2006 Main battery replacement
Discussion in 'Gen 2 Prius Main Forum' started by JSHVNFN, Sep 1, 2011.
  1. JSHVNFN
    JSHVNFN New Member
    OK, got the "screen", been looking for the video on how to replace the traction (main) battery, cannot seem to find.. Anyone know the link? [email protected]
    201,000 miles..
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    Santa Fe, NM
    I'm not aware of any video, beyond those that show installation of PHEV packs, such as
    The main issue is getting all the trim off. You need to remove everything below window level: floorboards, side trim, trunk trim, and both seat backs. The floorboard that covers the battery is a particularly difficult piece to remove the first time. The trick there is to pop the forward clip out (near the middle but slightly on the passenger side), and the slide it backwards off the two rear clips. Also, take this opportunity to clean the HV battery fan.
  3. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The instructions for SAFE HV Battery removal are available for free from Toyota.
    JeffD
