HID Headlight Alignment Sensor: This Can't Be Good...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TonyPSchaefer, Jul 31, 2011.
  1. TonyPSchaefer
    14,816
    2,502
    66
    Far-North Chicagoland
    My HID alignment sensor has been throwing the Big Red Triangle of Death intermittently for the last week. I finally had the time to roll under the car and take a look at it. Having downloaded the PDF for a DIY attempt at repair, I figured that the worst I could do is break a broken part. Worst case, I take it to the dealer for a new part.
    Well, as I rolled under the rear of the car, here's what I was greeted with:
    You can see the sensor mounting unit dangling, being held up by the pivoting end and the wire. So, uh, yeah. Looks like it's more than just a faulty sensor.
    As for going to the dealer for a new part, I think I might start with some salvage yards to see if I can get one on the cheap and replace it myself.
  2. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Do all Prius cars have this actuator on them? G2 anyway. I notice rust like this on my Prius as well. Hal
  3. a_gray_prius
    2,927
    783
    IL
    Wth the sensor just fell off the damn car?
  4. TonyPSchaefer
    14,816
    2,502
    66
    @Hal: others would know better but I believe all cars with the HIDs have this to keep the lights from shining up and blinding the oncoming cars. that is, when you load down the back, the headlights would aim up unless they adjusted.
    @agp: the second picture shows where the two rusted parts are supposed to be one. I have no idea why they would use material that can rust on the bottom of a car. Likewise, I have no idea what could have happened to have snapped it or knocked it apart like that.
  5. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    No, they don't, at least not in US spec HID-equipped cars. My former 04 350Z and 02 Maxima both had factory HIDs and had no sort of manual nor automatic leveling system. I have a copy of the service manual for the Z and confirm there's nothing of the sort in there.
  6. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    Santa Fe, NM
    No, that's not good. Maybe imwoody or freidawg can pull one off a wreck for you. They are $280 online. You may need the bracket too, but at least that is only $10.
  7. Hal W
    Hal W New Member
    872
    53
    I went out and crawled under the Prius and found no actuator attached, and the rust wasn't really that bad! I feel better! Hal
  8. qbee42
    3,082
    All G2 with HID. Leveling systems are required by law in Europe for all HID equipped cars. Leveling systems are not required in the U.S.
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    Yikes!
    If you replace it with a newer piece I would recommend using a rubberized undercoating or a rustproof paint. It's all that road salt.
  10. Patrick Wong
    18,210
    6,526
    I understand that all Canadian cars must be equipped with DRLs which is why the Canadian Prius have halogen headlights, not HID headlights. Only the HID headlight-equipped Prius would have the vehicle level sensor that Tony took photos of.
    MSRP of the new part is $359, you can buy it for $269 plus shipping here:
    Champion ToyotaWorld
  11. TonyPSchaefer
    14,816
    2,502
    66
    I guess that technically I only need the bracket piece to start. After all, I don't know if the sensor's bad or if the warnings were because it was dangling under the car.
  12. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    Tony I just paid $75.00 for the sensor and arm it's mounted on from Steve at autobeyours.com. Total cost to me was $82 including shipping. I was shocked with how clean the piece came from his yard.
  13. TonyPSchaefer
    14,816
    2,502
    66
    My big fear was that I wouldn't be able to remove the bolts from the chassis due to the rust. Worked on it last night and got the two bolts out. I left the pivot arm in place to offer support on one side.
  14. Hal W
    Hal W New Member
    872
    53
    Can you repair the original or is it beyond repair? Hal
  15. TonyPSchaefer
    14,816
    2,502
    66
    I'm not a metal worker so anything broken is beyond repair for me. But in this case, it's pretty rusted and just plain snapped in two.
  16. Hal W
    Hal W New Member
    872
    53
    I guess it depends what the new peace is worth! I am sure some good penetrating oil will free things up then weld broken parts together and coat it with rust remover and then a good rust paint will make it work again? Hal
  17. bisco
    52,878
    when mine failed under warranty on my 04, the tech who replaced it said there was a tsb or recall or something. i wonder if yours is still covered? unless it's just the bracket...
  18. Ryanpl
    780
    158
    Brooklyn, NY
    Bisco, a TSB isn't the same thing as a recall. Under a TSB it alerts the tech that Toyota issued a fix or improved repair. If I'm wrong someone correct me.
  19. TonyPSchaefer
    14,816
    2,502
    66
    Breathing a little life back into this thread.
    Does anyone have a link to an after-market distributor or a salvage place that will ship?
  20. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    Talk to Eric aka "freidawg" on PC at Adopt A Part in Denver...his donors are not all rusty underneath like you poor midwest guys.
    http://adoptapart.com
