Time for the first fill up...
Discussion in 'Newbie Forum' started by Xur, Aug 8, 2011.
  1. Xur
    Xur Junior Member
    Rhode Island
    Hi guys,
    Going to have to go to the pumps this evening to fill up for the first time. I know to just use regular gas on the Prius, however I've heard you should use brand name gas. I used to fill up at random Cash Only stations because the cost was 20-30 cents cheaper per gallon. Should I completely avoid these types of stations and only go to say Shell?
    Any opinions/suggestions would be appreciated. I am stuck at work till 5:30p est. So let me know before then!
    Thanks,
    X
  2. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    I would suggest experimenting. See what works best.
    I have seen as much as almost 3mpg difference between some brands but it is most likely the station since it is all the same stuff with different names.
    3mpg difference over the same distance will be around .5 gallon (example uses 425mi and 50 or 47mpg). That is around 1.80 difference.
    20c a gallon difference is also around 1.80.
    So...it really is a wash.
  3. Xur
    Xur Junior Member
    Rhode Island
    Well now that it is down pouring out...I'll go anywhere that will pump for me.
  4. eadams44
    eadams44 New Member
    17
    Jonesville, SC
    It's been my experience that alcohol free 100% gasoline is far better (if you can find it) than E-10.
  5. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    I agree. I frequent one of two local Shell stations. One of the stations has nice young ladies that pump your gas for no extra charge.
  6. Mendel Leisk
    41,230
    I'm partial to Chevron, mostly superstition I suppose. One thing, they still have FREE air, that get's my vote.
    Funny, I can remember my FIRST fill up, I mean: first in my life. At least at a self serve, which sort-of sprouted up in my carless years, between youth and responsibility.
    I had no idea that the pump would shut off. Or not.
    Also, I think it took me 3 tries to get up beside a pump, with gas cap also adjacent to it, LOL.
  7. bisco
    51,787
    i've used anything and everything and never noticed a difference in 40 years of driving.
  8. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    I drove a 1966 mustang from 1994 to 1999 as a daily driver. It has the gas cap in the center back, adjusting to a side filler was quite the task as I was used to pulling up anywhere and being able to fill.
  9. oldasdust
    oldasdust Member
    356
    47
    illinois
    The strangest thing in my area the cheapest gas gives the best mpg in all three cars, found this after years of crunching numbers. The honda fit dash mpg the most accurate only off a couple tenths from actual number crunching.
  10. Mendel Leisk
    41,230
    I found Honda Civic Hybrid (06) dash mpg (well, liters per 100 km) very accurate as well, slightly underestimating.
