how do you warm up the prius in the winter?
Discussion in 'Gen 3 Prius Main Forum' started by justintiime, Aug 23, 2011.
  1. justintiime
    justintiime Junior Member
    64
    Moneta, VA
    In the past years I've went out and warmed up my fiancees car for her commute to work so the car would be a bit warmer, and reach operating temp much quicker so she wouldn't freeze.
    What do I do in the prius? Will the engine turn on automatically?
  2. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    If you want decent mpg - you don't....
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    yes
  4. justintiime
    64
    Moneta, VA
    I dont care about mileage when it comes to freezing for 5 minutes or not :)
  5. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    On cold days here when I start my Prius I turn heater temp to HI and fan on HI. This usually keeps the motor running till warm!This car seems to warm up fast when driven.
  6. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Put in a block heater & use a timed outlet to preheat the engine for a few hours before the commute.
  7. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    Seeing that you're in VT (with no heated seats!!), I'd look into the block heater option like Dark matter mentioned.
  8. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I warm mine in the winter the same as I do in the summer - start it and drive it!
  9. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    I wear my winter jacket and drive. If I have to use the defroster/heater I do. But I shut them off at stoplights, otherwise the ICE keeps running. I find the heater to be much less efficient than the A/C in summer.
  10. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Heat comes faster from an engine being used. So, the get in and drive right away works well if you're like most who wouldn't have anywhere warm to wait after work anyway. That's true for any vehicle, not just Prius. However, Prius does have the advantage of a system carefully designed for heat-retention since heat is also used for cleansing emissions.
    Long story short, you have choices available.
  11. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    We had some of the coldest winter weather in years this past winter. I have about a 3 block drive in a residential neighborhood before hitting a main thoroughfare.
    I just get in and drive slowly through the neighborhood. By the time I hit the thoroughfare the engine is warm and blowing warm air in the cabin.
    Same thing in the afternoon in the parking lot at work.
  12. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    "Warm heat"??? ;)
    You can block some front grills, install a block heater, even install an electric heater for the cabin.
    The car will still be cool when starting out. But the good thing is the Prius does warm up quickly. But only if driven. It takes a long time to warm up when idling. The engine won't run past the "warm the cat cycle" unless you have the interior heater on, demanding heat. If you start out and have to wait at lights for the first 5-10 min it's a cold drive! It doesn't warm up fast waiting at lights. But driving, it warms up in a few blocks at 40 MPH.
  13. qbee42
    3,079
    I get in and drive, and that's with a Gen II Prius. The Gen III heats even faster.
  14. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    You can add another 10 minutes to that if the windscreen is frosty, it is slow to warm up on idle. It warms up pretty quick when being driven, but you can't really drive with a frosty windscreen. I suppose you could spray de-icer on but it's not good for the paintwork when oversprayed and doesn't do much for the wiper blades. Oh how I miss my Ford quickclear heated front screen.
  15. Mendel Leisk
    41,302
  16. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    just my .02
    turn on the front and rear defrosters... the front defroster keeps the compressor on which helps reduce humidity and keeps the engine on... it also initiates (as does high fan, etc) the electronic heaters. this helps take the chill off faster.
    with the temp set to 74 to 76 and defroster on, it will warm up the engine and cab automatically and not over heat the cab.... high settings can make it too warm... just in-case you get distracted inside...
  17. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    When it's really cold, I leave the car running with defrost on. By the time I've scraped the windows, the interior is warm - probably warmer than it needs to be, since I've just been 'exercising' while dressed in Winter clothing. ;)
    On not-as-cold days, when the windshield needs only to be cleared of moisture on the inside, the interior is also sufficiently warm by the time I can see where I'm going.
    I'm sure a block heater and grille blocking would improve efficiency and speed cabin heating, but the general idea is to get in and drive it. There's no point sitting there freezing, waiting for the engine's excess heat to warm you up - the Prius is designed to be more efficient than that.
  18. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    The ICE is not used to charge the battery or provide power to drive the car until it gets out of stage 1a, about 104 degrees F. There are exceptions, if the battery is very low or you really put your foot in it, it will use the ICE in stage 1a.
    So normally from the time you go to Ready until the ICE hits 104 degrees you will be running on the battery. This is power that has to be put back into the battery when the car warms up. In some cases it might save energy (i.e. gasoline) to set in the driveway and let it warm up to over 104 before you drive it. As far as I know this is an untested theory.
    There are exceptions of course, if you live at the top of a long hill, for example, you can coast down the hill while it warms up enough to use the ICE for power.
    If this interests you here is a reference thread. There are also some interesting rebuttals to the assertions in paragraphs 1 and 2 above
    http://priuschat.com/forums/gen-iii...-discussion/76501-gen3-warming-up-stages.html
  19. garglo
    garglo Member
    99
    45
    Port St Lucie, FL
    2020 Prius Prime
    I put a small 1500w heater in the back with the cord hanging out the hatch. Extension with a timer 30min before I go out, snow just pushes off and no ice to scrape. Screwed the heater to a square of paneling, fold down rear drivers seat, no problem after 3 winters.
  20. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    Block heater then drive slow and the ICE will warm up quickly. Do NOT idle in the drive way.
