05' getting 40mpg if I'm lucky
Discussion in 'Gen 2 Prius Fuel Economy' started by recycleman, Aug 25, 2011.
  1. recycleman
    recycleman Junior Member
    43
    Chandler
    Prius was getting 45/46 in the Summer and 47/49 in the winter here in AZ.
    January of this year the car went in for a recall and a couple of other things and since then, mileage has continuously dropped.
    I'm now at 40mpg flat and cannot get out of it. I've had it to the dealer twice now to see if they could see anything out of the ordinary and it's all within spec.<not sure if they checked alignment and we all know how the OIL LEVEL spec is.
    I will say this, I primarily used the CRUISE CONTROL on my commute to let the car do the work. The bars on the MPG seemed to be stuck at or just under the "50" mark when cruising along and seem to take longer once on a hill descent to shoot-up. This is for both city and highway. Throttle seems to be A LOT MORE sensitive and off<just my opinion since the recall.
    I will be checking the oil level of the vehicle tonight and probably getting it to an alignment shop that just does alignments also.
    Here are the Q/A's below.
    - What fuel economy are you getting and how are you determining fuel economy? (trip computer or manual calculations)
    COMPUTER
    - What fuel economy are you expecting and why?
    45-49
    - What are the approximate outside air temps?
    105-115
    - How long are your trips?
    12 MILES ONE WAY
    - How much of it is city vs. highway? Roughly what's the average speed in overall and and of each segment? Is there a lot of stop and go driving?
    75% highway, 25% city
    - What region/state are you in? (if you haven't set your location in your profile)
    Phoenix, AZ
    - What's the terrain like of your drives? (e.g. flat, gentle hills, steep hills, etc.)
    Pretty flat...
    - Is your oil overfilled? (i.e. above the full mark on the dipstick)
    Not checked
    How old is your 12v battery? What is the voltage reading of your 12v battery after sitting over night? (Method Here)
    brand new, toyota battery
    Have you had your alignment checked? Any pulling or abnormal tire wear?
    Not checked
    - Are you using the factory tires and wheels? If not, please indicate tire make, model and size (e.g. Goodyear Assurance Fuel Max 185/65R15).
    Bridgestone's low resistance. same size.
    - What are your tire pressures?
    was 40/38, changed back to 32/32 per toyota
    - Make, model, year, engine and transmission of previous car? (e.g. 08 Honda Civic Si 2.0L 4 cylinder, manual transmission) What did you actually get on the same trips/commute? (Please give us actual numbers, not EPA ratings.)
    - How are you trying to drive (e.g. trying to stay in electric only?) and how hard are you braking?
    driving normal.
    - Are you "warming up" the ICE (internal combustion engine) by letting it idle after powering on?
    No ice.
    - Are you driving using D or B mode?
    D
    - HVAC settings? Are you using the heater, AC, auto mode, etc.? If using auto, what temp is it set to?
    max cold at 50% blow
    - If reporting a mileage drop, did anything significant change on your car (e.g. accident, hit a curb or big pothole throwing off alignment, oil change/other maintenance/repairs, changed tires or wheels, etc.) or your commute?
  2. eadams44
    eadams44 New Member
    17
    Jonesville, SC
    Besides the oil level and alignment, I would definitely take the tire pressure back up to where you use to run it.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    ditto on the tire pressure. I think at those temps with AC working and that much highway..you're probably not too far out of target for MPG.
  4. recycleman
    43
    Chandler
    I would agree on the AC and temps, except same commute last year and now the mileage is considerably down. Temps are comparative to last year also.
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  6. recycleman
    43
    Chandler
    Brand new battery and Toyota just had the car to review everything. I'm almost leaning now towards the inverter/pump system didn't have either pump installed correctly(doubt it) or the coolant system didn't get purged correctly. I'm willing to drop $120.00 on Toyota to do a flush and re-do the whole cooling system on the car if it fixes this issue.
  7. wjtracy
    wjtracy Senior Member
    11,372
    3,609
    Northern VA (NoVA)
    When you say 12v is brand new, how brand new?
    Believe it took me a 1-2 tanks to get back to normal MPG.
