Lower front fascia and pan damage - ideas?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mmcdonal, Aug 17, 2011.
  1. mmcdonal
    mmcdonal Active Member
    666
    98
    Columbia MD
    So, dang it, I went over a grass median getting out of an hour long traffic jam, and this is what happened.
    The clips on the left wheel arch popped out as well, so the fascia is wider on the left side by about an inch. Just the lower clips (one or two).
    I guess I will have to get an entire new fascia, have it painted, get an entire new pan, etc. Ideas as to time and cost? I am not reporting this to the insurance company.
    :pout:
  2. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Maybe wait to see if the 2012 Prius resculpted front-bumper fascia can be retrofitted on the 10/11 and it'll look like you have a brand new Prius :)
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Check with a couple of body shops and see what they would charge for a non-insurance job to make it look good from normal viewing positions. No need to worry about perfection for the guy working under your car.
    There is also the possibility of a used fascia in the same color as your car. That should be a do it yourself job for person with moderate skills and a little time on their hands.
    If the pan is still there, any type of repair that puts it back in service and is reliable is good enough. It doesn't have to be pretty work since the pan is dull black and under the car.
  4. mmcdonal
    666
    98
    Columbia MD
    I think I will try to repair the pan myself. It is deflected downward with a crease in it (not apparent form the pic, I guess.) I could remove those pieces, have a go at straightening them, and replace it/them.
    The fascia looks hideous in this pic, but no one has noticed the damage.
    My biggest concern is this becoming a snow scoop when the weather turns.
    Are there any online body parts catalogs?
  5. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    No crack in paint so see if a paintless repair place can fix it for a nominal charge and make it look totally new.
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Here's one
    Part Detail
