Please take the Prius rattle survey
Discussion in 'Gen 3 Prius Main Forum' started by phoenixgreg, Aug 20, 2011.
  1. Yes for rattles My Prius was made at Tsutsumi plant line # 1 (code 0)
    15 vote(s)
    38.5%
  2. Yes for rattles My Prius was made at Tsutsumi plant line # 2 (code 1)
    5 vote(s)
    12.8%
  3. Yes for rattles My Prius was made at Fugimatsu plant (code 5)
    2 vote(s)
    5.1%
  4. No for rattles My Prius was made at Tsutsumi plant line # 1 (code 0)
    9 vote(s)
    23.1%
  5. No for rattles My Prius was made at Tsutsumi plant line # 2 (code 1)
    4 vote(s)
    10.3%
  6. No for rattles My Prius was made at Fugimatsu plant (code 5)
    4 vote(s)
    10.3%
  1. phoenixgreg
    phoenixgreg Senior member
    1,157
    294
    66
    Phoenix
    You’re thinking “yet another rattle thread”, but no one has put together a survey to determine how many members here have experienced rattles (the term “rattles” to also include plastic ticking/rubbing sounds or creaking sounds) in their G3 Prius. This survey/poll will attempt to get a trend as to where and when your Prius was manufactured as it relates to rattles or rattle-free operation. Also, your climate could be a factor.
    In order to participate, please locate the highest sticker inside the driver’s door frame – it is black with white lettering. In the upper right corner of the sticker, you will find the manufacture date of your car in the format of MM/YY.
    Also, just above the bar code in that sticker is the VIN #. Look at digit # 11 and it should have one of three possible values:
    0 = made in Tsutsumi plant line # 1
    1 = made in Tsutsumi plant line # 2
    5 = made in Fugimatsu plant.
    Please make a note of these values before proceeding. Then post the month and year of manufacture after taking the poll.
    If you answered YES that your G3 Prius has or had rattles, Please feel free to copy and paste the below survey into your post after the manufacture date. Then place an X in front of the answers that pertain to your rattle experience. I will periodically tally the answers to into a summary so collectively we can discover any trends.
    PLEASE – this is not a thread for complaints…there are plenty of those threads already. We are just interested in statistics that could lead us to some conclusions about why rattles happen in some Prii.
    The rest of the survey should be easy to complete. Thank you for participating.
    Copy and paste below survey with your answers and insert an X before all that apply
    My Prius was manufactured on (replace MM and YY with the information on your sticker):
    MM/YY
    My Prius spends most of the time in:
    __a mild climate
    __a mostly rainy climate
    __a mostly arid (sunny) climate
    __a climate with severe winters
    __a climate with severe summers
    Did you contact your dealer about your rattles?
    __Yes, my dealership was made aware of the rattles and they repaired them
    __Yes, my dealership was made aware of the rattles and they did not repair them
    __No, I have not contacted my dealership about the rattles
    Where are (were) the rattles in your Prius?
    __dashboard
    __instrument cluster
    __upper speakers or grilles
    __A/C vents
    __“A” pillar passenger window “buzzes”
    __glove compartment(s)
    __sky bridge console
    __center console
    __headliner and/or sun roof
    __seat belt retractors
    __driver and/or passenger door(s)
    __front and/or rear seat(s)
    __rear hatch door
    __rear storage compartment
    __spare tire compartment
    __other (list here)
    2 people like this.
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Re: Pease take the Prius rattle survey
    04/09 production date
    __a mild climate
    x_a mostly arid (sunny) climate
    x_Yes, my dealership was made aware of the rattles and they repaired them
    x_No, I have not contacted my dealership about the rattles
    Note: I had the rear seat rattles fixed, but haven't bothered with the others
    x_dashboard
    __A/C vents
    x_sky bridge console
    __center console
    x_front and/or rear seat(s)
    x_rear hatch door
    __other (list here)
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    05/09
    _X_a mild climate
    _X_a climate with severe winters
    _X_No, I have not contacted my dealership about the rattles
    _X_dashboard
    _X_upper speakers or grilles
    __A/C vents
    _x_“A†pillar passenger window “buzzesâ€
    _X_sky bridge console
    _x_center console
    _X_headliner and/or sun roof
    _X_rear hatch door (but fixed)
    __other (list here
  4. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    MM/YY
    __a mild climate
    _X_a mostly arid (sunny) climate
    _X_Yes, my dealership was made aware of the rattles and they did not repair them
    _X_dashboard
    _X_instrument cluster
    __A/C vents
    __center console
    _X_driver and/or passenger door(s)
    __rear hatch door
    __other (list here)
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    07/09 Tsutsumi #1
    _X_a mild climate
    _X_dashboard
    __A/C vents
    __“A†pillar passenger window “buzzesâ€
    __center console
    __rear hatch door
    __other (list here)
  6. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    No rattles, 30K miles.
