What's a pips worth?
Discussion in 'Gen 3 Prius Fuel Economy' started by cproaudio, Aug 23, 2011.
  1. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Anyone try to track the distance each of the 10 pips can be driven? Not all pips are created equal. The 9th pip has the shortest distance of all the pips.
  2. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    YMMV.
    I've found that #1 can last up to 200 miles. #2 and #3 only go about 30-40 miles each. For me, #9 goes around 50 miles.
  3. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    Probably the one thing everyone can agree on is that the worth of one pip is more than a mile but less than a hundred.
    If you want to estimate the distance of a tank, simply take the last refill amount and multiply by your lifetime mileage average. Then ignore the pips altogether until the last one blinks.
  4. cproaudio
    2,401
    762
    CA
    Of course mileage may vary. Same with tank total but people are reporting them anyway. You're gonna have track each pip with Trip A and tank total with Trip B. Then figure out how many gallons each pip represent. 1 pip does not equal to 1 Gallon of gas. The first and last pip can represent as much as 4 gallons.
  5. Bootjacker
    Bootjacker New Member
    29
    Mariposa, Ca 95338
    Depends on how you fill the tank. If you fill to the very top of the filler pipe, the first "pip" can last for about 200 miles. The manual says that when you get to "0 miles left" on readout, (last pip starts flashing) you have about 1.6 gallons left. To be safe, I figure 1.5 gallons X 40 mpg (I avg 45 mpg)or about 60 miles to find a gas station. Never ran out so I can't say exactly how much gasoline left.
  6. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    Using the pips to track fuel efficiency amounts to a "guess-o-meter". Every vehicle is different.
  7. RRxing
    RRxing Senior Member
    2,546
    1,821
    NEPA
  8. Capt Ed
    Capt Ed Junior Member
    Absolutely unacceptable! Basically a $25,000.00 car without a gas guage! Are all Toyotas like this?? :eek:
  9. DavidA
    2,344
    1,820
    Chicago western burbs
    Rounding it out, it is around 50. Yet, I've driven almost 120 miles on that top pip, and less than 20 on the bottom pip. YPMV.
  10. macman408
    1,179
    367
    Apparently not. :p
  11. fjpod
    fjpod Member
    419
    72
    New York
    Actually, the value of a pip depends on whether you fill the tank from the bottom up or from the top down. Pips on top are lighter than air so they don't contain as much gas. Pips on the bottom are heavier...unless you are in the southern hemisphere and then the molecules get mixed up.
  12. F8L
    19,011
    4,083
    Grass Valley, CA.
    How do you figure it doesn't have a gas gauge? Is there not something that tells you how much fuel you have in the tank? Do you not average approx. the same number of miles per tank before refilling? Sheesh :p
  13. F8L
    19,011
    4,083
    Grass Valley, CA.
    It can all be explained in quantum theory. The act of observation can skew the results. There is no definite state for a pip. Kinda like Schrödinger's cat.
  14. Minion
    Minion New Member
    New Jersey
    What if we cover up the pips? Do we still know they are behind the cover? How can we be sure?
  15. F8L
    19,011
    4,083
    Grass Valley, CA.
    We know the pips are there even if covered up because the car is still moving but we don't know how many pips are there.
  16. cproaudio
    2,401
    762
    CA
    If anyone care to try this, fill up the tank and stop at the first click, reset both Trip A and Trip B. At the first pip disappearance, reset Trip A, record the mileage for each of the 10 pips. On the last pip, record the mileage driven on the last pip while it's solid, reset Trip A when it starts blinking, reset again when DTE reaches 0, The last Trip A records how far you've driven on 0 DTE before filling up. The number of the pip should represent visible pip. So, when you fill up your tank, you have 10 pips. That's the 10th pip. Your record should look something like this
    10th pip - 80 miles, 65 AVG MPG on MFD, 60MPG calculated, 1.333 gal
    9th pip - 40 miles, 65 AVG MPG on MFD, 60MPG calculated, .6666 gal
    8th pip - 60 miles, 65 AVG MPG on MFD, 60MPG calculated, 1 gal
    7th pip - 60 miles, 65 AVG MPG on MFD, 60MPG calculated, 1 gal
    6th pip - 65 miles, 65 AVG MPG on MFD, 60MPG calculated, 1.0833 gal
    5th pip - 65 miles, 65 AVG MPG on MFD, 60MPG calculated, 1.0833 gal
    4th pip - 60 miles, 65 AVG MPG on MFD, 60MPG calculated, 1 gal
    3rd pip - 55 miles, 65 AVG MPG on MFD, 60MPG calculated, 0.91666 gal
    2nd pip - 55 miles, 65 AVG MPG on MFD, 60MPG calculated, 0.91666 gal
    1st solid pip - 40 miles, 65 AVG MPG on MFD, 60MPG calculated, .6666 gal
    blinking pip - 20 - This shows how accurate the 27 mile DTE estimate is.
    0 DTE - 50 - This shows how far you've driven when the distance to empty shows 0.
    Total miles on trip B 650 miles
    report total gas pumped, and Trip B's AVG MPG and calculated MPG. We can get the accuracy of MPG on the MFD vs calculated MPG.
    If you can, fill up the tank again at the same gas station, same pump, same time and temperature. Do a little calculation will show how much gas each pip represents. The 10th pip will be irrelevant but will be nice to know what the average is. It's the 9th - 0DTE that I'm interested to see.
  17. qbee42
    3,079
    Your Prius could be out of gas and full at the same time!
