2012 Camry / Camry Hybrid to be Revealed on 8-23
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by DeadPhish, Aug 22, 2011.
  1. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    No more spy shots and less speculation. The 2012 Camry and TCH will be revealed Tues 8-23.
    Toyota USA Newsroom | Global Launch of All-New 2012 Toyota Camry
    2 people like this.
    51,549
    new hycam this fall? this is great news!!!
  3. bedrock8x
    bedrock8x Senior Member
    1,483
    137
  4. drees
    drees Senior Member
    1,782
    247
    Wow, did you see the EPA ratings for the Camry Hybrid?
    43/39/41 for the LE model
    41/38/40 for the XLE model
    (city/hwy/combined)
    Drop in fuel economy for the XLE is likely primarily due to the larger wheels/tires 215/55/R17 vs 205/65/R16 on the LE.
    HUGE step up from the current model and beats the Ford Fusion Hybrid!
  5. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    This should go over well with the general public - they get their midsize car, 200hp, and 41 combined mpg. I predict there will be high demand for this car, depending on the price $.
  6. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    hybrid:
    non hybrid SE:
    non hybrid XLE:
  7. tcooper185
    tcooper185 Member
    122
    Rock Hill, SC
    And lower MSRP than the 2011 Camry ($25,900)! Well played, Toyota.
  8. StuffOnARock
    StuffOnARock Member
    98
    26
  9. Rybold
    2,760
    322
    Southern California
    It looks like they gave the hybrid the same outside appearance as the high-end model - an indication that Toyota does Not want the Camry hybrid to be perceived as the economy version of the Camry, but rather as a high end version. This could indicate a steep price tag.
  10. dipper
    dipper Senior Member
    1,242
    252
    Wonder if the Lexus CT performance version will get this TCH treatment. Imagine more power AND mpg for the upgrade package.
  11. dipper
    1,242
    252
    And still no Lithium battery. Probably waiting for Ford to ante up on the next Fusion hybrid.
  12. fredthepostman
    422
    boothwyn pa
    With the lower prices on Camry, does this mean the V will also have lower prices than predicted ???????:rolleyes:
  13. tcooper185
    tcooper185 Member
    122
    Rock Hill, SC
    The all important trunk space answer:
    Traditional Camry: EPA Cargo Volume 15.4 cu. ft.
    Hybrid Camry: EPC Cargo Volume 13.1 cu. ft.
    Passenger volume is the same in both cars.
    Also, the Hybrid LE is 3,417 pounds, and the traditional LE is 3,190 pounds.
  14. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    I don't get why the hybrid needs a 17gal gas tank.
    Why not do a 10 or 12 and keep full trunk volume?
  15. tcooper185
    tcooper185 Member
    122
    Rock Hill, SC
  16. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    The trunk is bigger (13.1 vs. 10.7 cu.ft) than the much hyped Sonata hybrid with Lithium battery.
    Camry hybrid is also lighter (3,417 vs. 3,483 lbs) than Sonata hybrid. This is a big deal because Hyundai hyped their hybrid system is lighter and cost less.
    Both cars cost virtually the same. However, I have not compared the standard equipments.
  17. essaunders
    essaunders Member
    195
    NH
    Seriously Toyota, couldn't you have fixed the trunk?
    The pittance of a passthrough is a real downer. perhaps I'll just stick with my hatch and wagon....
  18. austingreen
    austingreen Senior Member
    13,664
    4,204
    Austin, TX, USA
    You don't need 17, but I'm sure its less expensive to build one gas tank for all the camries. The new trunk is much bigger than the old one, the only problem with it seems to be shape from the photos.
  19. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Lithium just for the sake of Lithium?
    Besides an increase in cost, how would Lithium improve the efficiency of a non plug in car?
  20. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    then shouldn't they be getting more then .26 from Prius??
