can you use 2006 parts in a 2004? camera/aux in?
Discussion in 'Gen 2 Prius Main Forum' started by m1j1tc0rn, Nov 22, 2005.
  1. m1j1tc0rn
    m1j1tc0rn New Member
    92
    Does anyone know if you can take a 2004 prius and upgrade it with the 2006 head-unit (which has aux in) and the rear camera?
    Granted you'd need to run wires, but I'd think it would be possible.
    At least, I hope so. :)
    Any help or knowledge would be great.
    Thanks!
    -r
  2. inPlacentia
    inPlacentia New Member
    36
    Orange County, CA
    That would be cool.
  3. Jeffreywho
    Jeffreywho New Member
    47
    Scranton, PA
    I know you could add a rear camera. It's just a license plate holder with a camera. Think I seen the link here, maybe someone can help.
  4. m1j1tc0rn
    92
    i know coasteletech makes one, but i'd like to try and go with oem stuff.
    the wiring doesn't exist in the 2004, but the port is there.
    if i could replace the headunit and add the camera, i would be happy.
    i got my wife a 2006 sienna and the toyota nav screen is now a higher resolution and the navigation experience is much better overrall. i wonder if the 06 prius will have the same system.
    anyway...
    -r
  5. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    Just saw the rear backup camera today on a 2006 at the Orange County Prius Club- it is cool.
    Any newer word on whether the 06 camera would work on an '05?
  6. BMcGraw
    BMcGraw Member
    230
    Southern California
    Assuming you're talking about the Viewtech 200? with the A/V input you should've stated that "...coastaletech MADE ONE". Dave 'made one' and then put it in his wife's 2004. He's never sold ANY to ANYONE Y E T ! (If ever....)
  7. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    actually, we will be pulling an attempt at throwing in the aux-in into our 05 once my husband has time to go through all the wiring diagrams of the 06 vs 05 and decides whether it's doable without a major undertaking. if anything pans out i'll share how it got done.
  8. naterprius
    naterprius Senior Member
    1,843
    I've already checked out the wiring on the 2006 for the backup cam. Quite a bit different than the 04-05.
    It's not looking good.
    Nate
  9. AlphaTeam
    AlphaTeam Member
    643
    Earth
    Where is the actual camera on the 06? I know in the back....but where specifilly?
  10. Jeffreywho
    47
    Scranton, PA
  11. prius_colony
    prius_colony New Member
    Northern Ohio, USA
    Ok, that's a little small... How about:
