Electric Motor Starts When Driver Side Door Handle Touched?
Discussion in 'Gen 3 Prius Technical Discussion' started by eadams44, Jul 31, 2011.
  1. eadams44
    eadams44 New Member
    17
    Jonesville, SC
    After the car is parked for a while, when you open the driver side door or just touch the door handle an electric motor starts running. After several seconds it stops. Sounds as though it is running a pump and building pressure or vacuum. Just wondering exactly what it is? Thanks.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I believe that is going to be your brake hydraulic system building pressure, as you suspected.
  3. macmaster05
    macmaster05 Senor Member
    4,050
    730
    It's getting ready to OWN.
  4. eadams44
    eadams44 New Member
    17
    Jonesville, SC
    own???
  5. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    own = do it's work ( i assume )
    they're getting ready to put a mad beat-down on those brake calipers if necessary... so to speak
  6. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    The typical conventional car waits to be driven and only reacts when needed. The Prius, and I'm not making this up, actually anticipates and begins the preparation cycle before you even start the car.
    There's also a pump the moves pre-heated fluids from a thermos to the engine block in order to bring the engine up to temp faster. I often wondered if that was what the "open the door" noise was.
    But yes, when you open the driver's door the Prius thinks, "I'm about to get driven; I'd better get ready."
  7. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    Yep;)
  8. eadams44
    eadams44 New Member
    17
    Jonesville, SC
    Thanks all. I do appreciate the replies!
  9. fuzzy1
    10,602
    Not on the Gen3, that thermos was abolished with the 2010 redesign.
  10. TonyPSchaefer
    14,816
    2,501
    66
    Good call. I wasn't paying attention and was talking GenII.
  11. qbee42
    3,079
    On the Gen III it is the brake accumulator pump building hydraulic pressure.
  12. Mendel Leisk
    41,863
    The few times I'm opening the door just to pop the hood, and this motor is still starting up, Ii kind of gets to me: wish Toyota would have chose something else as instigator for this pump, maybe: starting the car?
  13. macman408
    1,179
    368
    But by the time you start the car, your foot is already on the brake pedal, and that pressure is already being used. So opening the door is really the right time to do it. Next time you open the door to pop the hood, lean over from the passenger side to do it. ;)
  14. TonyPSchaefer
    14,816
    2,501
    66
    NOOOOooooooo :eek:
    Okay, so I over-react. But this very thing killed my 12v battery.
    Twice. (I'm not that bright.)
    Two things you need to know:
    1) I keep my headlights on as pseudo-daytime running lights.
    2) On the Gen2, the "turn off the lights" is triggered ONLY by the driver's door. Seriously.
    So I opened the passenger door to roll up the windows. On another occasion, I opened the passenger door to plug in my air pump. Both times it was the middle of a sunny day and I didn't notice that the headlights came on when I powered up the car. And both times, since I never opened the driver's door, the lights stayed on even after I powered down.
    But again, we're talking Gen3 in this thread and since I don't have a Gen3 someone else will need to test this.
  15. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    So stop making erroneous statements.
  16. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    As in pwned?
  17. Mendel Leisk
    41,863
    Yeah, I think I'm going to start doing that. I already do that if I want to for instance check the gauges, but was thinking it would be hard to reach the hood release, but believe you're right: it's not that much of a stretch.
  18. fuzzy1
    10,602
    Despite not owning the generation in question, I think Tony got this one right.
  19. qbee42
    3,079
    That's how it works for the Gen II. Toyota changed the initiator with the Gen III. The intention is to make sure brake boost is available when the driver first steps on the pedal.
  20. Ffejrobins30
    Ffejrobins30 New Member
    Santa Clarita, CA
    The noiswe you are hearing is the brake pump running. The reason that they do it when you open the door is because it actually builds pressure and MEASURES where the pads are so it knows how much pressure to apply based on the throw of the pedal.
