Driving in Snow
Discussion in 'Gen 2 Prius Main Forum' started by trip, Oct 3, 2011.
  1. trip
    trip Junior Member
    25
    Illinois
    I figured I'd beat the rush on snow questions :)
    I've got a 2008 Prius that I purchased a year ago and I recall last year I had some issues driving in the snow, mainly getting stuck. The tires were properly inflated and had plenty of tread. I live in the Chicago area.
    Wouldn't this be something that occurs frequently in snowy areas-driving over snow and maxing out the clearance? I would think the question was asked while designing the car, "what about snowy areas?" I've done some searching on this site and it seems that tires are the most frequent answer. If that the case, what kind of tires are other's using in the is area or situation to address getting stuck? I love the car, but this is a little frustrating.
    Thanks,
  2. jdenenberg
    jdenenberg EE Professor
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Either buy a pair of good snow tires for the Illinois winter or get a set of 4 Nokian WRg2 all-weather tires that are almost as good in snow/ice. Decent tires make a difference and the original tires that came with my 2004 Prius (Goodyear Integrity) were terrible in the snow.
    JeffD
  3. ursle
    ursle Gas miser
    1,049
    192
    NH
    It's a front wheel drive car with stability control, clearance isn't really the issue, what's someone doing driving around in 10"+ of snow, just trying to get into an accident?
    Put on new snows with studs, the car will be unstoppable. Or in the event of wanting to stop, will stop on a dime. It will also turn when you want it to, unlike having forward momentum and not being able to turn or stop...
  4. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    Or get a set of chains and keep them in the back - if you do this be sure to practice getting them on and off on a nice day.
  5. deltanh
    deltanh Junior Member
    44
    Manchester NH
    I'm considering Bridgestone, no studs, for our NH winters. What do you think?
  6. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    I've been using Blizzaks on both my Prii (2004 and now 2010). I have not had any problems commuting from Nashua to Bow.
    Don
  7. Mendel Leisk
    41,022
    I've heard the second gen's traction control is set overly sensitive, ie: it will refuse to turn the wheels once you get a slight loss of traction.
    Also: "plenty" of tread is one thing, but snow tires have a much more aggresive tread, coupled with more siping (lateral slits). Their rubber is also a different formulation: that stays pliant when temperatures drop, compared to all-seasons.
    You are right about ground clearance, and the Prius is just so-so (better than our last Honda Civic Hybrid, anyway): it doesn't matter what sort of tires you have, if you hit deep enough snow you will get stuck. ;)
  8. trip
    trip Junior Member
    25
    Illinois
    Thanks for the feedback folks. It sounds like the the best thing for me is to get different tires for such a situation. Which introduces some variables.
    One thing I can say for sure is that, like many, money is very tight and will continue to be tight for a while. Obviously I don't want to trade safety, but here is what comes to mind:
    Will there be enough difference with all weather tires to minimize getting stuck?
    Would I want to change to winter tires each year instead?
    What would it cost to get rims with these new winter tires.
    What is the cost of changing just the winter tires as opposed to changing the winter tires that are already on spare rims.
    I realize I'm asking for some detailed recommendations, I'm really just looking for the best value.
    Thanks for all the help again.
  9. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    I'm not sure how serious your issue is. The Prius had a problem with traction control kicking in too early, but I'm pretty sure that was resolved in 2006 and you shouldn't see a problem on your car. Is this noticeably worse than other FWD cars you've had (sedans, hatchbacks)?
    There's plenty of us in the Chicago area, and most of us have had little to no difficulty getting around, even in 10" of light snow. The only time I had a problem was when I had 40K miles on the original Integrity tires, I had stopped on an uphill at a light unknowingly on ice and then had trouble getting going again. (This was at a point where I saw a policeman earlier directing traffic to the center lane, so I assume the icy patch was a problem for others as well). That's about when I decided I should probably get new tires before the next winter.
    Tame picture from a few years back. I should put up a real snow picture, but this is the best I could find at the moment.
  10. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    It's not just the tread that matters, it's the rubber compound. Summer and 'all-season' tires get too hard in low temperatures to provide useful traction. Snow tires are made of softer rubber that stays pliable in Winter. If you live in an area that gets real Winter - and Illinois would probably qualify - then you need Winter tires. Yes, it's a bigger cash outlay, but it means your Summer tires will last that much longer, and you'll be far safer when the roads are slippery. From that point of view, two sets of tires are probably LESS expensive in the long run, especially if they keep you out of an accident.
  11. qbee42
    3,079
    Maxing out clearance is an issue with any vehicle. Ground clearance on the Prius is pretty typical for front wheel drive cars, so there isn't anything special in that department. Certainly Toyota gave some thought to this area, and as a result decided to make the Prius about the same as any other car. If you require more ground clearance you should be driving a truck.
