Center Armrest Too Low for Comfortable Driving. Any Solutions?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by skilbovia, Aug 29, 2011.
  1. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    I find that that the center armrest in my Gen III Prius is too low by about an inch or two to support a comfortable driving position for me. It is literally causing a pain in my neck on long trips. Has anyone had this problem and resolved it?
    And while I'm at it, I find that I rest my arm on the windowsill because the door arm rest is really too low. Any solutions for this?
  2. qbee42
    3,079
    Gangster lean:
    [ame="http://en.wikipedia.org/wiki/Gangsta_lean"]Gangsta lean - Wikipedia, the free encyclopedia[/ame]
    6 people like this.
  3. GoldPianoGarden
    GoldPianoGarden Bling Meister
    841
    74
    98
    Brunswick, GA
    You're not right! lol! I have just recently been trying more and more to be aware of myself sitting with my left "cheek" up on the side padding of the seat, rather than sitting centered-up in the seat, which has my body kinda tilted toward the right side in a jacked up fashion (probably not good for my back in the long haul...), and I think I do it cause it allows my right arm to be just the few inches lower that it can rest on the center armrest... I ended up rigging the situation by put a matching bath towel, folded a few extra times, on the center armrest. So, now I can sit centered up in the seat and still rest my elbow on the armrest if I desire. So, moral of this story, I have also noticed this issue and had to come up with a less-than-ideal work-around.
  4. ChaiLove
    ChaiLove Junior Member
    32
    Virginia Beach, VA
    check out this for the console:
    autosportcatalog.com/miscellaneous-comfort/armrest-console-cushions.cfm
    and for this for the window side:
    autosportcatalog.com/miscellaneous-comfort/arm-restler.cfm
    you have to add the www before those because it won't let me post links yet
  5. Tideland Prius
    16,597
  6. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Rather that wasting a good Phonebook. I would grab some foam, you determine how squeezy you need and add it to the height of the center armrest. Find some nice leather of your liking at a Fabric store. You can apply this yourself. It's such a small piece you should be able to knock it off in a weekend.
    If you do, please post your results!
  7. MrBillTulsa
    MrBillTulsa Member
    174
    35
    In the hills west of Tulsa
    2012 8-way power adjustable seat?
    :eek:
  8. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    I had never thought about this but I tried it out today. I find the center armrest to be a perfect height for me & I'm 6'2" tall. I asked my wife & she found it perfect too & she is only 5'3" tall.
    Now the door armrest is too low for both of us & I rarely use it. :mad:
  9. Tideland Prius
    16,597
    10-way if you include lumbar support.
  10. Much More Better
    Much More Better Active Member
    655
    163
    Maybe lower your seat.
  11. Zedknepplin
    Zedknepplin semper prius
    124
    65
    162
    Georgia
    I bought some hand towels from Target that match the interior color and folded them up. My boss liked the idea and did it with his Nissan Z.
  12. Danger
    Danger Member
    175
    22
    Frisco
    Any one know if someone makes an aftermarket center console that is like the Prius V. I like how there is a cut out for the cup holder and your still able to get into the storage.
  13. GoldPianoGarden
    841
    74
    98
    Brunswick, GA
    Ditto for the towel thing! I did it, too, just a few days after we bought my car! lol
  14. Pfcardwell
    Pfcardwell New Member
    39
    St. Louis
    I designed a Prius Pillow for the driver side. Perfect match with dark Gray cloth seating
  15. Pfcardwell
    39
    St. Louis
    My son gave me tube socks stuffed into one tube sock for Christmas i use that on the right hand side for very long trips. It works.
  16. Pfcardwell
    39
    St. Louis
    Storage area for Prius pillow and the Prius tube sock pillow
  17. Kachoo
    Kachoo New Member
    Richmond
    I like the pillow idea.
  18. d2mini
    d2mini Active Member
    519
    106
    Houston
    :pound:
    I like your kid's sense of humor.
  19. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    Love these suggestions! Between the Gansta Lean to the Prissy Prius Pillow, we should all be able to find a way to achieve a comfortable driving position for the elbows on the console. :)
    LeatherZ is definitely a possibility. They have the 1/4 inch cushion and for a little extra $$ they can add another 1/4 inch of cushion. Order a set for the doors and another set for the center console armrest.
    A good piece of cushion and a good interior shop could custom build (just the right height) a nice fitting arm rest over the existing console.
    No one mentioned that if you don't want to mess with the interior, you could always just buy a quality set of elbow pads! They should be easily customizeable, too!
