CNG Civic GX vs. Leaf EV (elec from NatGas)
Discussion in 'Environmental Discussion' started by wjtracy, Aug 10, 2011.
  1. wjtracy
    wjtracy Senior Member
    11,363
    3,607
    Northern VA (NoVA)
    A few months ago we explored http://priuschat.com/forums/environmental-discussion/90200-coal-power-volt-vs-gas-power-prius.html .
    Today I would like to explore CNG Honda Civic GX vs. Nissan Leaf EV, where the electricity for the Leaf is generated from 100% Nat Gas. Which is cheaper to refuel? Which is more efficient?
    The Civic GX apparently gets about 26 miles per GGE (Gasoline Gallon Equivalent), whereas 1 GGE = 126.67 cubic ft of Nat Gas. The Civic "gas" tank @3600 psig holds 8 GGE. So you get 208 miles on a tank which burns 8 x 126.67 = 1013 cubic ft of Nat gas. CNGprice.com showed wide price variations but I am using $2/GGE = $16 for fill-up. Can also fill-up at home, not sure cost.
    The Nissan Leaf EV gets about 3 Miles/KWhr. At the power plant, each cubic ft of nat gas burns equates to 0.1465 KWhr assuming 50% thermal efficiency. Thus traveling the same 208 miles takes 69.3 KWhr = $8.31 @ 12cents/KWhr and uses only 473 cubic ft Nat Gas.
    Somebody check my calcs, but seems like the Leaf wins this contest. Leaf uses less NatGas and costs less to refill. Possibly you can refill Civic cheaper at home, but bottom line 26 MPGGE is not that impressive. GX refill cost does not seem much different than a Prius @ 50 MPG. Can anyone comment on $2/GGE fill-up costs?
  2. wjtracy
    11,363
    3,607
    Northern VA (NoVA)
    :violin:
    Let's jazz this up by comparing the Civic CNG vs. Prius Gen-III HEV.
    Apparently jazz violin is the only choice.
    Our favorite vehicle Prius Gen-III gets 48 MPG so it uses 4.3 gals of gasoline to go the same 208-miles, also costs about $15-16 refill, and that is approx. only 23-lbs carbon.
    So the Prius HEV makes ~30% less CO2, but California allows the CNG Civic GX to use the HOV lanes and not the Prius?? Fair? OK for me since I am in VA.
    Also note there is no apparent CNG refill cost advantage, since although CNG is cheaper, it burns almost twice as much CNG@ 8 Gal equivs. versus 4.3 gallons regular gaso for the Prius.
  3. jdenenberg
    jdenenberg EE Professor
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Don't forget to take into account the road use tax (Fed and Local) that gasoline (and diesel oil) pays, but for the moment is not charged on CNG, Propane or Electric.
    JeffD
    ps. You can run a Prius on CNG or Propane to get the hybrid benefit over the Civic GX.
  4. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    I serve on my town's recycling commission and had to recently work up a proposal for a new trash truck - here in eastern PA gas is $1.36 per cch (hundreds of cubic feet) and as you said the GGE of CNG is 126.67 cu ft (1.267 cch). So just multiplying the two I'd get the price for the GGE of natural gas being $1.72.
    So if the Prius gets 50mpg that means gallons per 100 miles would be 2 so at $3.85 a gallon the cost would be $7.70. If the Civic GX gets 26 mpge the equivalent gallons per mile would be 3.8 and cost $6.61. So a bit of a savings assuming that I did not mess anything up.
    As far as I know it, the big market for CNG cars is Utah - the state has a substantial subsidy on natural gas - I read an article about it a few years ago.
  5. wjtracy
    11,363
    3,607
    Northern VA (NoVA)
    Steve - Thank you. You are saying even though CNG Civic burns about 2x more "gallons" per mile, it can cheaper for some. True.
    Some states apparently charge less than <$0.80 per CNG gallon! However the recent TV commercial, the nat gas vehilcle promotion says CNG cost is generally about 40% less than gasoline per gallon.
    Re: CNG COST
    Web site CNG stations and Prices for the US, Canada and Europe shows all the refill stations in the USA.
    Cost varies widely "all over the map", but seemed like $2/CNG gallon was about right for the calcs.
  6. wjtracy
    11,363
    3,607
    Northern VA (NoVA)
    JeffD- Just saw T Boone Pickens on TV, talking about the nat gas big rig trucks he proposes. I assume the trucks he is talking about must be really good MPG big rigs? Otherwise the CNG cost savings would not be there. Sort of like saying replace old low MPG trucks with new high MPG trucks and, by the way switch to NatGas too?
