2012 Prius Plug-In official photos released
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Danny, Sep 13, 2011.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    You need to pull the gas door latch near the driver seat to open it, so it is unlikely. I wonder how the electric port door will open.
  3. SageBrush
    11,627
    2,533
    Southwest Colorado
    ^^ I was joking.
    But you never know what someone might do. Material for a Wiley Coyote cartoon
  4. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I can imagine the look on the gas attendant's face staring at the electric plug looking confused with a gas nozzle in one hand.
  5. SageBrush
    11,627
    2,533
    Southwest Colorado
    ^^ that takes looking, AND seeing
  6. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    I don't know how EV and EV city mode works, but from my understanding of press release EV mode will fire ICE earlier depending on the power demand from the throttle than EV City.
    If I am not wrong, electric motor also has it's efficiency curve but unlike ICE it's most efficient in low power band. Sure it's hard to say that sometimes it's better to run gas than draw batteries, especially if electricity is cheap, but this is the best compromise if you know you will be traveling more than 14 miles.
  7. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Since it is on the passenger side, and the demo cars acted this way, I'd imagine it will be the push in and it pops open kind.
  8. El Dobro
    El Dobro A Member
    7,079
    3,259
    "Hey lady, somebody jammed an electric plug in your filler neck".
  9. austingreen
    austingreen Senior Member
    13,664
    4,204
    Austin, TX, USA
    I think you are correct sir.
    In EV mode the prius acts like an electric car on a single speed transmission. As rpms increase torque decreases, and after a certain speed power to the wheels will also decrease. This doesn't necessarily make the drive inefficient, but will make the car less responsive and the battery run down quicker (since consumption / mile goes us as speed increases ).
    We won't know until some one is able to review the car, but If I would have to guess to city EV would give you a bigger time delay for acceleration at higher speeds than EV, but allow you to stay in EV mode without staring at the indicators. Normal EV mode may kick on the motor anticipating you will want to continue to accelerate. This is definitely a useful feature.
  10. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    Take note on the Prius that the air intake above the bumper has been significantly reduced (look at my profile/avatar photo to the left), and the enlarged air intake on the bottom is likely to compensate for this. The total intake surface area may be unchanged from "than they used to." (the iQ on the other thread also has this, as well as numerous other Toyota cars)
    My best guess is that reducing the amount of air intake on the top (where the hood meets the front end) increases aerodynamics and airflow over the top of the hood).
  11. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I think grill opening size is an optical illusion. The actual size should be the same.
  12. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Cool. Hope they're differentiated enough.
    As a side note: on my former 02 Nissan Maxima, I liked how they designed the gas cap and trunk release controls. Even though they were next to each other, the buttons/levers were of different size and one was push while the other was pull.
  13. DavidA
    2,342
    1,818
    Chicago western burbs
    The new grille looks like it is trying to swallow up more road.
  14. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    It sure make the car look wider.
  15. F8L
    19,011
    4,083
    Grass Valley, CA.
    I like it much better. Looks mean.
  16. hill
    8,727
    Yea ... munchin' all the Volts.
    :p
  17. uglymuddah
    uglymuddah Junior Member
    24
    The Netherlands
  18. reverai
    reverai New Member
    119
    Alexandria, VA
  19. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Do we know the equipment level and what's the equivalent cordless Prius price there?
  20. Danny
    Danny Admin/Founder
    7,093
    2,118
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    2 people like this.
