Service Dept. trying to rip me off?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by canesfan, Sep 20, 2011.
  1. canesfan
    canesfan Culture shocked...
    544
    Jacksonville, NC
    I have a 2008 with almost 41,000 miles on it. Up until now, I have always had it serviced every 5,000 miles at the same dealer with no problem. I recently moved cross-country (had the 35,000 mile service done somewhere in Nebraska, I think) and went in this morning to a new dealership to get the 40,000 mile service done. First the service rep says he can't find all my service history. Then he asked if I've ever had a fuel system service done ($159.99). I said no. Then he says they always recommend it every 20,000 - 25,000 miles. I declined. If this is a recommended service, wouldn't my previous dealership have suggested it at some point? Or the dealership in NE? It all seems fishy to me. There were two guys in the waiting room with me. I asked them if they had service there before, and they both said no. One guy said the service rep couldn't find all of his service history either. This is a military town and some businesses try to rip people off if they know they are military by the base tags on the car. They figure we won't be around long enough to either protest or be a repeat customer. What do you think?
  2. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Fuel system service?
    I don't know what it is and I've never "had it done". Perhaps someone else can correct me but I'm not sure I've even seen something like that mentioned here at Priuschat unless it was called something else.
  3. canesfan
    544
    Jacksonville, NC
    I just called the service rep and asked him exactly what this service entails. It is supposed to clean out the fuel rails, injectors and intake valves. It's all Greek to me, but that's what he said.
  4. canesfan
    544
    Jacksonville, NC
    ...And the throttle body, too.
  5. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    If it ain't broke... The only way I would have a fuel system cleaned is if the car was showing symptoms of rough idle, hard to start, seriously bad performance and mileage. Just add a bottle of Chevron Techron to the fuel tank after a fill up and that is all the preventitive maintenance you need.
  6. ETC(SS)
    7,373
    Stop.
    If you've had your car regularly serviced by a Toyota dealership for the last 4 years, and you're at a Toyota dealership, and they "can't find all [your] service history", then I would leave immediately after doing three things:
    1. Ask for the service manager's card. If you're at a real dealership, they should make these available in a dispenser in the waiting room, or at the cashier's window. If they don't...that's what we call an 'indicator."
    2. Ask them to show you the fuel system cleaning service in the schedule of maintenance. It's easy. The Aichi Iron Works schedules required maintenance for the first 60K miles (and beyond for those with extended warranties.) If it's on the SOM, it's required. If it isn't, it isn't.
    This "fuel system cleaning" is, at best, a can of cleaner sprayed into your intake.
    Unnecessary, and even potentially harmful, since sometimes they'll actually disassemble part of your fuel system to spray their "marvel mystery fluid" (R) into your intake.
    Your fuel efficiency OK?....... I thought so.
    Do NOT do this.
    Ever.
    Well....OK. theoretically you might need a fuel system cleaning every quarter million miles or so if you live in harsh environs, or if your gas is for crap.
    OK....now for #3.
    3. These guys are either crooks or morons. Tell them I said so.
    If you have a smart phone, show them this site and invite them to defend themselves if they have the stones.
    They won't.
    If they're not competent enough to look up your vehicle's service history, you don't want them swinging wrenches on your car. If your vehicle service history really is unavailable in the wilds of NC, then they tried to make a quick buck fifty off of you. $1,99 for carb cleaner. $8 for the half hour that the apprentice tech would charge for pretending to use it, and the rest for the dealer.
    Use the business card to pop a flare over whatever Toyota uses for a customer care branch in your part of the United States.
    Good Luck!
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I agree with this.
    The items being mentioned as being cleaned as part of this service can be maintained well using an occasional bottle of Techron. I also agree that they will usually give demonstratable warning if/when they approach needing cleaning.
    On a vehicle with < 50,000 miles on it? I'd hardly think the service is necessary and nothing more than a cosmetic revenue service for the dealership.
  8. canesfan
    544
    Jacksonville, NC
    Noticed something interesting... I just carefully read my service invoice and, as part of the 40,000 mile service they put in BG Motor Oil Additive, BG PF5 Fuel System Cleaner, and BG Engine Quick Clean. Adds up to about an extra $17.00. So, they are putting in this BG Fuel System Cleaner AND they want me to buy their "fuel system service"? Seems redundant and makes this whole thing sound even more fishy to me. I know, I know, I should have read the service invoice more closely while I was standing there checking out...
