2005 Cruise Control Switch How to remove
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Driver Ed, Aug 4, 2011.
  1. Driver Ed
    Driver Ed New Member
    Los Angeles
    I think my cruise control switch is bad.
    Is there a simple way to remove it without taking of the steering wheel.
    I know when I turn the wheel upside down I can see the back of the CC switch surrounded by a plastic plate. When I take that off the trim plate I can see inside but that about all I can do..
    Please help.
    Thanks
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    Santa Fe, NM
    Service manual recommends disconnecting 12V power, removing steering wheel covers and horn button. No need to remove the wheel entirely.
  3. bstephens
    bstephens Junior Member
    36
    Oklahoma
    Changing the switch is really easy. Remove that trim plate you mentioned, along with the one on the opposite side of the steering wheel. Oh, disconnect the battery first - you are fooling with the air bag area! Now back to the trim plate areas - you will see bolt head on each side. I think they have allen wrench heads, maybe not. Loosen those bolts a few turns, not enough to remove them. Those hold the horn button/airbag in place. That should be able to be turned out, towards you if you loosened the bolts enough. Now you will see the two bolts holding the CC switch in place, and the wiring harness. Remove both bolts and disconnect the harness. Reverse the process to install a new switch. It is even easier than the description. And you saved $120, because that is what the dealer quoted me to do that.
  4. Driver Ed
    Los Angeles
    Thank you guys!
    I'll give it a try.
  5. DotBone89
    DotBone89 Junior Member
    Virginia Beach
    Thanks to Driver Ed, seilerts, and bstephens; just finished the repair and performed the PMCF. All systems 4.0! (Well the CC systems at least).