  7. jdenenberg
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Actually Mr. Picken's grand plan is to lessen our dependence on foreign oil by switching a large part of the transportation energy usage to locally produced nat gas. He doesn't emphasize any overall cost savings. It also doesn't hurt that he would make a lot of money in the process.
    JeffD
  8. austingreen
    austingreen Senior Member
    13,664
    4,204
    Austin, TX, USA
    The idea is non CO2 polutants, but the prius is really low on those. California only recently got the right to regulate CO2. I can't say the CARB rules make much sense, but prius or civic GX or leaf do reduce the dangerous pollutants in LA.
    Since the civic already has similar substitutes, not nearly as much oil is displaced as it would be on heavy trucks or busses. The piken's plan is forward looking when we need to reduce gasoline usage, it reduces future possible shocks of oil shortages. It would probably cost money over the next 5 years, but this may be worth it to reduce oil dependance. Having plug-in diesel hybrids would also greatly reduce oil use.
  9. icarus
    icarus Senior Member
    4,884
    976
    earth
    Auto propane is road taxed in most places that I know of.
    Icarus
  10. wjtracy
    11,363
    3,607
    Northern VA (NoVA)
    OK I thought he mentioned nat gas cost cheaper per gal (for trucks) on TV today. That's why I thought he was out on a limb if the trucks use more CNG, then overall no cost advantage.
  11. wjtracy
    11,363
    3,607
    Northern VA (NoVA)
    ...as you say AG it is hard to beat Prius, but some are close and offer alternate fuel choices. HOV lanses are for, well, more than 1 person.
  12. austingreen
    13,664
    4,204
    Austin, TX, USA
    You may have heard that. The plan is supposed to take a decade to implement, so you need to estimate the cost of CNG and gasoline 10 years out. The pickens plan would use a great deal of federal money to build wind farms and transmission lines. If wind is substituted for natural gas on the grid, and then this gas is used to power trucks, perhaps cng price will rise slower than oil. Its a big if. I'm sure pikens will profit from the plan if implemented, but he stands to profit more from the wind power transmission more than the cng.
  13. wjtracy
    11,363
    3,607
    Northern VA (NoVA)
    AG- Yes hard project future cost. Did you agree with my OP calc for NatGas power @ ~50% efficiency?
  14. austingreen
    13,664
    4,204
    Austin, TX, USA
    I'd say its a little high. Certainly the newer combined cycle plants are that high, but most of the peaking plants are simple turbines, and worse in california they have many gas steam turbines which have the lowest efficiency. Marginally when we are talking long term its 50% for EVs powered by natural gas, but while the grid is being built out I would use 40%-45%.
  15. gaspig53
    gaspig53 New Member
    Fresno
    I live in Utah and own a Prius and a CNG Civic. I commute 100mi a day all hyw at 70mph. Civic gets 30mpg. Prius gets 45mpg. CNG cost $1.25 gge. Gas cost $3.50 gal. Approx. Cost $3.75 for CNG, $7.00 for gas. Only when gas gets down to $1.85 a gal will the Prius be better.
    Now when I drive out of state the Prius shines. The CNG infastructure is not as good as Utah in other states.
    2 people like this.
  16. wjtracy
    11,363
    3,607
    Northern VA (NoVA)
    Thank you GP! I agree Civic gets ~30 highway MPG. I used 26 MPG due to favorable review article that said 26 MPG was average if you do mixed driving. So you have favorable MPG commute and favorable nat gas cost, so you are making out well. Utah sounds nat gas friendly.
  17. drees
    drees Senior Member
    1,782
    247
    Appears to be 40% as of 2010 in CA. Has been steadily improving at nearly 1% year for the last decade thanks to the addition of combined cycle plants - was only 33% in 2001.
    http://www.energy.ca.gov/2011publications/CEC-200-2011-008/CEC-200-2011-008.pdf
    Efficiency of different types of plants for 2010:
    New Combined Cycle: 47%
    Aging Plants: 30%
    Peaker Plants: 30%
    Cogen Plants: 30%
    Other: 41%
    Combined cycle plants are currently around 65% of total gas fired output, cogen plants are around 28%, aging plants are around 5% and peakers less than 1%.
    Note that cogen plant efficiency does not include the heat used from those plants - so actual efficiency should be much higher. I think it'd be safe to assume that those plants are at least as efficient as CC plants (given that their output has remained fairly constant around 25-30% the last 5 years). A quick google search shows that many cogen plants can reach 90% overall efficiency. Given that CC and cogen plants consist of 91% of total generation I think for all useful purposes one could assume that the actual efficiency of gas plants in California is at least 45% and could be significantly higher.
    The paper above lists heat rate in Btu/kWh. To calculate efficiency I assumed that 100,000 BTU == 29.3 kWh which would be 100% efficiency.
