Heat and AC
Discussion in 'Gen 2 Prius Fuel Economy' started by tbstout2, Nov 22, 2005.
  1. tbstout2
    tbstout2 Member
    156
    Hallieford, VA
    My question is aimed at the multitude of Toyota Prius experts.
    If the AC/Auto is on, does the AC compressor start up whenever the inside cabin reaches the set temperature?
    The recent weather in VA has dipped down to between 32 and 40 in the mornings. If I set my AC/Auto to 68 I often feel cold air coming out of the upper vents. I know that the system alters where the air is delivered (floor, floor/vents, etc.) but I’d hate to think that the AC is kicking on when it’s 35 degrees outside.
    I could simply set the temp without the AC/Auto but the steering wheel control is very handy.
    Thanks for your feedback!
  2. simple_in_seattle
    simple_in_seattle New Member
    58
    Lake Stevens, WA
    You can set it to Auto without the potential for AC to come on by going to climate and hitting the yellow "AC". It should then go grey yet still perform climate control.
  3. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    I think you will find that it's outside air you're feeling, which on 32-40 degree mornings is cold.
    Thats one of my complaints with the Prius climate control. Once the car gets to the desired temperature, it blows out cold air. I end up angling the vents away from me and then it's OK.
  4. Bill Merchant
    Bill Merchant absit invidia
    4,096
    86
    The only time the compressor should come on when it's cold out (lower outside temperature than the desired cabin temperature) is when you put on the windshield de-fogger (the button that sort of looks like air blowing at a fan). If you have fogging windows, running the AC compressor helps reduce the humidity of the air blowing against the windshield, which helps eliminate the fog on the inside. Both the heat and AC are running then.
    Otherwise, I agree with Marlin. It's probably outside air that hasn't been warmed that you're feeling. Try putting the system in recirculation mode and see if you notice the blast of cold air.
  5. nhalber
    nhalber Junior Member
    83
    Marblehead
  6. nhalber
    83
    Marblehead
    I know that you can set it to grey, but why does it come on initially. My garage is 46 degrees, I back out and the temp is 34 and the a/c is yellow.
    Is there some initialization going with the computer system?
  7. KMO
    KMO Senior Member
    1,903
    651
    Finland
    2023 Prius Prime
    The yellow light doesn't necessarily mean the compressor is on, just that it is enabled. Exactly when it decides to use it (and at what speed) is a mystery known only to the system designers.
  8. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    "I often feel cold air coming out of the upper vents."
    Right, that is the way it is designed work. The A/C icon is a misnomer it actually denotes whether the Climate Control is functioning or not.
    Denso says:
    "By using a 50/50 ratio of fresh and recirculated air we were able to reduce the ventilation load 50%. At the same time, we were able to achieve the same cabin temperatures possible with conventional systems. Warm cabin air has a high moisture content. So, simply recirculating the cabin air would fog up the windows. The new system sends recirculated air out at foot level. Drier fresh air flows near the windows, which prevents moisture from condensing on the glass. "
    For more info see: http://www.denso.co.jp/AR-e/1998/TW/climate.html
  9. nhalber
    83
    Marblehead
    Thanks
  10. tbstout2
    tbstout2 Member
    156
    Hallieford, VA
    Thanks, SeaSalsa I read the entire info on the Denso site.
