Low tire pressure = low mileage
Discussion in 'Gen 3 Prius Fuel Economy' started by lucas in alaska, Aug 14, 2011.
  1. lucas in alaska
    lucas in alaska New Member
    Eagle River AK
    I have 6600 miles on my Prius. When I first go my prius I increased my tire pressure to 40 psi. At 5000 miles I got an oil change and my checkup. Took a road trip of 400 miles and got 53-54 mpg.
    Just before my fill up at 5500 I put a screw through my front passenger tire. Toyota fixed the tire for $10 and I was on my way.
    The last two tanks of gas I have only gotten 45 mpg and was ready to take the Prius back into Toyota and ask them to fix whatever they did to the car.. To make a long story short I decided to check the tire pressure on all the tires again. Three of the tires were at 40 psi and the one Toyota fixed was at 35 psi. I inflated the one tire to 40 psi and not I'm right back where I was on the mileage. 52-53 mpg.
    It's really hard to believe that 5 PSI on a front tire dropped my mileage from 52 to 45 mpg. That a 14% drop in mileage due to 5 psi difference in one tire. WOW!!!
    Moral of this story, make sure all your tires PSI match.
  2. fuzzy1
    10,603
    There must have been some other factors involved. One mismatched tire, or even four low tires, shouldn't make that much difference.
    What was the average trip distance on the two low-mpg tanks? What was the average tank mpg of the first 5k miles?
  3. lucas in alaska
    Eagle River AK
    I do agree with you on your points. My driving pattern did not change the last two tanks. The only reason I can think of in seeing a major difference in mileage is the transmission had to work harder to turn the tires with such an difference in tire pressure.
    I don't have the average distance but as I said before our driving pattern didn't change. We live 3 miles from downtown and it's all down hill one way. Easy to average 99.9 on the way down and by they time you return home the average is usually 53 or 54. I live 13 miles from work and I usually average 54 or 55 going to work and back. It is not unusual for us to drive 25-30 miles one way and back and see an average of 55. Now mind you that is what the prius says and so far the prius has been showing 2 mpg better than I actually get.
    I don't have the exact number but when I filled up I genrally saw 50-55 mpg. Most of the tanks were right around 52.
  4. lucas in alaska
    Eagle River AK
    I should also add I generally reset trip A on my car every time I leave the driveway and monitor my mileage while driving. It is really enjoyable to constantly try and improve my MPG.
    PS: This drives my wife nuts so when she is in the car I don't do 50-55 mph on the hwy I do 60-65. I also speed up to 65 if traffic is heavy to not upset other drivers (had to throw that disclaimer in).
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Hey Lucas, I am getting the same numbers for my commute (54-56). Winter sucks though (about 43-44).
  6. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    I usually inflate my tires to 2.7/2.6 bar (front/back - 39/37 psi). I went for the 30.000km check and once I got the car back went to check for the tire pressure - guess what - it was back to 2.4/2.3 (as per indication in the door).
    I think dealers are compelled to give the car back according to specs.
    So, this means you need to check tire pressure again each time they put their hands on the tires or the car for a maintanence check... ;)
  7. HowardDean
    HowardDean Josh
    Connecticut, U.S.A.
    One my way from Connecticut to Maine I noticed I was getting terrible MPG ~ 48 driving around 70 mph (still 3 better than the EPA claimed it could do on highways)
    This morning the TPMS (_!_) light came on. I had to check the manual to see what it meant.
    I inflates front (42) rear (40) a month ago. When I checked today it was 38 for the front pair and 34/25 in the rear. The 25 psi is probably what tripped the TPMS.
    Now I'm back to ~50-54 MPG :-D and on my way to Quebec, Montreal and Vermont.
    I wonder if I should get the 25 psi tire checked. Is it normal to drop that much pressure? I inflated them when it was 90°F + out and its mid 50°s here in Maine...
  8. HowardDean
    HowardDean Josh
    Connecticut, U.S.A.
    Sorry to ramble on but I was surprised how easily the (_!_) TPMS warning light went off - I re-inflated the tires accidentally with the car on...the light was off when I got back in.
    I was expecting to have to go through the reset procedure with the button under the dash and the ignition switch.
    Also, it's nice how in Connecticut air for tires is mandated free by law. Although, some stations still have quarter slots and allow unsuspecting patrons to pay. They begrudgingly flip a switch when free-loaders like me invoke the law and ask to turn the compressor machine on. Every state should have such a law.