    05/09 Fugimatsu 5
    x_a mild climate
  7. Tideland Prius
    16,547
    07/09
    ___a mild climate
    ___a mostly rainy climate
    ___a mostly arid (sunny) climate
    _x_a climate with severe winters
    ___a climate with severe summers
    ___Yes, my dealership was made aware of the rattles and they repaired them
    ___Yes, my dealership was made aware of the rattles and they did not repair them
    _x_No, I have not contacted my dealership about the rattles
    ___dashboard
    ___instrument cluster
    ___upper speakers or grilles
    ___A/C vents
    ___“A†pillar passenger window “buzzesâ€
    ___glove compartment(s)
    ___sky bridge console
    ___center console
    ___headliner and/or sun roof
    ___seat belt retractors
    ___driver and/or passenger door(s)
    ___front and/or rear seat(s)
    ___rear hatch door
    _x_rear storage compartment
    ___spare tire compartment
    ___other (list here)
    The tonneau cover squeaks and it's the same on the old Prius. The centre console box lid creaks if I put pressure on it (it didn't do it when new). I'm only listing warm weather creaks and squeaks since cold weather does funny things (I'll hear the moonroof creak for example)
  8. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    No rattles - 45K
    ___a mild climate
    _x_a climate with severe summers
  9. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    08/09
    __a mild climate
    X a climate with severe summers
    X No, I have not contacted my dealership about the rattles
    X dashboard
    X instrument cluster
    __A/C vents
    X glove compartment(s)
    X center console
    __rear hatch door
    X Driver "A" Pillar (Right hand drive)
  10. Cactuscoug
    Cactuscoug CactusCoug
    77
    Redmond, Oregon
    10/09
    __a mild climate
    X Yes, my dealership was made aware of the rattles and they did not repair them (Twice attempted)
    X dashboard
    __A/C vents
    X sky bridge console
    __center console
    __rear hatch door
    __other (list here)
  11. phoenixgreg
    1,157
    294
    66
    Phoenix
    01/10
    __a mild climate
    X_a climate with severe summers
    X_Yes, my dealership was made aware of the rattles and they repaired them
    X_dashboard
    X_A/C vents
    X_“A” pillar passenger window “buzzes”
    X_glove compartment(s)
    X_center console
    X_seat belt retractors
    X_front and/or rear seat(s)
    X_rear hatch door
    X_rear storage compartment
    __other (list here)
    Thanks to all who have replied so far, I will tally results as trends develop and update the primary thread with the data.
    PLEASE BE SURE TO POST YOUR PRIUS DATE OF MANUFACTURE IF YOU TAKE THE POLL
  12. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    Great thread; thanks for your efforts!
    It would be interesting to also chart which country received the majority of specific plant rollouts. Since most PC'ers are posting from USA the figures may lean more towards one plant compared to another. ?
  13. JACoH
    JACoH Enjoying the mileage
    193
    40
    Oregon
    09/09
    __a mild climate
    X_a mostly rainy climate
    _X_dashboard
    _X_A/C vents
    _X_“A†pillar passenger window “buzzesâ€
    _X_glove compartment(s)
    _X_center console
    X__driver and/or passenger door(s)
    __rear hatch door
    __other (list here)
  14. blake918
    blake918 Blizzard Brigade #23
    52
    Metairie, LA
    07/10, 11,000 miles, was rattle (tick) free for the first 300 miles. LOVE the car, but this is a bad showing for a car maker who used to make cars that just wouldn't rattle.
    __a mild climate
    _X_ a climate with severe summers
    __dashboard
    _X_instrument cluster (the trim piece around the speedo/MID)
    __A/C vents
    _X_“A” pillar passenger window “buzzes”
    __center console
    __rear hatch door
    _X_other: The seat adjustor on the front passenger's seat rattles if the seat is slid all the way back -- stops if I move it one click forward, I get a loud click from the exterior of the car when I hit some bumps, dealer was no help, but doing some reading here, it sounds like it is something with the brakes.
  15. taxachusetts
    taxachusetts Junior Member
    39
    Boston
    I have two Prii, the one described below (a '10) and an '11. The survey won't let me enter two vehicles. The 2011 was made in 03/11 in Tsutsumi #2. It has no rattles as yet (2,200 miles).
    08/09
    X a mild climate
    _X_dashboard
    __A/C vents
    __center console
    __rear hatch door
    __other (list here)
  16. Tideland Prius
    16,547
    Methinks it's something to do with switching from screws to plastic clips. They save weight for sure (just imagine how many screws there would've been) but clips do allow for some movement of plastic parts vs. screws.
  17. AllenL
    AllenL New Member
    Just posted about how sensitive I am to rattles. I am a fairly new owner of a G3 Prius V. I am always listening for rattles. Somehow my average hearing is dog-like compared to dealer service managers. I don't hear any yet and our car lives mostly in the garage or sunny environments.
    06/11
  18. Carzone
    Carzone New Member
    33
    Toronto
    My Prius was manufactured on 01/2010 at Tsutsumi plant line # 1 (code 0)
    __a mild climate
    X a climate with severe winters
    X Yes, my dealership was made aware of the rattles and they repaired one rattle successfully (Rear seat).
    __dashboard
    __A/C vents
    X glove compartment(s) (lower glove box)
    __center console
    X front and/or rear seat(s)
    X rear hatch door
    __other (list here)
    PS: If your prius has the same rattles as mine, please check my recent post. Maybe you can fix them by yourself.
    http://priuschat.com/forums/gen-iii...2011-prius-rattles-99-cents-neat-version.html
    My Prius has been "rattle free" for 3 months after the fix.
  19. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    02/10
    __a mild climate
    _Xa climate with severe winters
    _XYes, my dealership was made aware of the rattles and they did not repair them
    _X_dashboard
    _X_A/C vents
    __ sky bridge console
    _X_center console
    _X_front and/or rear seat(s)
    _X__rear hatch door
    __other (list here)
  20. chevron
    chevron New Member
    67
    Rhode Island
    __a mild climate
    __dashboard
    __A/C vents
    __center console
    __rear hatch door
    __other (list here) My Prius has 12,500 miles , built in the # 0 plant ,no rattles at all to date
