Document your MPG by doing this!
Discussion in 'Gen 2 Prius Fuel Economy' started by unigeezer, Sep 8, 2011.
  1. npyle
    npyle New Member
    Cuyahoga Falls, OH
    I've done quite a bit of reading on MDF mpg difference compared to calculated, so I started tracking this about 1 1/2 months ago. To date, there's been a 3.35% difference--MDF has been 3.35% higher than calculated method.
  2. Mendel Leisk
    41,901
    We bought in mid-November 2010, and I started tracking mileage in a spreadsheet at the outset of 2011. Basically recording the odometer at each fill-up, and the gas purchased. I reset Trip A at each fillup, to verify the odometer change, get the in-dash mileage feedback and to have a feel for miles-to-empty.
    The spreadsheet primarily uses the gas purchase and the difference between the two odometer readings, to calculate actual liters per 100 kilometer. But I also enter the Trip A liters per 100 kilometers reading, and calculate the error.
    We have the stock 17" wheels, which have slightly smaller OD than the stock 15" wheels. I would think Toyota has adjusted the odometer for that, but not really sure.
    Anyway, for the year to date, we've travelled 12135 kms, consumed 605 liters, and accordingly have an overall fuel economy of 5.0 liters/100km (it's gotten a lot better of late, car braking in, warmer weather).
    Average in-dash was 4.67 liters/100km, for an error of 6.42%.
  3. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    Wow, with all these high MPG claims, I'm surprised that Toyota has not updated their "real world" MPG stats to read closer to 60/65! :D
    So many are claiming these high averages which they apparently see as nothing that special. But then again, I've seen similar MPG claims for the Jetta GTI, and even a Hummer that gets an astounding 100MPG!
    My guess is that the vast majority of prius owners (gen 2 and 3) are averaging somewhere in the low to mid 40's range. I drive a 2004 (first year gen 2) with 125k and a seemingly sound hybrid batt pack, live in SoCal, and drive a mix of city and hwy. My average ranges from the low to upper 40's. I did just get a new set of tires, (Goodyear fuel max) along with alignment, and I've heard that brand new tires can reduce MPG a bit until they break in.
    But I admit that I don't do any of the MPG enhancing tricks, aka, "Hypermilling". I do use cruise control regularly. And I am content in the fact that I still get far better MPG than non-hybrid owners. :)
    The 2012 Honda civic hybrid is rated at 44MPG for both city and hwy, but one testing company achieved nearly 70MPG, admittedly using all the hypermilling tricks they could muster. All these examples are the exception, and obviously not the rule. If everyone drove this way, it would make airport delays look like a walk in the park!
  4. babybird
    babybird Member
    117
    44
    Colorado
    I'll be buying my Prius hopefully this afternoon but driving style can have a huge impact. My current Subaru Legacy wagon with 4spd automatic is rated at 20mpg city but by adjusting my driving style I average 23, and by inflating my tires a couple psi over the car's recommended pressure (but below the sidewall maximum) and using pulse and glide where traffic allows, and cruise control where it doesn't, I can average 27mpg even while delivering pizza and idling for quite a while at my deliveries and using a/c. That's 35% over EPA estimates for the car and the 2003 estimates were optimistic compared to today's numbers, and this in a non-hybrid, awd station wagon with an automatic. Driving style makes all the difference. My friend struggles to get 22 in mixed driving in his 05 with a manual.
  5. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Take a look at the fuel consumption pole, upper 40's is a very commonly reported MPG. The histogram looks very believable to me, the data is approximately normally distributed with a mean of about 48 to 49 MPG.
    Personally I get between 52 and 56 MPG averaged over a complete tank (over 500 miles) just about every tank.
    See this pole: http://priuschat.com/forums/gen-ii-...l-what-mpg-you-getting-in-your-gen-2-a-9.html
  6. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    How do I get accurate mpg figures with over size tyres, eg 205/55/16 witch have fewer turns per mile so that the odometer under reads the distance that I drive. I could do a calculation odo miles divided by gallons used plus say 2% but how accurate is this going to be. The only sat nav I have is the one fitted in the Prius can I use this to give me accurate distance covered.
    It could be that the MFD display will now give an accurate MPG reading since on my old tyres 195/55/16 and 3mm of tread had the display over estimating MPG by about 2.5% over calculated MPG.
