Aftermarket Catalytic Converters...Any Good?
Discussion in 'Generation 1 Prius Discussion' started by Pufzilla, Jul 16, 2011.
  1. Pufzilla
    Pufzilla New Member
    DFW
    2001 Prius
    I
    Hi All! I have a 2001 Gen 1 Prius with 142K miles. Has the dreaded Cat Code with a $1900 repair bill! Was wondering if anyone that has used the aftermarket converters, what is your experience with these?? Its a huge price difference just wondering if they work and if it clears the cat code. I live in TX and have the emissions testing. Thanks in advance for any all help! Also, where good place to order? :help:
  2. Patrick Wong
    18,200
    6,471
    I suggest that you replace oxygen sensor #1 (which is upstream from the catalytic converter) first, using the correct Toyota replacement part. A marginal oxygen sensor will not show voltage fluctuations as quickly (in response to changes in the air/fuel mixture) which may cause the engine ECU to log the DTC for a failed catalytic converter.
    If that doesn't work, and you decide to install an aftermarket converter, you will have to separate the old catalytic converter from the HCAC chamber which is upstream from the catalytic converter. I hope that you have access to welding equipment or have a local muffler shop that will help you with this.
  3. Pufzilla
    Pufzilla New Member
    DFW
    2001 Prius
    I
    I thought about that too since much cheaper to replace. However, they said that oxygen sensor code would actually show up if that were faulty. The Tech said the cat coverter code is different than O2 senser code. Grrrr....
  4. Patrick Wong
    18,200
    6,471
    It is true that separate DTC exists for each oxygen sensor vs. the catalytic converter. Regardless, if the first oxygen sensor and catalytic converter are both marginal, the engine ECU may post the catalytic converter DTC.
    Then, if the oxygen sensor is replaced with a new sensor that is quicker to respond to air/fuel mixture changes, the engine ECU may decide that the catalytic converter is OK. The ECU makes this decision based upon the difference in voltage readings provided by the two oxygen sensors (the first sensor is supposed to provide rapid voltage variations while the second is supposed to provide relatively slow variations, which indicates the cc is working.)
    In any event, it's up to you. Good luck.
  5. gippah
    gippah New Member
    121
    Austin, TX
    Go to a Meineke. I took mine there and was treated well, and the repair was cheap. Use the search function for my other post on this topic around here somewhere.
  6. sbiddle
    sbiddle Junior Member
    29
    Alton, NH
    I just bought a 2002 Prius about a month ago, 223,000 miles. It had the P0420 code so I needed to replace the converter. I found a thread on this forum with instructions for replacing the cat with an Eastern replacement. It was pretty easy. I needed to cut the pipe right behind the 2nd O2 sensor and with a new donut seal for the inlet and a muffler clamp (included with the cat), I had it installed in a little over an hour. I cleared the code and no more CEL
  7. Don502
    Don502 Junior Member
    Kentucky
    Can you help me find that tread? Where did you purchase the Eastern replacement?
  8. srponies
    srponies New Member
    WI
    2001 Prius
  9. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    Santa Fe, NM
    Don, if you have a 2004, there is a direct fit available from Eastern. But it would be good to understand why your converter failed in the first place.
  10. Don502
    Kentucky
    I haven't purchased the 2004 Prius yet. It has 250k miles. The owner/seller tells me the check engine light is for the catalytic converter. He had it checked at two different places. I will check the tailpipe for carbon deposits. He has been up front with me. I will also ask him about oil consumption.
    Thanks
  11. sbiddle
    29
    Alton, NH
  12. theSaj
    theSaj Junior Member
    25
    Pennsylvania
    2002 Prius
    I had mine replaced by a local shop ($50) after ordering the Eastern unit online. My MPG went up about 1-2mpg after the repair.
