New codes for old part deu
Discussion in 'Generation 1 Prius Discussion' started by Dirk, Jul 30, 2011.
  1. Dirk
    Dirk New Member
    65
    Wa
    2003 Prius
    Well, we are now in our fourth year of trying to get this car to run, and have invested roughly $3000 more than the car is worth.
    I purchased the Autoenginuity software and cable, and then an update that was forced upon us by their firmware upgrade refusing to talk to our version of the software. Caching, $450. It would not read codes. They insisted that the car (after examining the log file) was not putting out any codes. We towed it to a hybrid shop, and the Techstream software put out P3100 data 310. Hooked up the Autoenginuity software, and nothing. Autoenginuity insists that there is nothing wrong with their software!
    Sigh. So, the info from Techstream says the inverter. We purchased one, installed it, and yippee...It tries to start for ten seconds and then P3101 data 205. There is of course a great deal of discussion here on those codes, and the car is within the mileage of the extended warranty. However, since it was involved in and accident, it's our tough luck to deal with it.
    Now. Having read what to do, both here and the TSB, I've drained the tank (assuming 4 year old gas would not be good), put fresh gas in it, and the throttle body shines inside and out after removal and hand cleaning.
    Same result. So, I'm seeking advice on what to check next on those codes.
    Thanks, and stay away from Autoenginuity!
  2. Patrick Wong
    18,210
    6,515
    Your situation is unfortunate, an example of money going into a rathole.
    In any event, since you want to get some return on that investment - with an engine no-start problem, I recommend that you start with the basics. An engine requires ignition spark, fuel, and compression to start. (Checking Prius engine compression requires a special process and access to the Toyota diagnostic laptop.) We can at least check the first two items with the following process:
    Replace the iridium spark plugs using the correct NGK or Denso plugs.
    Check to ensure that the spark plugs are firing, using Toyota repair manual info for details on the procedure. (This basically requires removing the spark igniter and spark plug from the cylinder head, grounding the spark plug shell, and attempting to start the car while watching the spark plug for visible spark.)
    Make sure the air filter is clean and that there are no obstructions in the air flow from the air intake leading to the air cleaner housing, to the air cleaner housing, to the intake manifold.
    Remove and clean the mass air flow sensor using MAF cleaner. You must be able to see the two sensing wires while cleaning. Do not use throttle body cleaner for that cleaning purpose.
    The engine oil should be 5W-30 viscosity and should not be overfilled.
    After you've tried to start the engine a few times, do you smell raw fuel? This is an indication that the fuel pump and fuel injectors are working.
    Since you mentioned a TSB, I assume that you have access to TSB EG011-03. If not, please do a search for that, I've uploaded it a few times.
    Also note that EG011-03 has been superceded by T-SB-0180-09, which puts greater emphasis on throttle body cleaning and less on replacing the engine ECU.
    TSB EG011-03 suggests that, once you've checked the basics, P3101 info code 205 may have a few causes:
    1. Check the circuit opening relay. If the relay's switched contacts have abnormal resistance, the fuel pump will receive reduced voltage, hence will not pressurize the fuel rail to the rated amount. Apply 12VDC to the relay coil contacts, thus energizing the relay, and measure resistance of the switched contacts. If that is more than 0.5 ohm after accounting for resistance of the ohmmeter leads, replace the relay.
    2. Check fuel line pressure (should be at least 43 psi.) If this is low, yet the results of #1 were good, then you'll have to replace the fuel tank since the fuel pump is located within.
    3. If you are sure that the throttle body interior and throttle plate are clean, then check the engine ECU (located behind glove compartment area) part number and replace if the number is below 89661-47054, with a unit purchased from a salvage yard. That might cost you $300 or so.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    Santa Fe, NM
    Don't forget to hose the MAF sensor with some CRC MAF cleaner. It would also be unhappy if throttle body cleaner got on it.
  4. Dirk
    Dirk New Member
    65
    Wa
    2003 Prius
    Thanks to both of you.