  9. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    Santa Fe, NM
    All that is a ripoff. If you can go to a different dealer, do that. Otherwise, ask around with other Toyota owners on base and see where they go ala independent shops. But don't go to a quick-lube either.
  10. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Canesfan,
    Maysville is close to Jacksonville, NC, correct? You must be going to Stevenson Toyota in Jacksonville, correct? They own several different dealerships in eastern NC.
    They own the Honda dealership in Wilmington. I take my wife's Accord to them and have had excellent service from this dealership. Yes, they always want to offer the fuel system, coolant system, transmission system and brake system flushes. These are all money makers for the dealerships. I just tell them no when they offer and they just move on and do what I ask them to do.
    If you continue to have trouble with Stevenson in Jacksonville you may want to try Toyota of Wilmington. It is on the Jacksonville side of Wilmington and maybe 45 minutes from you.
    Dwight
  11. canesfan
    544
    Jacksonville, NC
    Thanks, Dwight. It's good to know there are other PriusChatters in the area! There are not too many Prii on the road here compared to Oregon. :D Yes, Maysville is near Jacksonville and I did go to Stevenson Toyota. I see your point of view on the upselling. I wouldn't mind that in and of itself. It just made me suspicious when they couldn't seem to find all my service history (or the other guy's) and then I realize later they are putting extra stuff in my car that's not part of the regular maintenance without giving me the chance to opt out and then I paid for it without realizing it. I am writing them an email about my experience, so I'll see what they have to say. Do you know which other Toyota dealerships they own around here? My husband is retired from the Corps after 26 years so we are not going anywhere and I would like to find a reputable place to go.
  12. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Canesfan,
    Come to Wilmington and you will see lots of Prii running around :)
    Stevenson owns a lot of other car dealerships like the Honda, Mazda and Suzuki dealerships in Wilmington. The Toyota in Jacksonvile is the only one that I know.
    I know that Rick Hendrick (NASCAR fame) owns the Toyota dealerships in Fayetteville and Wilmington. I bought my Prius at the Fayetteville dealership and was quite impressed. More so than my local dealership. If you cannot get satisfaction from Stevenson, I would recommend trying one of the Hendrick ones.
    If you will go to ToyotaOnline.com, setup an account and enter your VIN you should be able to see all of your car's service history at any Toyota dealership. Of course, Stevenson should have been able to see it also, assuming the past services were at a Toyota dealership.
    If I can be of help, let me know.
    Dwight
    2 people like this.
  13. canesfan
    544
    Jacksonville, NC
    Thanks again, Dwight! :) Yes, all of my service has been at Toyota dealerships. I will check out that website you mentioned. If I can see my all service history, I will really wonder about this dealership!
  14. jdcollins5
    5,131
    1,346
    Wilmington, NC
  15. canesfan
    544
    Jacksonville, NC
    Yeah, I figured it out. :) On that website I don't see any service history for 2008 or 2009. I called my previous service dept. and they said it's all there on the national Toyota database and the service dept. here should have been able to see it also. I am currently on hold with Toyota to see about filling in the gap. I have all my service invoices, but I would like to be able to see it online.
  16. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Just to make sure, there are multiple pages on my Service History. If you go back to the furthest page, can you not see anything for 2008 or 2009?
    I thought I was missing some of my first service records until I realized that a second page had been started and I had to select the previous page to see the previous recoreds.
  17. EffinRed
    EffinRed Junior Member
    32
    Boston, MA
  18. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Another nice thing about this site is that you can add your own service records if you DIY oil changes, etc., or use a non-Toyota service facility. This way you can keep up with all of your service records in one place.
    This will be useful for dealership warranty questions and if you sell the vehicle.
  19. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    They do more but basically it amounts to putting a $6 bottle of Fuel Injector cleaner in tank.
  20. canesfan
    544
    Jacksonville, NC
    I did go back to the earliest page and they have the date when I bought my Prius and then, on the same page, it skips right to 2010. I have followed up with Toyota to get it fixed.
