Our 2006 Prius will soon need a 12 volt battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wtfjr36, Sep 10, 2011.
  1. wtfjr36
    wtfjr36 Junior Member
    63
    Ormond By The Sea FL
    We have an 06 Prius with 26,000 miles & wonder where to buy a battery other than the dealer & at what price ?
    Our original battery is doing fine but it is only a matter of when.
    Any suggestions ??
    Thanks !
    Bill in FL
  2. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    With that kind of service from the 12V , why would you bother looking elsewhere! Hal
  3. El Dobro
    El Dobro A Member
    7,093
    3,271
  4. wtfjr36
    63
    I have seen this site & was wondering if there was any other place & or some place here localy to purchase ?
    Any thoughts here ?
    Thanks.
    Bill in FL
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    You can buy the correct battery at your local Toyota parts department. Or you can buy a Yellow Top D51 by Optimia but you will need the conversion kit.
    The Prius does not use SAE battery terminals, it uses a much thinner JIS terminal. It is in the passenger cabin with your loved ones, so any replacement battery should be vented, (to reduce hydrogen gas build up, and AGM. (to reduce sulfuric acid spillage)
    That makes correct batteries very rare. If you have no loved ones, you could skimp on safety, but most of us love someone.
  6. wtfjr36
    63
    But, our dealer wants $230 not installed & $270 installed & all + tax !!
    For any car battery that sounds like a lot of $$$$.
    Is there a less expensive Toyota or another brand available ?
    Thanks.
    Bill in FL
  7. jstraw20
    jstraw20 Member
    122
    Long Island NY
    Do you have any other dealers in your area? The prices you are being quoted are really outrageous. I replace mine a few months ago and the dealer charged $200 installed. I'd definitely call around if you're not interested in the Optima.
  8. lessismore
    lessismore New Member
    FL
    Hi Bill,
    I am in FL (Jax) as well and I recently purchased a new battery from a dealer here in town for ~$148+tax. You should call all the dealers in the city you live in because I was able to pit two against one another and get the $148 price. I did EXTENSIVE research trying to find an alternate battery, that didn't require retrofitting, with no luck. If you are handy w/ tools it should take you about an hour to replace the existing battery. You should also know that my car had almost 100K on it when I replaced, so with only 26K you have plenty of time before you should need a new 12V. Remember the 12V doesn't function at all like in a non-hybrid in that it is never used to crank the engine. It just keeps the computer happy. My battery was actually down to just slightly over 10V with a bad cell and the car was still working fine. Good luck!
    Matt
  9. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    a lot of people (thanks to a few key people.. or one.. not sure) are starting to add distilled water. the battery is just getting low. if you feel like this is something you can possibly do then we or you can find the post and you can try that. it's a lot cheaper and people from early on (04/05) have strong batteries still.
  10. wtfjr36
    63
    "Remember the 12V doesn't function at all like in a non-hybrid in that it is never used to crank the engine. It just keeps the computer happy."
    I had no vauge idea that the 12 volt battery was not used to start the Prius engine !!!! Not too bright being an owner !!!!
    Would someone please explain what the 12 volt is used for, how you know it is going bad, & anything else that needs to be known about the 12 volt battery ??
    Thanks !!
    Bill in FL
  11. El Dobro
    El Dobro A Member
    7,093
    3,271
    From what I understand, the 12v battery powers everything except the hybrid drive system, like the audio, HVAC, windows, etc.
  12. V8Cobrakid
    3,790
    152
    actually.. the 12v only powers the doors and such when the car is off... the only job is has it to run things when the car is off... and flip on a few relays so the hybrid battery/system can do all the work. it's not used when the car is on. it just charges. there is an inverter that powers the 12v line when the car is on... way more power than the battery could ever feed anyway...
  13. qbee42
    3,081
    AC is powered by the traction battery. The radio, windows, lights, Nav, and other such accessories are powered by the 12V system, which means the 12V battery when not Ready and the DC to DC converter when Ready.
  14. drew_flux
    drew_flux Junior Member
    73
    22
    sydney australia
    late last year the optima importer to australia told me a d51 would be avalible with the small JIS terminals mid march this year. i couldnt wait and bought a stock battery. have a look and see if its avalible yet. if it is you will not need a adaptor kit for the install.
  15. El Dobro
    El Dobro A Member
    7,093
    3,271
    I stand corrected. :D
    Now let me ask this, does anyone use a battery charger to give the 12v a good charge every three months or so?
  16. Patrick Wong
    18,210
    6,514
    I use a 12V battery charger every two weeks or so, on the cars that are lightly used.
  17. richard schumacher
    7,675
    1,058
    United States
  18. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    For a few months now I have been wanting to change the 12V in my 2006. I checked several dealerships in Columbus and Cincinnati, and the price varies from $255-300 (installed).