  12. jdenenberg
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Mendel and HYO,
    The Nokian WRg2 tires have "soft in cold" rubber compound, extra siping and aggressive tread (on one half) to allow good bad weather traction that compares well against true snow tires (at least until the tread depth is down to 4/32). They do have a somewhat short tread life (about 50k miles).
    JeffD
  13. nerfer
    2,507
    237
    28
    That really depends on where you land on the paranoid to over-confident spectrum. I'm probably on the OC side (having grown up with 'real' winters in northern MN where it gets to -40' (F or C).
    But you can certainly drive all year long with all-season tires in Illinois, or Minnesota. If you're in very hilly terrain, or you get a lot of wet snow (like nor'easters in Boston area), then snow tires may be necessary. Dry snow, like we get in the middle of winter, is easier to drive on, so in the upper midwest there's really only a couple days a year where you have to be extra careful. And you can still get where you're going, providing a snow plow has been able to make it somewhat recently. If you're a plow-truck dispatcher or 911 operator or something and absolutely need to drive to work regardless of whether the plows have been out yet or not, then you might want to invest in snow tires. Or a Subaru.
    People tend to get all bent out of shape about things, when just driving at a moderate speed, keeping momentum when they need it, and slowing before curves or stops, will do the job just as well or better than some extra bit of technology or specialized tire.
  14. ursle
    ursle Gas miser
    1,049
    192
    NH
    Last winter was my 5th on some Michelin x-ice without studs and it's do-able but new snows with studs will eliminate the not able to move on ice and or not able to stop on ice syndrome. They only stud when the tire is new, with stability and traction control the prius won't move in 3" of snow, won't go uphill on ice from a stop, etc... with studs that's eliminated, it's you personal call, I like the idea.
  15. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    I've gotten stuck in the snow in my '08. And I'm proud to say that yes, I
    was able to spin the tires -- to no avail in the particular circumstances.
    I was was stopped dead, with the car bottomed out on a ridge of snow
    under the center of the car. All in all, it wasn't the car's "fault." The
    tires did spin, but wheel RPMs appeared to be limited. I couldn't "gun"
    the engine and really get the wheels whining. It really frustrated the
    young men who eventually got me out. Much to my surprise, I was able
    to do a weakish rocking motion between forward and reverse.
    Oh yeah, be sure to tell anyone pushing not to touch, never mind push
    on, the rear spoiler.
    I would certainly second the idea of keeping up momentum, what with
    the reduced power application that the Gen II have.
    Since that time I've gotten real snow tires on rims. And they worked like
    a champ... as a snow deterrent; last winter we had very little snow.:p
    This year I intend to buy a snow blower with the hope it too will deter
    heavy snow again this year.:rolleyes:
  16. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    You cannot get extra ground clearance with winter tires. I say this because you implied you might gain some. The Prius wheel/tire combo runs with only one size diameter.
    I've had no problems with snow and ice except last year, when we had a record snowfall. Even then I would have been ok except our city doesn't -remove- snow, they just push it around. I came home to a 6" step in compacted snow/ice to get into my back alley. NOT GOOD!
    I've been running the Nokian WR and just replaced them with Nokian WRGII. They work just fine. Take it easy, avoid morons, and you won't have problems. ;)
  17. Tideland Prius
    16,508
    The investment is worth it. Remember, if you're using the winter tyres, your all seasons aren't being used so you don't have to change them as soon as you would if you were runnning them year-round.
    Winter tyres will have a more aggressive tread to deal with loose snow. Their rubber compound is also softer to allow them to maintain grip at low temperatures (all-seasons will harden up, making them less flexible and unable to provide the same amount of grip as they would in warmer temperatures).
    The difference in grip is amazing. I was a convert in 2007 when I got Nokian WRs for the 2005 Prius and then dedicated winter tyres (Nokian R) for the 2010 Prius.
    Mounting the winter tyres on separate rims have a few benefits.
    - Save the alloys from the harsh winter conditions (salt, grime, crud, potholes, cold temps)
    - Reduce wear & tear on the rim because you're not taking out the tyre off the rim twice a year
    - One time investment on the steel rims pays for itself after one season because changing the tyres yourself or even asking the shop to do it is cheaper because they treat it as a tyre rotation. If you ask them to mount the winter tyres onto the stock alloys, it will cost at least 3x more (it costs me 5x more. Cdn$20 vs. Cdn$100).
    Downside? Well there's the initial layout (but at least for me, it's the same cost as one seasonal changeover) as well as the Low Tire Pressure light will be on all winter (I'd rather live with that than incur the high cost of separate tyre sensors. You just have to be more vigilant with the tyre pressure and ensure they're not below recommended.. you know.. like the last 50 years)
  18. a_gray_prius
    2,927
    783
    IL
    I'm in Chicago and occasionally make trips to very poorly plowed places in Michigan. I have Nokian Hakkapellita R tires mounted to my stock rims and have no problems in the snow. I can do the wheel changeover myself with the spare tire jack in about an hour having invested in a Sears toolset (on 50% off sale) and a torque wrench.
