Headrest?
Discussion in 'Gen 3 Prius Technical Discussion' started by Dusty Chips, Jun 28, 2011.
  1. Dusty Chips
    Dusty Chips New Member
    85
    Laughlin NV
    Maybe I'm going nuts, but... Everytime I lower the driver's seat headrest, it later raises up again. Is this by design?
    Also, on an unrelated matter... I recntly had the experience of driving the same route (Las Vegas to Laaughlin) in the day and in the evening. The ambient air temp was about 30 degrees cooler (it gets hot here in the desert). Admittedly non-scientific observation, but with the A/C running much less, there was a 5 MPG difference. Does that seem correct/
  2. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
  3. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    That (5 MPG hit) was my experience until I learned, on this site, a more efficient way to use the A/C and air circulation system. Running the car in Economy mode, with the A/C in auto, recirculate on and the temperature adjusted to 76-78 degrees F has little impact on fuel economy and, once the car cools down, is comfortable in the front seats. Adjusting the temp to cooler settings speeds up the fan and vice versa if you raise the temp. Although this method works fine for front seats occupants, it may not get enough cool air to the back seats. Give it a try and let us know how it works for you. :)
  4. SmellyTofu
    SmellyTofu Average punter
    251
    29
    Sydney
    Are you pushing the lumbar area pretty hard? This will raise the headrest slightly to stop your head from rolling over the headrest as the lower backrest activates a mechanical link to the active headrest mechanism.
  5. El Dobro
    El Dobro A Member
    7,099
    3,276
    Interesting, my car has the incredible creeping headrest, too.
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    My headrest does this too. Every time I push the headrest down to the top of the seat it creeps back up to the first notch in the posts :cool:
    I have just about decided to leave it in the first notch.
  7. El Dobro
    El Dobro A Member
    7,099
    3,276
    I'll have to see how far it goes if I don't push it back down, So far, it's been going to the second notch.
  8. Unlimited_MPG
    Unlimited_MPG Member
    218
    24
    Federal Way, WA
    I have the same issue with my headrest...it likes to peek over my head :)
