2007 A/C doesn't always start blowing air after hitting start button
Discussion in 'Gen 2 Prius Technical Discussion' started by james78, Sep 16, 2011.
  1. james78
    james78 Junior Member
    25
    florida
    Sometimes when I hit the start button it takes a couple of minutes for the AC to start blowing air. I even tried stopping and shutting off and restarting but it still took a few minutes to start blowing. It doesn't do this all the time just evey now and then. Any ideas. thanks in advance.
  2. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I think that the AC doesn't blow air until the heat exchanger/AC unit is the correct operating temperature for the setting you've selected. Otherwise, you'd get a blast of cold/hot air when you wanted it to be the other.
    It's actually quite nice of it, In my opinion.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    If you have the AC set to Auto AC, it's normal for a delay.
  4. james78
    25
    florida
    I know when I start thr car it takes a second or two for the blower to blow. When it does this it's minutes before the blower kicks in. I do keep it set on auto but I tryed manually turning the blower up, turn ac off and several other things and it does nothing. Then all of a sudden it kicks in.
  5. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    See my answer.