    Car has 33,000 miles on it, and the plugs look very good.
    MAF was cleaned with the proper CRC cleaner.
    Throttle body was cleaned with proper TB cleaner.
    Circuit open relay was checked and is perfect.
    MAF sensor wires are visible and no obstructions.
    EGO11-03 was indeed what I was referring to, and I've been through all of it except the fuel pressure, and am now off to the store for a pressure gauge. How do you check it if the car will not start?
    One more point to make is that I do have Techstreem for another day, and at least can do what any Toyota tech can at the moment (short subscription).
    Wasn't the new ECM just cranking the engine longer?
  5. Dirk
    Dirk New Member
    65
    Wa
    2003 Prius
    New info.
    fuel pressure is 43 during the ten second crank run.
    At this point I'm not sure how to test spark and the injectors opening (last two thinks I can think of).
  6. Patrick Wong
    18,210
    6,515
    The current version ECM allows more time for the engine to start, before giving up and logging the DTC P3101/P3191.
    I don't have access to the repair manual at this moment. Assuming you do, pls look up how to test the spark igniters.
    Regarding the injectors, I recall that the test is to see how much fuel is output over a specified time period, and to evaluate the spray pattern. Again, the repair manual would provide the suggested test.
    In case you haven't seen the new T-SB-0180-09, it can be found here:
    http://priuschat.com/forums/generat...0-09-copy-sought-p3191-p3101-error-codes.html
  7. Dirk
    Dirk New Member
    65
    Wa
    2003 Prius
    Oh what joy... Compression
    1. 70
    2. 110
    3. 0
    4. 30
    On and engine with 33K on it.
  8. seilerts
    3,326
    1,519
    Santa Fe, NM
    Were you running the cranking test via Techstream? That spins the engine slower (250 rpm) and keeps wide open throttle. I don't know that it is possible to get sensible results otherwise.
  9. Patrick Wong
    18,210
    6,515
    Even if you didn't use the approved method to test engine compression, if your method was consistent across the four cylinders, then it appears the engine has a serious problem with cyls 3 and 4 at minimum.
    You might add a little squirt of engine oil into the spark plug holes for the four cylinders, then retest to see if the results improve or not. If not, the valves are the problem; if you see improvement then the pistons/rings are the problem.
    So - is it time to shop for a salvage engine? Probably ~$500 plus the labor required to install?
  10. Dirk
    Dirk New Member
    65
    Wa
    2003 Prius
    I was using the Techstreem to do compression. I just got in from the shop where I had removed the valve cover anticipating finding a stuck valve. Plugs came out, and the injectors. Number three showed rusty injector and spark plug. Apparently water got into it while it sat after the wreck. I checked valves on number 3 and found nothing wrong, and was able to move the cup under the cam down and they returned.
    On the upside, I re-assembled it, and checked one plug while cranking and it did have spark. I dropped a couple of tablespoons of gas in it, turned the AC on, and hit the key. It bucked quite a bit at first but It started to run and the display showed it was charging the main battery. And man what a lot of smoke from the oil I put in the cylinders :D
    This is the first time this car has run since we bought it in June of 2006 damaged. What a treat.
    Now I need to get it running smooth, I believe the one injector is not working well. I figure to clean the plugs, but not sure how to deal with the injector. After all the money I've thrown at this, I'd like to avoid 4 fuel injectors.
    Anyone know how to test the injectors?
  11. Patrick Wong
    18,210
    6,515
    Since you've removed the four injectors, I suggest that at minimum you do a visual inspection. If the other three look OK, then just replace the #3 injector and see what happens.
    If you can get the gasoline engine to start, even if it is not running smoothly, I suggest that you force charge the traction battery so that doesn't become another problem. Shift to D, hold the car stationary by applying the brake pedal, then floor the accelerator pedal. That forces the engine to spin MG1 which will provide power to the inverter to charge the traction battery. Look at the SOC gauge and get the battery up to 3/4 charge (three bars).
