thanks
    Ryan
  5. mee081224
    mee081224 New Member
    193
    Tampa, Florida
    Still doing reseacrh lol. Did you get the car today and in the shop? What did you find out about what will fit?
  6. vidoprof
    vidoprof New Member
    136
    Tampa, FL
    Goes in Monday. Got it Friday. Driving it for the weekend to see if anything is wrong before sending it in.
    So far so good though.. They are going to tell me how much room I have to work with, although I think it's only going to be a JL 10W3 in there SADLY
    Ryan
  7. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    How about the MB Quart's RLP shallow mount subs? 10" is 3" deep and requires only 0.5 cubic ft sealed. 12" works in only 0.7 cu ft sealed.
  8. vidoprof
    vidoprof New Member
    136
    Tampa, FL
    OOOOO A 12".. hrmm.. Now I have to look into it. I am always weary about those shallow mount subs as I think they just don't hit anywhere near as hard as a full sized lower end sub.
    I just wonder if it would sound as good and play as loud or low as the JLW3 would.
    Guess I am off to check some reviews. :)
    Thanks for the suggestions
    Ryan
  9. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    I've heard good things about the Alpine SWR-T thin mount woofers.
    You could probably do a 10 or 12 in that space.
    If you're looking at the 10W6, you might also consider the Image Dynamics ID-Max 10
    or the Alpine SWR-10. All should do well on 500 Watts RMS.
  10. vidoprof
    vidoprof New Member
    136
    Tampa, FL
    Thanks guys.. The problem with the 10w6 is the mounting depth. It's JUST under 7". I will look into the ID MAXX12 for sure, forgot all about that sub, although I am not sure what that mounting depth is.
    The Alpine might be a good choice, although again do they even come close to the output of "Real" 10" woofers?
    So far loving the Prius. :)
  11. vidoprof
    vidoprof New Member
    136
    Tampa, FL
    Unfortunately the ID MAX 12 has an even bigger mounting depth at 8.25". That just ain't gonna happen. :)
    Damn.
    Ryan
  12. mee081224
    193
    Tampa, Florida
    Im starting to wonder, if we really want bass it may need to go under the floorboard.
    I am ok with that, as long as I can move it in and out when need to get to battery or tire.
    But in my 5 years with my old car, I never had to, but flats do happen.
  13. vidoprof
    vidoprof New Member
    136
    Tampa, FL
    Not for me. I am keeping the storage area.. I am just doing whatever sub fits in the cubby hole on the passenger or drivers side.. Plain and Simple
  14. vidoprof
    vidoprof New Member
    136
    Tampa, FL
    I went with the right side cubby hole. It just allowed for more room (without all the curves on the drivers side).. the box just looked much better over there too.
    It's being fiberglassed as we speak. Should have picks up in a few days after I get the car back from the shop.
    Ryan
  15. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    Has anyone thought about putting one in the hatch door itself? Or would that be too difficult/impractical?
  16. hyo silver
    hyo silver Awaaaaay
    15,269
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    My impression was that the left side cubby was bigger, if you take advantage of the space beneath it. The little cover comes right off, and the lower box comes out with a single screw. The left side cubby may not be as wide as the right, but there's no battery in the way like there is on the right, so the air volume is greater. If you're going to the trouble of making a fibreglass enclosure, you may as well use the whole space.
    Let us know how it turns out.
    The wiring's more of an issue, and the hatch lid isn't all that deep, either. Plus, the plastic trim isn't really secured tightly enough for good sound - there'd be a whole 'lotta rattlin' goin' on. :)
  17. mee081224
    193
    Tampa, Florida
    Hey ryan,
    Any update?
  18. Correllaaron
    Correllaaron Junior Member
    San Jose, CA
    Same here, update us! :)
