Winter Blend Gas
Discussion in 'Gen 3 Prius Fuel Economy' started by car compulsive, Oct 5, 2011.
  1. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    It looks like winter blend gas has arrived in Michigan. My Prius MPG on Fuelly went from 50-51 in September to 48.1 and 48.4 on fill-ups on October 1 & 5. I haven't filled the Lexus (with premium) yet in October, so we'll see where that ends up.
  2. Mark57
    2,945
    2,740
    OK
    We haven't switched here "yet" but I know it's coming soon. It's usually mid to late October for us.
  3. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    Keep in mind, it's been a lot colder in the mornings the last week or two. I notice my engine running much longer on a cold start than it did three weeks ago.
  4. car compulsive
    741
    274
    Michigan
    My engine has no choice but to run in the mornings. I drive 1/10 mile to the entrance of our sub and then accelerate to 50-55 for the next 5 miles to town.
  5. Roadburner440
    Roadburner440 Member
    316
    59
    Hampton, VA
    Yeah I am not looking forward to the winter gas myself, and sorry your state already switched over... This is part of the reason we got rid of the truck for a PHEV so we could avoid running the Prius hard all winter. At least you are still getting close to 50mpg though. I am curious to see how far it drops in full blown winter though. This will be our first full winter with our Prius (we bought it at the tail end of last winter), so we have not seen cold weather ops with it. I have read the horror stories of 35-38mpg though on winter blend gas + the cold.
  6. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    I don't even see mpg that low in MN. Being in FL, you'd have to drive some mighty short trips to cause that.
    Here's my experience last winter:
  7. Roadburner440
    316
    59
    Hampton, VA
    Well here in Jax my daily drive 1 way is 11.2 miles give or take... When we move to Virginia at the end of the month my drive is going to go to 5 miles 1 way with a lot of sitting in traffic. I personally have never seen mileage lower than 48mpg, but having read other peoples threads I try to prepare for worst case scenario. Plus our average trips to the store (Wal-Mart, Target & such) are barely 1.5 miles away. I also like to give people practical numbers as I know not everyone sweats the MPG's like some of us. Certaintly looks like it has quite a dip between Dec-Feb. Will guess due both to initial car warm up and heater usage? I should probably start a log like that for our car.
  8. walter Lee
    1,126
    376
    Maryland
    The short trips will lower the Prius MPGs because the Prius needs to run atleast 20 minutes per trip to mitigate the cost of warming up the ICE and catalytic converter. Blocking the lower air intake of the 2010 Prius will help lower this warm up cost for short trips and urban stop-and-go traffic congested roads. You should not block the lower air intakes for superhighway driving (>55 mph for >30 minutes) If you'd rather not sweat the MPGs - your best bet for reasonable MPGs is to set the "ECO" mode on and just drive the Prius like anyother car - the Prius onboard computer will then make the decisions for you. If you haven't already - you can also get better MPG if you use a Jax service station that sells pure gasoline - you can goto the following link to find one near you - pure gas has more energy per gallon.
    Ethanol-free gas stations in FL
  9. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    Interesting question, is that MPG loss due to gaso composition, or cold weather? Gaso composition, the main difference I guess is higher vapor pressure, EPA allows more butanes in there? The old rule-of-thumb is that all gasolines are the same, so if this minor change makes a big MPG difference, the old rule would be proven false (exclusive of ethanol MPG debit).
  10. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    Car Compulsive, I am in SE Michigan and have not seen a drop in MPG's yet. My current tank is at 56 MPG over 400 miles into the tank, and for my driving routes, this is even a bit on the high side. Tires at 42/40, though I am going to drop them 2 psi this month due to the increasingly harsh ride on our poor roads.
  11. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    Here is some info from FuelEconomy.gov
    I do not think it helps answer too much, because: (1) not sure the 1.7% less energy number (winter fuel) is up-to-date and/or includes variations in ethanol; and (2) not aware that there is a good correlation between fuel energy content and MPG.
    Lots of other factors - colder/viscous lube oil cited as 3 MPG debit in winter in one post on another site.
  12. Caug1
    Caug1 Member
    119
    BOSTON
    Are there ethanol free gas stations in mass?
    c
  13. walter Lee
    1,126
    376
    Maryland
    How can you tell that the winter blend gas has arrived? :confused:
    Thanks.
  14. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    The only thing you can easily determine is legally what date the gasoline stations in your area are allowed to switch over to the less restrictive winter blend. However, they may still have summer blend in storage and will use summer blend until it is used up. Maybe ask the station manager. Got this info from reading other posts.
  15. car compulsive
    741
    274
    Michigan
    I filled up at the same station a couple times and saw the MPG drop. However, I changed stations and saw the MPG go back up with no changes in driving habits. but warmer temps. We'll see what happens with the temp down again, but gas from the second station.
    LOL, Yes my life is quite boring and predictable.
  16. walter Lee
    1,126
    376
    Maryland
    Both the databases from pure-gas.org and from buyrealgas.com
    suggest there are no ethanol-free gas stations in the state
    of Massachusetts. :(
  17. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Also, when the EPA does the MPG fuel test it does NOT use 10% Ethanol gasoline.
    Why????
    Here in Oregon I have absolutely no choice as 10 % Ethanol gasoline is required all year long in Oregon.
    The EPA should use 10% Ethanol gas when conducting their test as
    they seem to always tell us how GREAT Ethanol is.
    Another point; 10 % Ethanol gas is more likely to give you at least a 5-7 % less mpg's than regular gas, maybe more.
    Ethanol for fuel, from a standpoint of common sense, is useless, when it takes 2 gallons of diesel fuel, 250,000 BTU of energy, to make 65,000 BTU's 1 gallon of Ethanol.
    Only our government can see the sense in that....
    alfon
  18. chucko
    chucko Junior Member
    Oregon
    Gasoline without Ethanol is available in Oregon, you just have to know where to find it.
    http://www.boatoregon.com/OSMB/news/E10.shtml
    http://pure-gas.org/index.jsp?stateprov=OR
    Here's more info regarding the lifting of the ethanol blend requirement for gasoline above 91 octane.
    http://www.oregonlive.com/opinion/argus/index.ssf?/base/editorial/1271445675256810.xml&coll=6
    http://www.oregon.gov/ODA/MSD/renewable_fuel_standard.shtml
    and some additional interesting info:
    http://e0pc.com/newreality.php
    Demand for Gasoline at a 10 year low:
    http://green.autoblog.com/2011/09/27/u-s-gasoline-demand-hits-10-year-august-low/
  19. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Fortunately we don't have to deal with the "blend" up here however "comma", once the studded snows go on and the temps dip to 30 and below I drop from 51 to 41-43. Ouch and that is with a 30 mile commute.