  12. rlouie
    rlouie Junior Member
    Vancouver, BC
    What you might want to do (which I've used in regular cars) is one or all of the following:
    1. Get some Seafoam and do a piston soak. Pour some Seafoam into each cylinder and let it sit over night. The Seafoam will soak into the rings and hopefully loosen them up.... Start up the ICE. You will find that the ICE will be hard to start but once it does, the whole block will know it started. Once started, take the car out for spirited ride until the smoke screen clears. :spy:
    2. Get a bottle of Gumout Regane Complete (yellow bottle). This stuff is the same as Chevron's Techron but is typically cheaper. Pour a bottle in your next few fill-ups. Should clear out your fuel system.
    Continued on next post (my fourth post and I have some URLs to post for point #3)...
  13. rlouie
    Vancouver, BC
  14. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    It's probably worth checking with OKINJECTORS.COM
    The refurbish injectors for $22 each.
  15. Dirk
    Dirk New Member
    65
    Wa
    2003 Prius
    I've completed a recharge on the HV battery, and can get it cranking again. After the few short runs its had, I now have 100 pounds even on all cylinders. I'm putting a set of plugs in it today, and after that the only thing that can be wrong would be the injectors.
  16. seilerts
    3,326
    1,519
    Santa Fe, NM
    Dirk, this is great stuff. But I am a little confused regarding the injectors. Is the car running, but just rough? Are you getting P0300 P030x codes?
  17. Dirk
    Dirk New Member
    65
    Wa
    2003 Prius
    I was barely running and only after I poured some gas in the intake.
    In the last 24 hours I've replaced the plugs and the injectors. It still won't start!
    The plugs are firing (confirmed), I have 43 PSI fuel pressure, and a local shop rebuilt the injectors today as I watched (cool machine), they were all firing, and after cleaning were even.
    So, even compression, new plugs, rebuilt confirmed good injectors, 43 PSI fuel delivery. It cranks for 10 seconds and stops with P3101 data 205 and the other associated one which I believe was 3191 which basically together says "i didn't start, throw more money at me"
    The only thing I can think of is that the injectors are not firing. Would that throw a DTC?
    It's insane that the car has had $2000 thrown at it, a hundred hours of labor, 5 shops/mechanics, two pieces of software and cables, AND IT WON'T START! :tape:
  18. Patrick Wong
    18,210
    6,515
    After you have tried to start the car, do you smell a very strong odor of raw gasoline in the intake manifold? If yes then you have evidence that the fuel injectors are working.
    If not, the repair manual suggests using an oscilloscope to verify the engine ECM is providing the injector voltage pulses. At idle speed, each injector is pulsed for 2 milliseconds, every 0.2 seconds.
    If you can measure the voltage pulses then you will have proved the engine ECM is providing the correct signals to the injectors. If not then you have a problem with the engine ECM or the wiring harness.
  19. Dirk
    Dirk New Member
    65
    Wa
    2003 Prius
    I just got stranger
    Well, it just got weirder.
    While setting up to get info on MAF and injector pulse from Techstream I attempted to start it, and it DTC’d on the main battery (getting low again). At that split second it started the ICE. Ran like crap, and smelled awful. I’m assuming I was not able to get all the old gas out. I let it run for a while and it improved, but rpm was at 1500, Maf 8.5-10, Injector 4.7. Where it gets interesting is that clearing the DTC and cranking it again to start, resulted in the same thing. It will not fire the injectors until it errors on the main battery. This was duplicated 4 times (no start when things are ok, and the fuel system apparently kicking in when it errors) and since it errors, the engine though running will not charge the battery.
    I’m not sure why the injectors are disabled when there is no DTC
  20. seilerts
    3,326
    1,519
    Santa Fe, NM
    It must trigger a failsafe mode, i.e. the engine runs in spite of multiple cylinder misfires.
    Can you get all the bad gas out? There's a way to get the fuel pump to run and just dump gas out at the rail, but I can't remember how off the top of my head.
