Automatic Air Conditioner
Discussion in 'Gen 3 Prius Main Forum' started by nated1455, Aug 9, 2011.
  1. nated1455
    nated1455 New Member
    New Berlin
    Hi this is probably a foolish question with a simple answer, but I'd still appreciate one. When I turn on the air conditioner using the remote, does it use the gas engine or the hybrid battery to power that? If it has been sitting out in the sun all day, does the solar roof power the air conditioner? Thanks!
    Nate
  2. goober_nut
    goober_nut Member
    68
    Champaign, IL
    When you press the AC button on your fob, it will use the battery and gas engine to run the compressor.
    The solar panels on your roof ONLY power a fan, for about 3 minutes at a time, to keep the temperature similar to outside (assuming you've enabled it before leaving your car) so that you don't get in a crazy hot car.
  3. Tideland Prius
    16,615
    Actually, the Remote Air Conditioning System (world's first) does NOT use the gas engine to run the compressor. It runs off the hybrid battery until the battery runs out (2 bars) or 3 minutes have passed whichever is first. It is meant to supplement the Solar Panel Ventilation System.
    The SPVS powers the fan (your fan motors have been beefed up compared to cars without the SPVS). After you stop the car, the vehicle will open the vent after 1 minute and start ventilating at 10 minutes (depending on how hot it gets inside the car and how much solar energy it can receive. It will run intermittently or continually depending on how much power it's receiving so don't be alarmed if you get into the car and it's not running and you think it's broken.
    The Remote A/C just helps further cool the interior if you wish (and of course works best if the SPVS already vented out the hot air). It will use the last setting on your climate control (so if you had it at MAX COLD before you shut off the car, that's the setting it'll use. If you had it at 78°F, that's the setting it'll use).
    Two things to note:
    The SPVS will continue to run even if you unlock the car and open any of the doors or the hatch. It will turn off if you start the car or press the SPVS button on the left side of the dash to turn it off.
    The Remote A/C however will shut off if you open any door and the whole system (the SPVS) will restart in 10 minutes.
  4. fulltank
    fulltank New Member
    230
    Arkansas
    Didn't want to start a new thread and thought this one was as good as any...
    Anyway, I purchased my new Prius last Oct and have not really experienced really HOT weather. How badly will my MPGs be affected if i have a bad of habit of having my AC cranked all the time?
  5. Royal5280
    Royal5280 New Member
    49
    Dallas
    Tideland- thanks for the heads up. About to pick one of these up and that is certainly a valid question. Is there any feedback on the reliability of this whole package? Is it even offered anymore or was it a one-hit wonder?
  6. F8L
    19,011
    4,083
    Grass Valley, CA.
    It depends on how long your trips are. Short trips and heavy AC use is a recipe for terrible mpg. On my GenII I observe a temporary 10mpg hit until cabin temps comes down. If I only drove 5 or 10 miles at a time my mpg would drop precipitously.
  7. Tideland Prius
    16,615
    Np.
    So far so good. I turn it off in the winter because sometimes it can run in early spring/late winter or late autumn/early winter on a sunny day (where the day is still long enough and the sun is still strong enough) but I really don't need it to run. Otherwise, I just leave it "on" all summer unless it's dusty.
    It's still offered on the Liftback model. The Prius v gets a resin panoramic moonroof and the Prius c gets a regular one so there are 3 types of moonroofs available for the Prius family.
    If the Prius v was lighter, it would've been nice to have it on the roof as well as it's a larger vehicle with more windows.
  8. yeldogt
    yeldogt Active Member
    810
    313
    NE
    My guess is that the original design of the roof did not allow for a sun roof. And someone convinced the Toyota higher ups that the whole solar roof would be a good idea.
    It sounds good on paper but adds little to the value of the vehicle and it prices the roof to a level to make it too expensive for many. Same for the A/C key control complexity -- give me better seats vs the solar roof panel and auto headlight vs the AC control.
