To TPMS or Not To TPMS
Discussion in 'Gen 3 Prius Accessories and Modifications' started by minh240z, Aug 10, 2011.
  1. minh240z
    minh240z New Member
    Placentia
    I am new to this forum and I have a 2011 Black Prius II. I am going to purchase some new wheels and I am on the fence about transferring the sensors to the new wheels. I am purchasing the new wheels & wires online and they will mount and balance for free before shipping them out. So I just want to get a feel for how many of you with aftermarket wheels transferred the sensors over to then new wheels.
    Thanks!
    Minh240z
  2. justintiime
    justintiime Junior Member
    64
    Moneta, VA
    Recently, I was on the fence about the same issue. I found some online. I called and was assured they were OEM parts. Not bad for $62 shipped for all 4! I couldn't pass it up.
    (4) Scion TC XB XD TPMS tire sensors PMV-107J | eBay
    If that link doesnt work, the sellers name is centersplus
  3. justintiime
    64
    Moneta, VA
    also the fact im going to be switching from summer/winter rims and tires made me figure that switching TPMS was going to be a pain, so I got the extra sensors.
  4. ocblackpriusii
    ocblackpriusii Junior Member
    56
    OC/So Cal
    If you go this route don't you have to have the dealer re-initialize the computer to recognize the new sensors? And then again when you put the original ones back on? In other words, the computer will not automatically register new sensors, only the four it is programmed to recognize.
    I don't plan on switching tires annually so I just had the existing sensors installed on my new wheels.
  5. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    Yes, you will need to update the TPMS IDs in the ECU each time you swap wheels. You don't necessarily have to use the dealer for this, as there are tools you can buy that allow you to do it. Some larger tire chains may have the tools that are compatible with Toyota or they may not.
    The other option is to buy a TechStream compatible cable (most get them from China) and to install/uninstall/install each time you wish to use it. Or you can purchase a 2 day subscription for $55 and program it yourself.
  6. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    I did the ECU wire jumper mod. The light never comes on and I can switch between my winter and summer tires. With out wasting money on the sensors.
  7. justintiime
    64
    Moneta, VA
    cliffs on the jumper mod?
  8. minh240z
    minh240z New Member
    Placentia
    Can you link us to that jumper mod? Thanks for all the input. I decided to not install the sensors.
  9. robby3
    robby3 Member
    181
    24
    Switzerland
    Has anyone tried the TPMS Tool from ATEQ called "TPM QuickSet" ? I have one at home that doesn't work on the RAV4 but maybe it does on the other sensors of the PRIUS. I have also ordered the OEM quality $69 TPM sensors and hope they work as advertised.
  10. Judgeless
    1,821
    257
    Cleveland, OH
    2 people like this.
  11. wick1ert
    1,311
    183
    Delawhere
    It works here in the US - I'd imagine it would work there too.
  12. Mendel Leisk
    41,928
    Within a week of purchase last fall I swapped out our OEM 17" alloy wheels (with Tire Pressure Monitors) for snow tires on 15" steel rims, without TPM's. The world continued turning. Basically one little light came up on the right extreme of the dash. Put the OEM's back on in spring: the light disappeared.
  13. wick1ert
    1,311
    183
    Delawhere
    My personal preference, if one were to have 2 sets of wheels/tires and only 1 set of TPMS would be to put them on the snow tire set. That's mostly because in winter it's cold, possibly snowing, and I really don't want to fiddle to check the pressures if I don't have to. More likely to keep an eye on it during summer months.
  14. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    Swapping the sensors between tires is asking for aa sensor failure.
    Getting thee dealer to reprogram the TPMS twice a year is not cost effective.
    ... or one could avoid the costs and just live with the bloody TPMS warning light.
  15. minh240z
    minh240z New Member
    Placentia
    Order new wheels today and will get them on Monday. I will post pics once they are on.
  16. Judgeless
    1,821
    257
    Cleveland, OH
    Or do the 5 min mod I post in this thread and never had to worry about the light again.
  17. robby3
    robby3 Member
    181
    24
    Switzerland
    Just a side note from our europen cars with head-up display: The display shows several allerts and the TPMS is one of them. Instead of speed we are getting the warning triangle for the TPMS. do not know how long this stays but it will be annyoing for sure.
  18. Mendel Leisk
    41,928
    Judgeless, did you forget to post a link? Thanks.
  19. GoldPianoGarden
    GoldPianoGarden Bling Meister
    841
    74
    98
    Brunswick, GA
    He did in post #10 on the first page of posts....
  20. w202mae
    w202mae Junior Member
    59
    SoCal
    I bought my wireless tpms monitor on Amazon, made by Tyredog. Shows psi and temp, love it, easy to use with screw on cap which is easy to transfer.
    thongn likes this.
