An overhead light "Did you know?"
Discussion in 'Gen 3 Prius Main Forum' started by Jetboy, Aug 27, 2011.
  1. Jetboy
    Jetboy New Member
    Great Lakes Bay Region Michigan
    Did you know that you can turn the overhead light on by pushing in the light itself?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Do you mean the map lights? Yes.
  3. Jetboy
    Jetboy New Member
    Yes, I was referring to the map lights. So is this common knowledge? I found it out by accident.
  4. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    It is a quite common feature on many automobiles by numerous makers.
  5. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    there is a lot of FAQ items you should probably look through.
    1st. read your owners manuals... all of them. they'll tell you a lot of helpful stuff that could ease your frustration down the road.
    2nd. jot down a keyword or two regarding a question you may have into the priuschat custom search on the top right hand side of priuschat while you're in a forum, (not sure if it's available on main page)
    3rd. browse priuschat. some go through the forums, others grab new topics off the main page. there is also a backlog of recent post. if you're on an smartphone, there are reader apps that work with priuschat.
    4th... only if none of that works... create a post and ask. a lot of members have a lot of answers on here.
    5th. welcome to priuschat.
  6. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    That only applies to non-SRP Prii. For those with the SRP, there's a button to push to turn on/off.
  7. Tideland Prius
    16,623
    Yeah it's the maplights (hence the 3 dots on the cover). As HI MPG states, it's on non SR models. Those with the Solar Roof will have a different overhead design with an actual maplight button separate from the lighting.
  8. macman408
    1,179
    368
    The different styles are actually dependent on whether the car has the Safety Connect system or not - so my V has the same design with separate buttons for the map lights. Looks like that currently means that any Four or Five with the Nav package (and maybe the Three too - the Toyota website is inconsistent with itself whether the Three's Nav system has Safety Connect) should have the buttons.
  9. steveb123
    steveb123 New Member
    New York
    Yes I have seen this feature in many cars.
  10. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    I accidentally hit the light/switch with my head. -- A head operated switch. What will they think of next???
    Keith
  11. RoyThePriusGuy
    RoyThePriusGuy New Member
    186
    25
    phoenix
    Did you know the horn sounds if you press the area in the middle of the steering wheel?
    If not check the owners manual.
  12. V8Cobrakid
    3,790
    152
    lol Roy... i was tempted to post a similar comment... only because i saw a ("radio did you know" forum)
  13. theloop82
    theloop82 Member
    Spanaway, Wa
    Did you know that if you crash your Prius into a brick wall a lot of bags will pop out all over the place?
  14. Much More Better
    Much More Better Active Member
    655
    163
    ok...now we're being just a-holes....but it's still funny.
  15. goober_nut
    goober_nut Member
    68
    Champaign, IL
    My 3 with nav and solar doesn't have safety connect.
  16. goober_nut
    goober_nut Member
    68
    Champaign, IL
    Speaking from experience, those bags aren't nearly as comfy as they look. They're really hard and hurt when they hit you, but hey I guess it beats your head meeting any other part of your car.
  17. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    To Jetboy - the OP of this Thread.
    Apparently you're new here and your posting was honest and trying to be helpful.
    Some of the responses sure might seem as biting and negative - but consider them as friendly bantering. As if you were out for a couple beers with buddies and they were joking with you about a topic you brought up.
    (Almost) All of us are friends here and appreciate input, but sometimes we may need to have a bit of fun too. Don't take it personally and enjoy your ride.
    3 people like this.
  18. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Well said Dean. OP, I have the push on lights as well. It beats scratching for a small switch in the dark. :p
  19. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    I've had airbags blow on my face twice. Didn't even feel a thing.
  20. qbee42
    3,081
    Didn't feel a thing, or don't remember a thing?
    :D
