Need advice on 08 Prius Bumper
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by HowardDean, Aug 14, 2011.
  1. HowardDean
    HowardDean Josh
    Connecticut, U.S.A.
    Today I hit my front bumper on a large rock while turning the Prius. Admittedly my fault (I'm really beating myself over it) but c'est la vie I suppose.
    Any idea on what kind of repair I'm looking at with just the damage in the picture? Will the whole bumper or bumper cover need to be replaced? And does anyone have any suggestions for repair shops Toyota certified or non in the CT/NY/PA area.
    Thanks for any feedback! Id really appreciate it.
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    You could check local Toyota used parts from a boneyard parts yard!. The bumper is a pretty easy thing to replace, expecially if you find a blue one!
  3. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    It does not look all that bad - just the area below the fog lamp. I dinged that area on mine - my daughter left a bike rack in the driveway - I was able to use a hairdryer to pop the plastic bumper out to just about normal. Since the bumper is plastic you do not need to worry about rust so a bit of touch-up paint might cover it. It would not be perfect, but given that it is low to the ground it might be acceptable.
  4. wesj49
    wesj49 Junior Member
    72
    CA Central Coast
    Problem with the abs bumper is that they stretch and/or crack and can't really be repaired. If nothing is damaged behind the shroud, a body shop will probably want to order a new plastic cover to paint and replace. In CA around $1000.