  8. recycleman
    43
    Chandler
    I'd say I'm on my 3rd tank. Toyota service guy also stated that the car has a "re-learning" period after a new battery install but my problems come directly after the January recalls. I'm going to try to purge the air out of the coolant from the inverter tonight to see if that helps based on my other post that is more specific about that issue.
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    Not withstanding any other problems you may be experiencing, the max AC use is hurting your mpg. I've observe ed a 10mpg drops when first starting the AC to cool the cabin down from 95°+ temps. Eventually this loss levels off when the cabin cools down. However, I tested this again the other day when it was 100° and the loss stayed at appox. 10mpg for over 10 minutes before I got tired of the loss and turned the AC off and rolled down the window. The instantaneous mpg reading always jumps up 10mpg when I turn the AC off in those extremely hot conditions.
    The point is, if you run short trips with the AC maxed you will lose quite a bit in terms of fuel efficiency.
    To test this try driving with the AC off and windows down or set the AC at 78° or higher.
  10. recycleman
    43
    Chandler
    Air conditioning is running at MAX COOL with the fan running at 50%. I ran this the same way last summer also on my commutes and have tried to just turn it off on the commute but did not see any difference.
  11. F8L
    19,011
    4,083
    Grass Valley, CA.
    Have you tried turning it off and on and watched the mpg change?
    I don't expect this to be your only problem but it doesn't help. That is why you have been getting mid 40mpg during the summer vs. winter.
    Given your hot temps are you hearing the HV battery fan running?
  12. recycleman
    43
    Chandler
    Is that near the passenger rear seat?
    Thanks
  13. F8L
    19,011
    4,083
    Grass Valley, CA.
    Yup. :) You'll see the vent.
  14. recycleman
    43
    Chandler
    Yea, that runs time to time. Runs loud in my opinion also.:D
  15. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    Santa Fe, NM
    Running loud == max setting. If you battery is that hot, then you do not get the benefit of boost or regeneration. Fuel economy suffers dramatically, turn Prius into Tercel. I've had it come on in my 2005 a few times this year, vs. only once the year before and never before that. It could be a sign of age. Notably, in my 2005, it will come on if I park it at 7 green bars SoC and take the next trip within the next 30 minutes - 2 hours.
  16. recycleman
    43
    Chandler
    I'm now starting to think the new battery wasn't broke in properly and when I go to start-up the car in the afternoon, I have only 2 bars showing on the battery display. I'm going to keep the AC off in the car and suffer in the 115* heat to see if this helps DRAMATICALLY.
    Thanks for everyone's input.
  17. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    if you hear the battery fan at all... it's not cooling as well as it should. you probably need to clean the fan. mine was caked up 25% on the edge of the blades and a little more in the center of the blades... which basically says to me that the fan has completely failed.
    if you start off at lower bars, it tends to suggest your battery is turning off hot.. as the temp drops, the voltage drops to a normal level... which is a lower SOC than it thought.
    clean the fan so you're car can pull a proper amperage at a proper voltage and not create excess heat in the process.
  18. recycleman
    43
    Chandler
    Will do. I'm starting to see the overall issue with how the car works. Age on these vehicles don't help it either. If the fan is indeed pretty nasty, I would think the Toyota tech would have "briefly" inspected this to notify me if this has ANY potential to cause a drop in MPG.
    Thanks!:rockon:
  19. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yeah the fan isn't on their maintenance schedule and the tech's don't seem to know much about it. :(
    Anyway, take a look at this thread here where I've posted some pictures of how to access the fan and what mine looked like before I cleaned it.
    See http://priuschat.com/forums/gen-ii-...ur-dirt-causing-major-battery-problems-4.html
  20. recycleman
    43
    Chandler
    Thanks for the link.
    What really gets me is the service ADVISOR told me flat out that when it comes to these cars, most times the CUSTOMER knows more about them then he does.:confused::confused::confused::confused:
    Tech went through the checklist but I have a feeling A LOT of owners FEEDBACK falls on deaf ears(ADVISOR) and the communication between the owner and TECHNICIAN is non-existent. I bought the car not wanting to be heavily involved with the car's mechanics but it appears no getting around that.:D
