Window chopped off my dog's tail!
Discussion in 'Gen 2 Prius Main Forum' started by FastMovinHeel, Aug 22, 2011.
  1. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    This is a TROLL posting....no such thing...
  2. fuzzy1
    10,603
    I had to test this, with a pencil substituting for a tail, and am not fully comforted by the results.
    On three windows, not possible. Over numerous trials in multiple locations, the windows reversed under very light pressure.
    The fourth window also reversed under light obstruction over most of its width. But over a few inches next to the B pillar, it did not reverse at all. The pencil emitted crunching noises, and now has eight very deep gouges.
    While I find a tail amputation very atypical, I can't dismiss it as impossible under all circumstances. No way in h*ll am I going to retest this section with my fingers.
  3. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    You could always try a piece of raw meat on a thin wooden skewer.
  4. qbee42
    3,079
    Was this on an angled section where the window acts like a shear?
  5. qbee42
    3,079
    Photo evidence:
    Tom ;)
  6. WE0H
    WE0H Senior Member
    3,247
    528
    I just tested the windows on the rental Prii I am driving right now and all four windows stopped then went down with a pen used as a tail :) Even tested with the pen in the corners and they always went down after touching the pen.
    Mike
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I would think a HOT DOG would make a perfect test material....
    I would think Hebrew National Hot Dogs would work great, after all they answer to a higher authority, and when the test is over, you can eat the results..... :D
  8. fuzzy1
    10,603
    Driver's window, within four inches of the B pillar. I can't see any reason why it behaves different than the same sections of the other three windows.
  9. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I bet the neighbours weren't fully comfortable with you mooning them like that. I don't even want to know how you either held or affixed the pencil. :eek:
  10. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    So any actual test finger results?
    (I like the hot dog idea, as long as it's not dachshund variety)
  11. 2009Prius
    2,705
    512
    63
    Hot dog is too soft. You might as well use tofu if you want.
  12. marzprius
    marzprius Junior Member
    92
    Northcoast
    Only auto up / down windows have the reverse function, so pre 2010 only the drivers window - 2010 & 2011 all 4 windows will reverse.
  13. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    What about other body parts?
  14. Trebuchet
    Trebuchet Senior Member
    3,772
    936
    43
    I tried that with a Corndog but my window broke! Guess I should have thawed it first. :rolleyes:
    You are one sick puppy, please add your thoughts to this NSFW list.
  15. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Hmm...
    The debate on this thread seems to center around it's "possibility". Is it a troll thread? Or could this really happen?
    Well congratulations to the OP in either case. If you are a troll? You got numerous Prius owners to run out to their vehicles and insert phalic symbols into their windows...in an attempt to see if damage was possible...
    If you are NOT a troll and you now have a tail less dog...sorry about the dog. But I would say that indeed this is something Toyota would want to design against happening. If your 2008 Prius did inadverdently become a Doggie Tail Guillotine? Then it's a failure of design.
    One post...no follow up...no 1000 word picture of a tail less dog with a cone around it's head...???
    I'm suspicious to say the least about the validity of this reported happening.
  16. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    You're assuming it was a meat hot dog. What if a Tofu Pup was used as the test phallic object?? :D
  17. KK6PD
    4,003
    946
    118
    Tuff call, you try something else first, let us know how that works out! :D
  18. green4u
    green4u New Member
    115
    CA
    Alright I'll say it - so who's gonna stick their d**k in there?
  19. fuzzy1
    10,603
    This was in the privacy of a closed room (garage), where snooping will get them in trouble with the state's anti-voyeurism laws.
    I will leave that to your imagination.