  7. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    I posted the 71.2 MPG picture and was accused of pulling it off the internet and claiming it as my own. After that, I started trying to find ways to 'personalize' the pictures. That's where the sheep came in.
    I'll see if I can find more pictures for you at home.
    The one with the ScanGauge is actually from the PHV prototype. The non-Prius one is a Ford Fusion Hybrid. Granted, the test drive was only 13.7 miles but it still provided me a pretty sweet 72.9mpg.
  8. fuzzy1
    10,603
    What are Toyota's real-world claims that you want to see updated? I've seen them advertise only EPA figures. I don't want to see them go into the legal grey area of heralding other, over-optimistic 'real world' figures.
    This was the Taylors, visiting from Australia for a special VW-Shell promotion. Wayne Gerdes crushed it three months later, getting nearly 10 mpg higher in a Civic Hybrid in much less mpg-friendly conditions. I hope you have seen what he and others can do with a Prius.
    Why compare a PHEV Hummer conversion to a regular Prius? Compare it to a PHEV such as a Volt (once advertised at 230 mpg) and a PHEV Prius instead.
    Here is the Gen3 distribution I plotted three months ago, from user reports at fueleconomy.gov. Sorry, I didn't make an equivalent Gen2 plot.
  9. TonyPSchaefer
    14,816
    2,501
    66
    I wanted to enter my mileage into fuel economy.gov but was miffed when the site wanted miles and gallons and insisted on doing the math itself. Anyone with a Gen2 bladder knows that the mileage may vary from the calculations. I didn't feel like messing with it.
  10. F8L
    19,011
    4,083
    Grass Valley, CA.
    Just because you don't get good fuel milage doesn't mean everyone else gets poor fuel mileage. Either your commute or driving style is to blame.
    With my 15" wheels I don't even have to try to get high 40s for mpg. Even driving like it's a race car and my 17s I can get 40mpg.
  11. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    Likewise, just because you don't get better gas mileage does not necessarily mean those that do are liars... Which is the insinuation I get from the OP's posts. :mad:
    Son of Gloin likes this.
  12. TonyPSchaefer
    14,816
    2,501
    66
    Found this picture at home. Not sure if it's convincing enough.
  13. Paul58
    1,126
    125
    Atlanta
    I don't know, maybe you should stick your head in the picture as well so we know it's really your! Can you also get it notarized? :rolleyes:
  14. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    That is just more 'hypermilers drive too slow' propaganda. If everyone drove like a hypermiler, I predict that traffic would decrease, and people would arrive sooner. Imagine if everyone timed stoplights, so that no one had to stop!
    2 people like this.
  15. jstraw20
    jstraw20 Member
    122
    Long Island NY
    I'll take a picture of the mfd once I'm far enough into the current tank, but for now here's how I did last year, my first year of ownership. Average for the year was 52.7mpg calculated, 54.5 displayed. It would have been better had it not been for the really awful tank in December/January, when the car was in the body shop (don't ask). I primarily used the car for commuting, about 40 miles round trip, mostly highway miles on fairly level roads. Typically @ the speed limit but also plenty of heavy traffic which allowed me to P&G without disturbing the flow.
    The fun thing about this chart is it really shows the "bladder issue" in action.
  16. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    :p:rolleyes:
  17. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
  18. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    In the USA, it is illegal not to use the EPA ratings. When the EPA said 60/51, that was what Toyota advertized, current EPA is 48/45 for Gen 2. In the UK, it has a rating of 54.7 MPG in US gallons. In Japan, 83.5 MPG.
    I average 42 MPG in winter and 45 in summer, 48 in spring and fall. But look at my Avatar, all those other Prius are empty, you can see right through them. Mine is full, the weight pulls my MPG down.
    I too, am a geezer, 40 years of 'bad' driving habits hold my Prius MPG back in ways I may never get used to changing. If one of these whippersnappers visits you and gets 50+ MPG in your Prius, how will you feel?
  19. bisco
    52,390
    how do we know that's you tony? do you have a picture of you holding your picture?
  20. TonyPSchaefer
    14,816
    2,501
    66
    It's true. The whole reason for the ChicagoPriusGroup was so I could find people with better mileage, sit in their cars and take pictures with my ID.
    To be most accurate, pictures should be taken at an angle that displays the VIN, the owner and the mileage. Also, proof that the owner drove the car for the duration of the tank rather than using one of the many Rent-a-Hypermiler joints.
